Question about Samsung Rf217acbp Black 20 Cu.ft. 33" French 3 Door Refrigerator
While a friend was out of town the refrig stopped working. He had quite a smelly mess to clean up. I looked at it and there is oil on the suction line and on the pan below the compressor. The compressor tries to start, draws near LRA, and kicks out on the overload. I suspect a loss of 134A and a compressor failure. We are going to Sears this Friday and demand restitution due to a manufacturing defect. Any advice?
    Master:
  • 492 Answers
Hang tough and demand they honor the warranty.
Posted on Oct 18, 2013
Ice collects in the bottom of the freezer not allowing door to shut
BA Baker... hello,
Ice collecting on the bottom of the freezer.. is not such a terrible thing...
(Probably means the defrost is working... (merely not EXITING)).
New refrig or unfamiliar refrig could cause deeper analysis...
but if ...
If this is not a new device... and has been happily tending to it's own needs (evaporating well) for a while (months would be re-assuring)...
Then you are MOST probably looking at a clogged evaporator drain... (usually easily fixed by negotiating "WARM" (not hot) through the bottom vents slots of your freezer section.
Looking under your Refrigerator/Freezer... or consulting your owners manual... Locate your defrost "catch" pan...
It should NOT be dusty...
(easily tested: clean paper in tray...
Still clean tomorrow = clogged drain (pan is watered daily).
Close inspection should reveal a tube descending into it.... This is where you will watch for your patiently applied doses of warm water to appear... (near immediate).
It may take several doses... because ice can also have formed over the drain... Be persistent... You will be proud.
Please comment me back... I really like REFRIGERATORS/Frzrs...
few appliances tend to themselves so well (adorable).
Samsung RF4287HABP User Manual
Apr 17, 2016 | Samsung RF4287HABP 28 cu. ft. 4-door...
Freezer door does not have the vacuum suction that it did have
Check the door is square to the frame and no shelves are sticking out stopping the door from closing properly. The seal should be magnetic and stick to the frame quite well.Check no metal strips have come off so the magnetic seal isn't attaching to the frame
May 20, 2012 | Frigidaire 20 cu. ft. / 566 liter Upright...
Power to food filled freezer in garage been out for 2 weeks how do we clean up this nasty smelly rotten mess
Try scrubbing with soap, then wiping with baking soda and, finally, wiping with vodka. Remember to keep a drop or two for the workers.
Jun 17, 2011 | Freezers
Have a standing freezer compressor is working suction line cold discharge warm but the box temp is the same as the room temp what could be the problem?
dear sir
i think its problem in freezer,s capellery pipe and filter it has been blocked by dusty oil so. please open that cappellery and filter and make clean after reuse or change i hope it will work good
hope answer the question.
thank you.
Jul 09, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Started making screeching noise, started to spit
ok,,il be blunt,,,throw it away,,its past its best,,to have it fixed would be costly so do yourself a faver and just buy a new unit,,,,then show it off to all your friends,,,like look what iv got,,,eat your hart out!!!
it would be the cheapest way out of this
Jun 24, 2010 | Freezers
I replaced compressor for a hussman refrig and its hums loud
God day,
Some thoughts.
1. Are the evap fan motors running, and at full speed. That would give you abnormally low suction pressure.
2. Cap tube sized too small. or partial restriction in the dryer cap tube/dryer when brazing in the lines.
3. Low ambient. What's the temp the machine is running in.
4. Over sized compressor.
5. Moisture. God, 134A is touchy on that one.
6. Was original cap tube soldered to the suction line to create a heat exchanger. Needed on many apps. Definately would cause flash back on start up.
7. Superheat a little low, should be 12 to 15 degrees.
Jan 31, 2010 | Hussmann Freezer Gelato Pan Rack (For 12...
How to tell if you have a bad suction valve for ac compressor?
Hey there. First question I have is if you have a heat pump or straight ac. Straight ac is easy to diagnose. Your suction pressure will be high, your head pressure will be lower, not sure how clean your condenser coils are so its hard to say how high. Your amp draw on your compressor will be lower than normal. Also, when looking at the suction pressures, you have to keep in mind what temp the air hitting the evap coil is. If it is warm, that will make your suction pressure go up. Another way to check the vavles is to hold the suction line at the compressor when you shut it off. If the temp goes up the second you shut it off, this tells you the hot gas is leaking through your suction valves. You can also try to pump the system down, then shut it off and see how fast the pressure builds back up, this will give you and idea how fast it is leaking through. Let me know if you need any thing else, I'll be here.
seth
Jun 26, 2009 | Hussmann Freezer 12 Facing Straight Glass...
Need a freezer for garage in the Dakotas
Refrigeration units don't care for the most part how cold it gets with exceptions. The oil is not a concern, neither is manual or auto defrost. Refrigeration units that are required to operate in cold temperatures, say below 30 degrees F. have crankcase heaters on them to heat the oil which keeps freon moving out of the oil and the bottom of the compressor. Otherwise when the compressor starts the cold freon will we sucked out of the bottom of the compress with a large quantity of oil which can destroy the compressor. Another item used for cold weather application is a fan control sensor which keeps the condensing temperature up or the unit will again remove the oil from the crankcase. It may work fine for a quite a while, but it will fail in continuously cold temperatures.
Nov 22, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Samsung Rf217acbp Black 20 Cu.ft. 33" French 3 Door Refrigerator Logo
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
