Atcatel one touch 297a network key Midi:0136510000445390
    New Friend:
Don't know
Posted on Oct 17, 2013
My text messages not coming in on my atcatel one touch
If your text messages are not coming through there are only a couple solutions.
1) have you recently changed you SIM card?
2) have you recently changed your provider
3) have you recently changed your number?
If yes then call ur cell phone provider for help.
If no, power down ur phone and take out your battery for 30 seconds. While the battery is out hold the power button down. Put the battery back in and ask a friend to text you or use another phone to text yourself. If they don't come through.,the next step would be to do a factory restore of your phone,make sure to back up your data, pictures, videos, files, apps, ext.
If this doesn't work, call ur cell provider.
Apr 17, 2015 | One Touch Cell Phones
Why are the Keys on my axiom pro 61 not sending MIDI messages?
Does your keyboard have a "MIDI OUT" port? If yes, then
there is a selection to choose between USB or MIDI OUT port.
For my M-AUDIO oxygen 61 (silver), I must press the [Advanced] button then Note F3 on the music keys manual to toggle the MIDI-OUT.
If set to INT, it will not sent via USB. If set to USB it will not send via MIDI-OUT port. To use MIDI-OUT port I need external 12V DC adapter.
Jul 29, 2014 | M-Audio Axiom Pro 61 Advanced 61-Key USB...
MIDI Basics
MIDI is the language used by electronic instruments to tell each other what to play. When you press a key on a musical keyboard this keyboard will send a MIDI message to a computer or a musical instrument connected. The message says something like: start playing this note at this volume. When you stop pressing the key a new message is sent which says: stop playing this note.
MIDI messages can be transmitted using MIDI cables or USB. Old instruments had MIDI ports (round with five connectors inside) so a computer had to have a MIDI interface. Nowadays it's almost all done with usb.
The important thing to remember is that a MIDI message (and a MIDI cable) are just an instruction to play, they don't contain sound. The sound you hear when you press a key comes from the computer or the instrument connected to the keyboard, not from the plastic key you have pressed.
There is a lot more to say, but I would suggest you check wikipedia first and then come back with more specific questions.
Nov 09, 2012 | Yamaha PSR-E433 61-key Keyboard, with...
I get random unwanted midi notes triggering while I plug my dd-55 into my emu x-midi 2x2 with my Reaper DAW. I don't know if this is a problem with the emu or the dd-55 itself, but it doesn't...
Check that you don't have MIDI echo on in the DAW. If the MIDI data is echoed, it MAY be merging with the outgoing and when MIDI signals are merged in pieces instead of whole messages the data is corrupted. If you can look at the data stream with software, you should be able to spot the problem. Another problem might be excessive latency of the recording software. Make sure you do not have antivirus or antispyware programs running or network running. The Roland will spill data at much less rate and while the dd55 may overrun the DAW the Roland might not be able to. The key to the problem is to analyze the MIDI data stream that is being recorded.
Sep 05, 2011 | Yamaha DD55 7 Pad General MIDI Digital...
I have same problem. I have recorded my performance on keyboard (PSR I425) when i transfered it to PC it's in .bup format. and the file is not getting played on PC. how should i solve it?
Transfer the data in MIDI format. The BUP format is a proprietary format to the keyboard and can ONLY be played by the keyboard. Either dump the data as MIDI format or using a MIDI interface send it to the PC or lastly, capture the audio using an audio interface on the PC.
Nov 26, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
I have yamaha PSR-i425 keyboard.can i conect it with my pc to play midi files stored in computer memory?
Yes. You will need to have a MIDI interface on your OC and also select in the sounds control panel of windows that you are using the external synth. The MIDI will expect the PSR to respond to the "general MIDI" assignments.
Sep 08, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
I have PSR-i425 Keyboard from Yamaha. I stored the music piece played by my in the keyboard memory. After that I downloaded the stored file to my PC The file is in this format: 06PK61.BUP. Kindly tell me...
The BUP is an archiving format proprietary to the Yamaha apparently containg styles as well as note data and conversion is really not easy.
If you can get the instrument itself to spill out MIDI and use a MIDI interface and software to capture it on the PC is the best plan.
Once it is in SMF format you can play it on the PC.
Jun 25, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
How to open 3 demo pieces of Technics SX-PC10 Digital Piano?
Usually you just select which demo BEFORE starting the demo.
If you are meaning to try to DOWNLOAD via MIDI or other those demo pieces that is USUALLY not possible as the pieces are stored in a ROM which is inaccessible via MIDI or USB.
They OFTEN don''t even send them out on the MIDI port when playing them.
Apr 30, 2010 | Yamaha NP 30 76 Key Lightweight Digital...
My mr61 keyboard does not respond to velocity or aftertouch. Is there a simple fix to restore touch sesitivity? also there are a couple of keys that do not work.
This is a rack module. Are you sure you are sending the MIDI velocity and aftertouch as the correct MIDI format?
Jan 06, 2010 | Music
Open Questions:
6 Ways Cloud Computing Helps Businesses Save Time and Money You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Online Cloud Backup services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Computer Data Backup Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Business Server Data Backup Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network. DataAlign has been designed with you in mind. You wouldn't require any technical skill or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
Jul 23, 2018 | Best Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
