Question about Philips MCD702 Shelf System
Control cable - Philips MCD702 Shelf System
How to access/replace the vent selector(defroster) ?
buy one
and install it.
it has clamps remove them or unsnap them and .....
access? its in the dash.
the FSM covers all HVAC work , you can get that and read it
or hope that ALLDATA.com covers R&R for the cables.
but will cover access. (huge job on some cars)
working on the dash with out and FSM invites more broken parts.
plastics.
hidden screws and such , and how to get to them are covered in the book.
here is the control panel, pasted
Removal & Installation
  1. Remove the upper console panel.
  2. Remove the instrument cluster finish panel
  3. Release the 2 fitting claws and pull out the heater control assembly.
  4. Using a screwdriver, open the claw of the cable clamp and disconnect the defroster damper control cable. NOTE Be careful not to bend the cable wire. If the cable wire bends, the heater control assembly operationally becomes worse.
  5. Using a screwdriver, open the claw of the cable clamp and disconnect the air mix damper control cable.
  6. Disconnect the connector, remove the heater control assembly. 42050_coro_g0008.gif Removal and installation of the control panel
To install:
  1. Install the inner cable end of the air mix damper control cable to the heater control lever.
  2. Install the outer cable of the air mix damper control cable to the cable clamp. NOTE Be careful not to bend the cable wire. If the cable wire bends, the heater control assembly operationally becomes worse.
  3. Operating the heater control knob and check that it properly stops at both ends of MAX. COOL and MAX. HOT and no recoil is identified.
  4. Check that the outer cable should not be disengaged (moved) from the heater control assembly when the cable is pulled.
  5. Install the inner cable end of the defroster damper control cable to the heater control lever.
  6. Install the outer cable of the defroster damper control cable to the cable clamp.
  7. Operating the heater control knob and check that it properly stops at both ends of FACE and DEF and no recoil is identified.
  8. Check that the outer cable should not be disengaged (moved) from the heater control assembly when the cable is pulled.
  9. Connect the connector, install the heater control assembly.
  10. Install the instrument cluster finish panel
  11. Install the upper console panel.
Dec 13, 2013 | 2005 Toyota Corolla
Replacing shift cable, disassemble of control unit, Quicksilver 3000 control
Un Bolt controler From Side Of Boat
Remove Lower Panel 2 Screws
Undo 8 mm Nut Securing Front Of Cable Remove Cable .
Fit New Cable Re Attach Front Of Cable Slide Cable Back Into Controller Re Fit Lower Cover Re Attach To Boat
Good Luck
Mar 17, 2013 | Cars & Trucks
Interior blower only blows up to warm on 1997 A4 2.7ltr
Check the blend door cable for proper attachment to the control panel and to the blend door. Try opening the door manually to see the you can get hot air out. If not, the door may be broken inside the heater box. If yes, correct/adjust the cable attachment for proper operation.
REMOVAL & INSTALLATION
1990-97 Passat Models
Install the cable ends marked with a white or blue band to the control head assembly. The cables must be attached to the control head before connection to the system air flaps.
  1. Remove the climate control head from the center dash assembly to access the control head cable ends.
  2. Remove the lower dash panels as necessary to access the cable lever arms.
  3. Attach the airflow distribution cable (cable 2) to the airflow distribution knob's lower control lever.
This cable can be identified as follows:
Operates the mode/central air flap Cable has a black sleeve and is 25.0 inches (634 mm) long Cable is marked with a white band
  1. Press the cable's sleeve against the control head stop and install the retaining clip.
  2. Attach the temperature control/air blend cable (cable 3) to the air temperature knob's control lever.
Operates the temperature control/air blend cable air flap Cable has a blue sleeve and is 21.0 inches (535 mm) long Cable is marked with a white band
  2. Attach the airflow distribution cable (cable 1) to the airflow distribution knob's upper control lever.
Operates the footwell/defroster air flap Cable has a black sleeve and is 37.5 inches (954 mm) long Cable is marked with a blue band
  1. Install the cable such that the blue band is over the retaining clip mount and install the retaining clip directly over the blue band.
