Question about Yamaha RX-V870 Receiver
Blank display Hi, I have a yamaha model RX-V870, it plays ok and as it seems every thing works fine except that the display is blank!remote works, the tuner works etc, when connected CD player worked Please can some one help me solve this problem?
  • Anonymous Nov 17, 2007
    I have the same problem and a friend of mine had the same problem with his. It cost about $200 to have Yamaha fix his.
  • seansean1 Dec 13, 2007
    My amp works perfectly when i set it to tuner but when i set it to another source the left speaker works fine but the centre an right speakers only have the radio still running quietly on them. this seems very weird to me
I replaced it with a 6V lamp. Radio Shack part# 272-1140. It cost $1.49.
Posted on Dec 31, 2008
I have one rx-v870 TopArt series. Vry good amp. The display unit is fitted with an Incandesant globe and these burn out easily. These are cheap, you'll also need some heatshrink and a half decent soldering iron. I replaced all my orange leds with blue ones and instead of a incandecnt globe i bought a 1 watt luxeon blue led (very bright) and jammed it into the cavity where the globe once was. if the light still works, check the interconnection between the mainboard and the display unit board(1 loom), make sure ur 870s off when you do this. if this doesn't solve the prob. hmm dunno.
Posted on Oct 21, 2007
SOURCE:
Yamaha rxv 870 - volume does not work from remote(s)
hi i have the same problem. yamaha rx-v870 with a remote control that works perfectly except for the volume up/down. i pressed the buttons for a minute and applied some lemon gunk remover liquid and this helped for a very short period. i am wondering if the problem is with the little motor inside the receiver that rotates the volume knob itself, as opposed to an infrared problem on the transmitter/receiver.
Dec 24, 2012 | Yamaha RX-V870 Receiver
My 7 year old Yamaha RX-V870 receiver won't stay on. I press the power switch, the display lights up and after about three or four seconds, it turns off. Every time that I press the power switch the...
Get your service manual here:
Yamaha RX V870 Manuals
FIRST be SURE your speakers are connected! A loose wire can cause shutdowns as your Supply tries to protect your output transistors!
Your Yamaha also HAS a onboard DIAGNOSTIC feature but it won't do you much good now because your supply is going into emergency shutdown so quickly... see page 15.
Suspect a problem in your Power Supply.
*** WITH THE POWER DISCONNECTED ***
Inspect the electrolytic caps for leakage AND be sure the tops are flat and not bubbled.
Find your power supply on pages 46/47/48. It is VERY extensive and has MANY possible suspects. NOT for the weak of heart!
Anthony
Feb 04, 2018 | Yamaha RX-V870 Receiver
THE FRONT PANEL DISPLAY IS BLANK. HAVE I DONE
Perhaps, the manual mentions a Dimmer setting under the Display Set Menu but doesn't specify how dark it can get. Give it a try.
Dec 26, 2009 | Yamaha RX-V1000 Receiver
My yamaha rx-v870 won't stay turned on more than a few seconds when i press the power button
protection is turned on,it is a seriously damaged,only service can fix it.Probably output transistors are defect,one or more
Nov 24, 2009 | Yamaha RX-V870 Receiver
Poor dialog sound of Yamaha RX-V363
I'm working on one right now. It seams that you are not selecting to correct program for the dialog. I would not use music enhancement on dialog content.
Jul 15, 2009 | Yamaha RX-V363 Receiver
NO INSTUCTION MANUAL. CAN NOT GET IT TO WORK AS A 2 CHANNEL AMP.
Click Yamaha Support and download required user manual of receiver to figure out to set it on 2 channel output.
Need further help, please intimate receiver model number.
Mar 18, 2009 | Yamaha RX-V870 Receiver
Yamaha Rx-V870
Aug 31, 2008 | Yamaha RX-V870 Receiver
Yamaha RX-V850 receiver
how can i hook a subwoofer into yamaha RX-V850
Dec 25, 2007 | Yamaha Audio Players & Recorders
722 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
