Question about Hoover Steam Vac Dual V w/ SpinScrub Vacuum
Cleaner not spraying/spinsrub attachment - Hoover Steam Vac Dual V w/ SpinScrub Vacuum
    New Friend:
  • 9 Answers
I had this problem with mine a while back. I opened up the unit and discovered that the trigger inside that you hold to spray was broken. I was not about to order a new trigger. I crazy glued it back to how it should be and closed up the unit. It worked fine and kept on working without problems. You must also check that nothing is clogged anywhere. or that a belt may have come lose somewhere. SO you must open up the unit carefully and remember where everything goes maybe takes snapshots of things as you do it so you can put it all back how it was originally.
please let me know if it helped. thanks!
Posted on Oct 16, 2013
Water wont spray from cleaner how to fix
Try cleaning the Flow Indicator Filter. Turn the Flow Indicator Cap counter-clockwise to remove, lift rotor and filter. Clean filter and replace in reverse order. Bissell's Consumer Care # 1-800-237-7691
Sep 16, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
My hoover unit is older, but I had constant problems with the sprayer unit. I recommend returning the unit for a refund or getting an Return Authorization number. They may send you another unit and then you can see if the new one works. If the sprayer does not work, sometimes you have to take the handle apart to discover how it's put together.
Oct 16, 2013 | Hoover Steam Vac Dual V w/ SpinScrub...
I have bissell cleaner 8920 it will not release the cleaning fluid and water
Please check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
If your machine continues to not spray, contact BISSELL Consumer Servies at...
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Aug 28, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell steam cleaner will not spray any water
Check to ensure there is liquid in the water tank and the formula bottle.
Note: This machine will spray with liquid in the Water tank only if the machine is set to the Water Rinse setting. On any other setting, you need to have liquid in the formula tank as well.
If no: add liquid to the Water tank and the Formula tank.
If yes: check each of the following....
-If everything is seated and attached properly, prime the machine by turning off the power, waiting one minute, and then turning the power back on and depressing the trigger on the handle.
- If priming the unit fails to fix the problem, remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
Jun 15, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover Steam Vac ; The vac is not dispensing cleaner/water. I suspect the tubing/path from tank holding the cleaner/water mixture is clogged. Is there an easy way to unclogg it. Are there are...
Just a quick clarification please. Will the water not spray in both the attachment hose as well as the floor part? Or does it spray in one or the other. You suspect that it may have a clogged line, is the machine doing anything in particular that makes you think a clog?
Thanks,
CJ
Apr 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Where can I get a hoover H3030 spinsrub 500 manual
This link should help:
http://www.fixya.com/search.aspx?cstm=0&_s=hoover+H3030+spinsrub+500+manual
Jim
Nov 29, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Hoover Steam Vac Dual V w/ SpinScrub Vacuum Logo
29 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