  2. Install the climate control head.
  3. Set the air flow distribution knob to defrost.
  4. Connect the longest airflow cable (cable 1) to the footwell/defroster flap lever on the heater's air box.
  5. Press and hold the flap's lever toward the retaining clamp perch and install the cable retaining clip.
  6. Set the airflow distribution knob to the Vent position.
  7. Connect the short airflow cable (cable 2) to the central/mode flap's lever.
  8. Pull and hold the mode flap's lever away from the retaining clamp perch and install the cable retaining clip. Check the operation of both air flaps making sure they can be heard contacting their stops.
  9. Set the temperature control knob to full cold.
  10. Connect the blue-sleeved cable (cable 3) to the air blend/temperature flap's lever.
  11. Pull and hold the mode flap's lever away from the retaining clamp perch and install the cable retaining clip. Check the operation of the air blend/temperature flap making sure it can be heard contacting the stops.
Fig. Side view of the control head and cable location. 1. Footwell/defrost flap cable-2. Air distribution cable-3. Temperature control flap cable
Fig. Temperature flap cable location and adjustment
Nov 24, 2011 | 1998 Audi A4
How can i control my cable box through my toshiba remote control? I need the code and step by step procedure. Can send me please.
Tv remotes are only for control the tvs only sorry.Ur cable box have it own remote,used the cable remote read ur cable box owner manual or call ur cable company for help by putting in the Toshiba remote codes for the cable remote to used.
Apr 22, 2011 | Toshiba Ct-90302 Remote Control
How do I take the dash apart to change the blower switch on a 2001 Mustang? I can not find a diagram or maunual that shows how to do this, can you recomend?
  1. Disconnect the negative battery cable.
  2. Remove the control panel assembly from the instrument panel.
    A special tool, such as the one shown, is necessary to disengage the temperature control cable from the back of the control panel
    Temperature control cable component identification
  3. Carefully lift the lock tab to detach the temperature cable from the control door shaft.
  4. Note the cable routing, then remove the cable from the vehicle.
To install:
  1. Route the cable behind the instrument panel, then engage the alignment pins and attach the temperature cable to the control door shaft until the lock tab snaps into the groove on the shaft.
  2. If necessary, install the instrument panel.
  3. Engage the cable end with the cable actuator on the control assembly. Install the control assembly in the instrument panel.
  4. Connect the negative battery cable and check the system for proper operation.
  2. Remove the snap-in trim molding in the center console to expose the four control assembly attaching screws. Remove the four screws attaching the control assembly to the instrument panel.
  3. Roll the control panel out of the opening in the console.
    Exploded view of the heater control panel mounting
    Click to Enlarge
  4. Detach the temperature control cable from the control panel by using Ford Temperature Cable Disconnect tool T94P-18532-A, or equivalent, to release the side locking tube, and a small flat-bladed prytool to release the top locking tab. Pull the temperature cable away from the heater control.
  5. Remove the two mounting nuts, then separate the vacuum hose and wiring harness connectors from the back of the damper door switch.
  6. Detach the wiring harness connectors from the back of the blower motor switch and the light bulbs.
  7. Remove the control panel from the center console.
    To remove the control panel, first remove the trim cover and remove the panel mounting screws . . .
    . . . then disengage the locking tabs on the temperature control cable . . .
    . . . and detach the control cable. Detach all wiring harness connectors and remove the panel
To install:
  1. Position the temperature cable at the midpoint of its travel, directly between the H and C markings. Position the temperature control knob at the midpoint of its range, then connect the temperature cable to the geared arm on the blower motor wheel. Rotate the temperature control knob from maximum cold to maximum warm to verify proper range of motion.
    Prior to installing the temperature control cable, turn the control knob and the cable indicator to the mid-points of their ranges
    Click to Enlarge
  2. Install the electrical connector at the following locations: blower switch, control assembly illumination bulbs and damper door switch.
  3. Install the vacuum harness connector for the function selector knob and tighten the mounting nuts until snug.
  4. Roll the control assembly into position against the instrument panel and install the four attaching screws until snug.
  5. Snap the console trim molding into position, connect the negative battery cable and check the system for proper operation
Jan 16, 2011 | 2001 Ford Mustang
Ford escort van heater not giving any heat bled system all pipes nice and hot but no heat blower works fine.
could be the control fal is broken on this model its a cable and one the outer cable ends has come adrift so when you move the control its not opening the flap on top of the heater matrix
Nov 17, 2010 | 1998 Ford Escort
The heater control knob will not turn all the way to either hot (right) or cold (left) so therefore I only get medium warm or medium cold. I assume the knob moves a cable but I cannot see it or remove the...
