Question about Frigidaire Refrigerators
EI23BC55IS1 This is a counter depth model Electrolux. Problem is the ice maker seems to be out of sync. When it is turned on at the dispenser, it goes into this movement from one side to the other and begins to make this noise like it can't engage or is stripped or something. I also cannot figure out their diagnostic well enough to go thru the test. I would like to get this working. Water does come thru the door.
duby1990
  • 370 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
jumptrout51
  • 3361 Answers
SOURCE: ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Posted on Mar 23, 2009
SOURCE: water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Posted on May 22, 2009
toolkits
  • 1099 Answers
SOURCE: water does not dispense thru my whirlpool
Take off the back panel in the freezer. 1/4" screws. Use a nut driver or ratchet and socket with an extension.
2. Behind the frost is the evaporator and the defrost heaters. One heater in the middle and one at the bottom. They are glass tubes. If you can see the bottom heater that is great. If not use a hair dryer and defrost only the very bottom to expose the lower heater only.
3. Now in the refrigerator section at the top where the controls are, take off the long plastic piece to expose the timer. The timer should be on the right hand side and have a little circle that is slotted. Get a flat screwdriver and turn that timer slowly clockwise just until it clicks and the refrigerator turns off. This will put it into defrost.
4. Now look at that heater that you exposed and see if it glows and gets hot. If it does, then the timer is bad.
5. If the heater doesn't come on then go ahead and defrost the rest of the evaporator with the hair dryer. This will take a little while. Don't poke at the evaporator!!!
6. Once totally defrosted look at both heaters. They should look like clear glass and see a silver coil running thru them. If they look discolored at all then the heaters are bad. The heaters come as a complete assembly with the defrost thermostat which clips onto the evaporator.
7. If the heaters look ok the only way to know for sure if they are bad is to check continuity with a meter on the plug at the end of their wiring harness. If you can check that then you can splice in a new defrost thermostat to solve the problem. However the best thing to do is replace the heaters and defrost thermostat . It is easy to install.
Follow these steps and this will solve your problem.
Hope this helpout......
Posted on Aug 04, 2010
Electrolux 23 cu ft refrigerator (EW23CS65GS1) Water dispenser problem. The water dispenser on the freezer door does not dispense water but the ice dispenser is working fine. I turned off my refrigerator...
the line is freezing up if you pull the bottom drawer out of ref side you will see a rolled up plastic line they use it as a resovoir tank so you get cold water if you have a vent in bottom left side close it i have put insulation over coil that fixed problem and turn down thermostat if milk and other stuff is freezing you will have to replace cold control
Oct 17, 2011 | KitchenAid 20.3 cu.ft. Counter-Depth...
My Whirlpool Gold Side by Side (counter depth) [model# GC3PHEXNS00] refrigerator stopped making ice. Water dispenser is still working, doesn't seem to be an obstruction in the line. What do I do?
Can be clogged water passing line or faulty water valve.But if you have already checked the water passing line and it seems clear, then its most probably the water valve.---------
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Sep 18, 2011 | Refrigerators
Ice maker dispenser door does not fully retract and close
There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Apr 24, 2010 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Ice dispenser will not dispens ice . light dims when pushed. ice maker works fine
It may be a good Idea to remove the ice bin, clean and dry ant the same time with bin removed see if while pushing the door light switch and the dispense ice control if the auger fork in the rear of the ice bin that normally turns the auger will rotate. Sometimes ice or water collects in the bin and locks the motor from turning and sometimes the motors go bad. Tell me your results, Thanks, Sea Breeze
Apr 23, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
The panel for the ice machine and water dispenser has shut off.
I have had the same probelm for over a year. It appears to be a problem in the touch pad w/ribbon connector which Electrolux refuse to accept responsibility for a faulty product. Model E230575DSS8
Apr 20, 2010 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Refrigerators Logo
41 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
