Question about Whirlpool WTW4850XQ Washing Machines
My whirlpool model wtw4850xq is getting power from electrical outlet but washer itself is not powering up. i.e none of the lights or cycles are coming on.
  • 249 Answers
SOURCE: Whirlpool duet washer will not power on
wait for agent d,not go at it
Posted on Nov 21, 2007
  • 1122 Answers
SOURCE: whirlpool duet ht wouldn't start
remove the lower front panel,3 screws,side up and off,there is a tech sheet inside on the panel that should help you ,let me know what you find-mike
Posted on Oct 18, 2008
fridgetech
  • 473 Answers
SOURCE: Code F1 @ Whirlpool Duet Sport Washer
An F1 is almost always a defective main control board. Could try unplugging the unit for a few minutes and see if it will reset. The part # for the board is W10110072. Sears sells it for $119.46 http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WFW8300SW01&productCategoryId=0153200&brandId=1198&modelName=RESIDENTIAL-WASHER&diagramPageId=00003&componentDescription=CONTROL%20PANEL%20PARTS&documentId=W0607261&backToLink=Return%20to%20Sub%20Components%20list.
Posted on Dec 12, 2008
robocop
  • 90 Answers
SOURCE: whirlpool washer wont spin during high spin cycle
Try www.Repairclinic.com.
Posted on Jan 19, 2009
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Posted on Sep 30, 2009
My whirlpool was stuck on the Lock switch. we used he cancel button but now it wont run. the fill light come on but nothing happens. I have tried unplugging it to reset the panel, but nothing helps
Double check there is power at the outlet. If no power, check circuit breaker box. If the circuit breaker "pops" after resetting, you have a serious electrical problem in the washer or wireing to the washer. Consider the age of your washer, cost to find a lightly used working replacement, vs the cost for repair tech. Ask for an approximate repair visit cost.
Jan 20, 2015 | Whirlpool Washing Machines
My whirlpool Model wtw4850xq is not working. The spin light keeps flashing and it won't do anything when I push start other than lock the lid.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jan 24, 2013 | Whirlpool WTW4850XQ Washing Machines
Whirlpool dishwasher DU1015XTXBO Stopped working during cycle, acts like don't getting any power. Checked the plugin and it works. No lights or anything coming on the dishwasher. Its like it just
You may have power, however if a circuit board fails, all the power in the world won't start the washer. You need a technician to test the circuit for internal damage.
Feb 17, 2018 | Whirlpool Dishwashers
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
see this causes and fix it. God bless you
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
My washer wont drain
Drain hose clogged, or pump has quit or switch to turn on pump has quit.
My first idea hose clogged, unplug power, run a coat hanger through hose, May have to disconnect hose
I once found a baby sock in the pump itself.
Hope these ideas help.
Jul 08, 2012 | Whirlpool WTW4850XQ Washing Machines
Whirlpool duet steam washer has no power!
call whirlpool, sounds as if you have a faulty electronic control board( power supply board) warranty issue, non need for you to get involved with the repairing of this
Feb 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
No power
Hi lushman001
I'm Harvey the Master Plunber.
Your question is: your 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
First check all the breakers (or fuses).
Second check the electrical connections. If you're not a qualified electrician or service tech then call one. It"s under the unit behind the kickplate.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool WTW4850XQ Washing Machines Logo
26 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