Cable is probably kinked or slipped adjustment. There are 2 cables connected to the knob. One move the blend door in the heater box to make the air flow thru the heater core, and the other cable opens a valve in the heater hose (engine compartment) to let the hot engine water into the heater core. Check both cables for kinks and fix and kinks. It is still doesn't work, first disconnect both cables at the blend door and valve and check the door and the valve for proper operation (can you open and close them by hand?--if not, these must be repaired or replaced), then, if good, adjust the cables according to this procedure from autozone.com:
CONTROL CABLE Adjustment
  1. Under the hood, open the clamp and disconnect the heater control valve cable from the arm.
  2. Under the dash, detach the air mix control cable from the clamp. Pull the cable from the control arm.
  3. Position the temperature control at MAX COOL.
  4. Turn the air mix control arm counterclockwise until it stops.
  5. Attach the air mix control cable to the arm.
  6. Snap the air mix cable hook into the cable clamp.
  7. Under the hood, turn the control valve to the fully closed position.
  8. Install the heater valve cable to the arm.
  9. Gently pull on the cable housing to remove any slack.
  10. Insert the cable into the clamp.
Oct 20, 2010 | 1996 Honda Accord
Cruise control not working when it was it seammed to make the motor run very ruff when i disengaged it by using brake pedal
If the cruise control makes the engine seem to run very rough until disengaging it, there could be a problem with the engine itself. As, most cruise control systems just pull on the throttle cable to maintain speed on the highway based on setting the speed with the button.
So, I would look into the engine maybe having an issue with spark plugs, or wires, or another tuneup or mechanical issue.
Cruise Control Cable Removal & Installation To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • The cable from the throttle lever and the accelerator control cable bracket gm_mv_ven_cruisecable.gif
    • The cable from the module by rotating the cable counter clockwise at the module
    • The cable from the module band
To Install:
NOTE: Ensure that the module strap is not twisted during cable installation
  1. Install or connect the following:
    • The cable to the module band
    • The cable to the throttle lever and the accelerator control cable bracket
  2. Adjust the cruise control cable.
prev.gif next.gif Cruise Control Module Removal & Installation To Remove:
  2. Remove or disconnect the following: gm_mv_ven_cruisecable.gif
    • The mounting bracket bolt from the cruise control module
    • The cruise control module from the mounting bracket
To Install:
    • The cruise control module to the mounting bracket
    • The mounting bracket bolt to the cruise control module
      1. Torque to 53 inch lbs.(6 Nm)
    • The electrical connector to the module
    • The cruise control cable to the module
Oct 11, 2010 | 1999 Pontiac Montana
When i turn on heater or fan engine revs over 3000 rpm
Idle Air Control Valve Pintle may be bad If you disconnect the IAC and the problem ceases it can point to this being the problem.: Removal & Installation 3.5L Engine To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove the fuel injector sight shield.
  3. Drain the cooling system.
  4. Remove or disconnect the following:
    • The air cleaner intake duct. Figure of IAC and TPS electrical connectors disconnected. aurora_g1.gif
    • The idle air control (IAC) valve and throttle position (TP) sensor electrical connectors. Figure of cruise control and throttle control cables removed from throttle lever. aurora_g2.gif
    • The cruise control cable and throttle control cable from the throttle body lever.
    • The fuel pressure regulator vacuum hose, positive crankcase ventilation (PCV) hose and the throttle body vacuum port hose.
    • The throttle body coolant hoses.
    • The throttle control cable bracket, leaving the throttle and cruise cables connected.
    • The upper nut holding the throttle body to the intake manifold.
    • The throttle body assembly.
  5. Clean the gasket mating surfaces.
To Install:
  1. Install a new gasket and new studs if necessary.
  2. Install or connect the following:
    • Start the top nut by hand.
    • Position the throttle control cable bracket and hand start the retaining nuts and bolt.
    • Torque the three throttle body retaining nuts to 89 in.lbs. (10 Nm). And the bracket retaining bolt to 115 in.lbs. (13 Nm).
