Question about Ricoh SP 4210N Laser Printer
How to reset the black pcu counter - Ricoh SP 4210N Laser Printer
Looking for keystroke sequence to reset pcu and dev counter on a konica minolta Di3510f. I am able to access tech rep mode but stuck after that
Enter in the service mode,select counter,select special parts counter ,reset to 0 P/c and I/C counter and in Function mode select F8 only you have change the developer,if not changed not use the F8 because damaged the copy quality.
Mar 20, 2013 | Konica Minolta Office Equipment & Supplies
How to reset pcu . Explaim this problem Clearly .mpc 2030
It's a RICOH MPC2030? Why do you need to reset the pcu counter? Or the maintenance counter? I repair ricoh from 10 years so i think i can help you, can you explain me better the problem what you have?
Feb 06, 2013 | Office Equipment & Supplies
I just replaced my black cartridge and my Aficio 41000 still says replace blank pcu - why?
The life counter of the black pcu has run out. It had nothing to do with replacing the toner. The replace pcu message comes on at around 50k on this model I think.
Apr 26, 2010 | Ricoh Aficio 1224C Black and White Copier
Ricoh Aficio AP3800c--message to replace black PCU, have done same and still get message?
This must be done before drum is replaced.
Resets counter.
Start the SP mode and execute the
New Unit Set:
• PCU: SP5-999-001 ∼ 004
Feb 03, 2010 | Ricoh Aficio AP3800C Laser Printer
Resetting the photoconductor unit
After replacing the PCU, you can clear the counter by going to Clear mode, 107, push and hold Clear/stop. Screen should change. Push Copier, 7804 should clear drum counter.
Jun 28, 2009 | Ricoh Aficio 450 Copier
Sharp ar 405 u2-11 error
Content Counter check sum error (EEPROM)
Detail Checksum error in counter data area
Cause EEPROM defective
Control circuit hung up due to noise
Defective EEPROM access circuit on
PCU PWB
Check Check EEPROM for proper set-up
and To prevent the erasure of counter data
remedy and adjustment values, write down the
counter data and adjustment values by
simulation. (If there is a printer option,
execute SIM23-1 and note counter
data/adjustment values.)
Clear U2 trouble with SIM16.
Replace PCU PWB.
May 22, 2009 | Sharp AR-405 Printer
Do I really Have to Replace the Photoconductor Unit
no, im with you let it go bad first! when it starts to go bad the print will go bad
  1. Close the top cover and carry out the following instructions to reset the Maintenance Counter.
  2. Press the [Menu] key on the Operation Panel.
  3. Scroll to display [Menu: Maintenance].
  4. Press the [Enter] key.
  5. Scroll to display [Maint. Reset: PCU] and press the [Enter] key.
  6. Press the [Enter] key when [PCU Press # to Start] is displayed.
  7. Press the [Enter] key when [Counter is Reset] is displayed.
  8. The Maintenance Counter is now reset - the display will return to the Maintenance menu after about 2 seconds.
  9. Press the [Online] key and check that [Ready] is displayed.
Dec 20, 2007 | Office Equipment & Supplies
The PCU Reset procedure needed
switch the machine off at the switch hold down online and escape while switching on the switch , hold the buttons till you see service mode on screen , you need to go to engine , then drum , there you will find the setting to reset the pcu , or under data log is a function pm counter clear if it is giving you replace pcu on the screen
Nov 01, 2007 | Ricoh Aficio AP3800C Laser Printer
Gettin a Error: replace Black PCU.
Hi yes you can fix it yourself it is just a warning that says the black pcu is almost warn out , but if the quality is still good you can clear the message is the sp modes by holding down online and escape whilst switching on the machine , under the menu "engine " is a sub menu called data log enter it and execute pm counter reset
hope this helps
Oct 15, 2007 | Ricoh CL3000E Laser Printer
B8300 toner error
From Oki's site: Symptom: The toner counter did not clear after installing a new toner cartridge. Cause: The printer was not powered off when the new toner cartridge was installed, Therefore the counter did not cleared. Resolution: 1. Enter the PCU Diagnostic Mode, By turning off the printer and holding down the MENU and OK buttons on power up. (Release the buttons once you're in the PCU DIAG MODE) 2. Press the MENU button 14 times until the operator panel reads " Counter Display " 3. Press the MENU button and the BACK/C button at the same time, This will put the printer into the Feed Counter Clear Mode (Release the buttons once you're in the Feed Counter Clear Mode) 4. Press the up arrow 5 times until the operator reads " Toner Counter Clear " 5. Press the OK button, The operator panel will now display " Toner no " 6. Press the up arrow once and the operator panel will display " Toner yes". Now press the OK button and the green data light will flash to indicate that the clear process is complete 7. To exit the PCU Diagnostic Mode, By turn the printer off and then back on this will allow you to exit the PCU Diagnostic Mode Hope that helps. If it does not please let me know Ed
Jun 12, 2007 | OKI B8300 Laser Printer
Ricoh SP 4210N Laser Printer Logo
27 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
