Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
I am trying to fix the light in our GE Profile refrigerator PFCS1PJXC. Bought new switches and replaced both of them with no result. I unfortunately did not pay attention to the wiring and think that maybe I did not put the switches in correctly. Do you know which wires goes to which connector on the switch. The old switches had a copper and a gold plug. The new ones do not.\, but the letters C and NC. The two wires coming out of the refrigerator are purple and brown. Also replaced LED light and still does not work.
MNTECH
  • 1543 Answers
SOURCE: Can I replace the LED light in my refrigerator?
I am not aware of any special tools or proceedues require to replace a LED light bulb, however,...... LED bulbs are generally very long life bulbs (read est. 10 year life, minimum). There is at least one manufacturer which has had some issues with their LED bulbs, and it is possible that GE may have outsourced some manufacturing, so we can not rule out a bad LED, however, it is actually more likely that you have a problem with the board or a switch, in which case the service tech will have to find out why your LED is not lighting.
Posted on Oct 16, 2009
  • 291 Answers
SOURCE: I have a ge profile fridge model # PDS22SHRBRSS needing help
Yes, you have to cut the wiring as the instructions stated. Not all the models have to have wiring cut, so read carefully to see if yours is one that needs to have the wiring cut. If it is not, then you have another problem, and you will have to let us know what the origional problem was before you replaced the board. If your model requires cutting, you may have damaged the main board by not doing this. Unplug the refer and follow the instructions carefully and test to see if it works. Good luck, Appliance Specialists.
Posted on Feb 04, 2010
bschilz
  • 2049 Answers
SOURCE: Water filter replacement on a GE Profile Refrigerator
You should NOT have to turn the water off to replace the filter. I have the same refrigerator and it closes water line itself when you turn the filter and drop it down. If yours flooded, I can only imagne the valve that the filter opens when in place got stuck.
There is a valve on the wall behind your refrigerator which can be shutoff.
The old filter should be heavier as it would still have water in it. Turn them over one by so water can drain out. The one with the smallest amount of water should be the new one. I always use a sharpie and mark the filter with the install date... that way ou know when to replace and which is the old one.
Posted on Jun 05, 2010
Testimonial: "Thanks for the quick reply. I've been mopping up and cleaning for the past two hours. Your solution makes perfect sense, as there was no mention of turning off the water. I'll move it out in the morning and turn the water to the frig off and then compare the two filters. Thanks for some good practical advice, a sharpie! Why didn't I think of that. Take care and thanks again. "
heatman101
  • 43501 Answers
SOURCE: Hi, our ge profile refrigerator is having temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 03, 2010
kevstu28
  • 17 Answers
SOURCE: Fridge light does not work.
Some appliances have electrical schematics on the back of the fridge, some are hidden behind rear cover. Wire,Switch or fuse..not much else it could be.
Posted on Aug 24, 2012
Refrigerator light does not work on ge profile
Check for voltage at the light receptacle, and then try to find the wire from the door switch. There should be a schematic on the back of the fridge. The switch can wear out after ten years.
Nov 22, 2013 | GE Refrigerators
We purchased four new GE Profile appliances in August 2008. I contacted them in October 2009 to advise them that the shelving on the side-by-side of the fridge are to narrow, and the shelving and food...
unfortunately noone can help unless it is a recall and the only way for that to happen is for a bunch of people to complain about the same thing on the same refrigerator and that is a longshot my advice write ge and express ur feelings about the product and sometimes they try to fix the problem but u cant go back to where you bought it they cant help you hope this was helpful
Jan 24, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ge refrigerator light switch needs replacement
no but where do I get a new switch part? Do you know what the part number is?
Jul 29, 2009 | GE GSS25LGM Side by Side Refrigerator
The ice will not dispense from GE profile sid by
The problem could be as simple as the door switch for the lights because the door switch when closed turns the control panel on. Or the problem may be the control board. WR55X129 Control Board Thanks, Sea Breeze
Jul 23, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge Profile Stainless Steel Refrigerator panel replacement
You can replace the doors but you will think you bought a new frig when you see what they cost. Most come as an assembly and are very expensive.
Eric
Jun 29, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Hi - I have a GE Profile Arctica model #PSC23NHMC. The fridge side works fine. The freezer side runs warm. I set the temp to recommended 0deg but it averages from 9deg to 16 deg. I had a local authorized...
unfortunately these systems are very expensive to repair and most shops will not service them if repairs cost more than a new unit. However you could make sure to keep the coils clean and adjust the thermostat to its coldest setting to get as much life from this one before buying another one. hope this helps and good luck.
May 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Refrigerator
If you have heating in the freshfood side there is only one possible. The light inside is staying on and allowing the bulb to heat up the refrigerator. To fix this you will need to replaced the door switch. To check simply unscrew the light bulbs and see if the problem goes away, or open the door and push on the door switch and see if the light is going off. Please let me know if this is not the problem and I will be happy to help. Please let me know if this did FixYa.
Mike
Sep 07, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Ice/water dispenser drips after using
afraid that sounds exactly like the problem.brand new fridge call who you bought it from they should fix it for free good luck hope this solves your problem
Aug 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
Dispensor not working
Check the electrical connector at the bottom of the freezer door , this can corrode and develop a poor connection
Apr 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
