Question about Video Game Consoles & Games
I have an emprex 3009 ARF wireless remote control. when i plug the wireless receiver into a usb port on my toshiba c660 laptop it does not seem to be found by windows 7. the red led on the hand held remote lights when a button is pressed but no response from the receiver.
C13295
  • 128 Answers
SOURCE: Xbox360
This means you have insuffiecient power for your XBOX 360 to work. You need a stronger power source
Posted on Jan 12, 2008
SOURCE: cant use ps3 controller wirelessly
Got the same problem, bought a new wireless controller which worked fine for 2 weeks then had the same problem. It's fully charged but won't connect to the ps3 unless it's wired. When wireless all four lights just flash simultaneously!
However the other day the newer wireless controller started working wirelessly again, but the original one still has the problem.
Anyone know a number i can ring sony on for support with this?
Posted on Jan 14, 2008
  • 3 Answers
SOURCE: PS3 controller Problem
I just fixed mine. The controller itself needs to be reset. There is a reset button on the back of the controller, above the top right hand corner of the square with all on the information and barcode. Press it with a sharp tipped object while still connected to the PS3 via USB cable. Then press the PS button and you should be back on wirelessly.
Posted on Jul 09, 2008
bubulica2000
  • 55 Answers
SOURCE: Connectivity
sounds like your wireless board went bad. Call SONY if you still have warranty.
If not find a wireless board (I sell them sometimes on ebay). It is really easy to replace.
Contact me at bubulica2000@yahoo.com if interested in purchasing a wireless board.
Posted on Sep 16, 2008
  • 80 Answers
SOURCE: Help Microsoft Xbox 360 Wireless Receiver For Windows, help help
Hello my name is Tim Ehrhart, If the reciever is not lighting up then it is dead, you can try to take it to walmart and exchange it for a working one, they are usualy good at swapping out and if they give you a hard time buy a new one and return it with the old reciever instead of the new one. I hope this helps you.
Posted on Mar 14, 2009
How to install 2.4Ghz wireless mouse with USB receiver?
Insert the batteries into the mouse. Turn the mouse over, find the battery cover, and slide it off. Insert the appropriate batteries-usually two AAs.
  • The wireless receiver that plugs into the computer uses USB power, so it needs no batteries.
Connect the receiver to the computer. If your computer has a USB port (as most do), plug your receiver into an available port. There will also be a green adapter supplied, in the event that your system requires the use of the mouse port. Caution-don't try and force the mouse adapter into the keyboard port!
  • The mouse receiver has a USB plug (left), but can also plug into the mouse plug through the adapter it came with (right). If your receiver plugs into the USB port it should look like the left. If it plugs into the mouse plug it should look like the one on the right, only connected to the receiver.
Connect the mouse to the receiver. Place the mouse in close proximity to the receiver, and note the following:
  • The receiver should have a visible button that is easily pushable by the average human finger.
  • The mouse will usually have a very small reset button in a hole on the bottom that can be pushed by something like a pencil or paper clip.
  • Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
Find a permanent position the receiver. Place the receiver where it won't be far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk.
  • The furthest a wireless mouse can get away from the receiver and still function is about 9 feet (2.7 meters), so keep that in mind.
Test your new mouse.
  • If you plugged into the mouse port, restart your computer.
  • If you plugged it into the USB port you should be able to use it immediately.
  • When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Adjust your mouse settings. Use the control panel that came with your wireless mouse, or download the necessary software from the manufacturer's website. Adjust the settings so that the mouse performs as you require.
Oct 18, 2014 | Computers & Internet
MY LAPTOP DOES NOT DETECH TOSHIBA USB OPTICAL MOUSE U20
Try a different USB port. Is the mouse wireless? If so, make sure it has a line-of-sight to the receiver that is plugged into your USB port. Does the laser (on the bottom) light up? If not, check the batteries.
Jun 19, 2014 | HP Wireless Optical Mouse
Toshiba c660 keyboard not working on left side
Fit a new keyboard. They are not expensive.
Jan 03, 2018 | Toshiba satellite c660
Both USB ports are broken
Unfortunately the C660 does not have a pc card/ esata interface for you to get an extender card. At this point, the options you have are to see if the system is in warranty or see if you could purchase the motherboard from Toshiba. An alternate would be to see if a local tech could resolder the ports for you... however your mileage may vary.
Sep 22, 2012 | Toshiba satellite c660
My Fuji xd card wont fit into slot of my Toshiba Satellite C660-1LD
That means your Toshiba's slot is not designed for that particular card. Go buy a card reader that handles many different sizes and formats for less than $20 and it plugs into your usb port.
Try this site at the link below and when it comes up just type: USB XD Card Reader in the white search box at the top and press GO.
You can sort the results from most popular which is shown first to Prices Low to High.
http://www.tigerdirect.com
Apr 23, 2012 | Toshiba Computers & Internet
Ports/Interfaces on Toshiba Satellite Pro C660-171
If you still have warranty, take it back asp, they will have to repair or replace since this was manufacture defect, if that is not an option! Do a complete recovery on your operational system to factory setting.
Mar 21, 2012 | Toshiba Satellite Pro 6000 Notebook
Usb port won't recognize mouse
the usb port may be damaged or bad solder connections, do a system restore taking the it back before the problem occured. "long shot"
Mar 19, 2012 | Toshiba satellite c660
1 usb port on toshiba satellite c660 doesn't recognize mouse
If is just a USB port, then it could be a driver problem, or that USB hub is turn off, or is a fried/bad USB port. Try another USB device on that port too.
Mar 19, 2012 | Gigabyte GA-8I845GVM-RZ Motherboard
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