    • The throttle body vacuum port hose, PCV valve hose and the fuel pressure regulator hose.
    • The throttle control and cruise control cables to the throttle body lever.
    • The IAC valve and TP sensor electrical connectors.
    • The air intake duct.
  3. Refill the cooling system.
  4. Install the fuel injector sight shield.
4.0L Engine To Remove:
  2. Relieve the fuel system pressure.
  3. Remove or disconnect the following:
    • Negative battery cable.
    • The Mass Air Flow (MAF) sensor electrical connector.
    • The PCV valve fresh air tube. Figure of cruise control cable removed from throttle cable bracket. aurora_g3.gif
    • The cruise control cable and throttle control cable from the bracket.
    • The cruise control cable and throttle control cable from throttle body lever. Figure of IAC valve and TPS connectors removed. aurora_g4.gif
    • The idle air control (IAC) valve and throttle position (TP) sensor electrical connectors. Figure of fuel lines removed from retainer on throttle cable bracket. aurora_g5.gif
    • The fuel feed and return lines from the retainer on the throttle control cable bracket.
    • The transaxle shift cable clip from the throttle control cable bracket. Figure of throttle body removed from water crossover. aurora_g6.gif
    • The throttle body from the water crossover.
To Install:
NOTE: The Mass Air Flow (MAF) sensor inlet and the outlet of the air cleaner assembly must line up when installed. Misalignment may cause MIL illumination or driveability concerns.
  1. Install or connect the following.
    • The throttle body to the water crossover. Torque the bolts to 106 in.lbs. (12 Nm).
    • The throttle and cruise control cables to the throttle body lever.
    • The throttle and cruise control cables to the throttle control cable bracket. The transaxle shift cable clip to the throttle control cable bracket.
    • The fuel feed and return line retainer to the throttle control cable bracket.
    • The MAF sensor electrical connector.
    • The air cleaner intake duct clamp. Torque the clamp to 27 in.lbs. (3Nm).
    • The fuel injector sight shield. Torque the nuts to 20 in.lbs. (2.3 Nm).
  2. Install the negative battery cable.
  3. Pressurize the fuel system and verify no leaks.
Oct 07, 2010 | 2001 Oldsmobile Alero
Hello i have a 2004 cavalier and it will not go into gear can you help me?
This Is Park Lock Cable Failure here is the Replacment Procedure
Park Lock Cable Replacement
Removal Procedure
  1. Remove the console.
  2. Remove the knee bolster.
  3. Loosen the lower steering column bracket bolts.
  4. Lower the steering column.
  5. Place the transmission shift lever in the PARK position. Important: Do not proceed to the next step with the key in any position other than the RUN position.
  6. Turn the ignition key to the RUN position.
  7. Insert a screwdriver blade into the slot provided in the ignition switch inhibitor.
  8. Depress the cable latch. Pull the control cable from the inhibitor.
  1. Push the cable connector lock button at the shifter base to the up position.
  2. Unsnap the cable from the park/lock lever pin.
  3. Depress the two cable latches. Remove the control cable latches from the automatic transmission control.
  4. Remove the control cable clips.
Installation Procedure
Important: When installing a new park/lock cable, keep the shipping cover gauge attached until you are instructed to detach it. The shipping cover gauge will aid in the proper positioning of the cable.
  1. Ensure that the cable lock button is in the up position. Place the shift lever in the PARK position.
  2. Snap the control cable connector into the automatic transmission control.
  3. Place the ignition key in the RUN position. Important: Do not insert the cable with the key in any position other than the RUN position.
  1. Snap the control cable into the inhibitor housing until the snap lock is seated.
  2. Remove the shipping cover gauge.
  3. Turn the key to the LOCK position.
  1. Snap the control cable end onto the shift park/lock lever pin.
  2. Push the cable connector hose forward in order to remove any slack.
  3. With no load applied to the connector nose, snap the cable connector lock button down. Important: Inspect for proper operation of the park/lock control cable before installing the steering column to the instrument panel.
  4. Raise and connect the steering column.
  5. Tighten the lower steering column bracket bolts.
  6. Install the knee bolster.
Apr 08, 2010 | 2004 Chevrolet Cavalier
Philips MCD702 Shelf System Logo
26 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
