Question about Krups Gusto 880-42 Espresso Machine
Need to find a KRUPS XP5220 filter holder - Krups Gusto 880-42 Espresso Machine
3 Suggested Answers
SOURCE: I dropped the filter holder last week, and now
saifdonkey@yahoo.com i mean son libya leader ابن قائد ليبيا سيف الحمار
Posted on Nov 03, 2009
reyjoshua07
  • 1157 Answers
SOURCE: Regarding a Krups xp5220 coffe-maker
Hi 3_141644,
If you want to replace the steam wand of your Krups xp5220 coffe-maker, please follow the steps below.
1. Remove the nozzle. In order to remove the nozzle you have to pull the slip ring down and pull straight off. It will requires a bit of force.
2. Please be careful, if you pry one of the 3 tabs which are in a vulnerable position they will break and then the steam wand may not stay on under pressure.
--> Once you understand how to properly remove and install the nozzle, it's not a problem.
Note: the steam wand is extremely fragile, please look at it's sideways and it may break.
Hope it helps.
Thank you for using FixYa.
Posted on Apr 19, 2011
How do your repair the Cover-Filter Holder for a Krups XP2280? Part # MS-622631.
Don't both sides make coffee? One brews into a large glass beaker the other into a cup.
Nov 16, 2016 | Krups Coffee Makers & Espresso Machines
Need to open front panel to check defective switch on front panel
there is 4 skruws from the front you will seen them remove the filter holder and you will see on the age if it and you have some at the back then you lift up slowly from the front upwords
Oct 10, 2015 | Krups XP5220 Espresso Machine, Precise...
How do i prime an xp5220
You should be really need to prime it all. Check where the water reservoir is installed for blockages or dirt. There should be O-rings present, these may have become dislodged.
Feb 08, 2014 | Krups XP5220 Espresso Machine & Coffee...
Pump may be broke
Remove the frother nozzle: if its the early type with three hooks, slide the frother body down before trying to remove it. Disassemble the frother and clean the three holes in the end. If the holes are blocked, the steam can't escape. If it's not pushing hot water through the coffee holder, pull out the water reservoir, and remove and clean the grid plate assembly where the coffee holder clips in.
I have krups xp 5220 and it doesn't make foam. There is just black caffe. please help me. thank you :)
Three things to try:
1. Try a finer ground coffee
2. Use fresh coffee not old coffee
3. Make sure the coffee is pressed down well in the filter holder
For the machine, make sure it has been descaled correctly.
Hope that helps.
Nov 03, 2010 | Krups XP5220 Espresso Coffee Maker
Can the lid on the Krups Aroma coffeee pot be taken apart to clean?
Yes!!! by the word lid do you mean the top or swing out filter holder? If you use small flat screwdriver you can expand plastic at hinge enough to pull apart!
Mar 17, 2009 | Krups Aroma Control 229 Coffee Maker
Krups Gusto 880-42 Espresso Machine Logo
20 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
