Question about Honda 4xled Cateye Black Mbx125f,xl 1251,nsr 250,vt 250 F2,cb1300 Turn Signal
My honda nsr 125 wont start, ive charged the batter, put in a new spark plug and changed the fuse that is near the battery it still wont turn over. If anyone could assist me i would appreciate it thanks.
Starter Motor Or Bad Wires
Posted on Nov 21, 2014
I put my Honda nsr 125 on a warm up after a warm up revved up then it cut &won't start back up , iknow the power valve servo has gone paid for one , has had new spark plug and air filter does spark
Hi Anonymous, and the usual suspects are:
1. Enrichner system plugged, not properly functioning or improperly operated.
2. Fuel overflow.
3. Restricted fuel supply.
4. Gas cap and or fuel tank not venting properly.
5. Plugged slow jet or passages.
6. Inlet system air leak.
For more information about your issue please visit the websites below. Good luck and have a nice day.
Honda NSR 125 won't start after cold Xmas
My Nsr 125 Wont Start Please Help
1988 1994 Honda NSR125 Service Manual Moto Data Project
http://www.vol-training.com/guides/honda-nsr-125-parts-manual.pdf
Honda nsr 125 Owners manual
Jan 02, 2016 | Honda Motorcycles
Honda NSR 125 R no spark
Hi, Anonymous and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Tilt sensor needs a reset.
11. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda Nsr 125 ignition problem no spark
No spark NSR 125f
https://drive.google.com/file/d/0B0RumHmTXc75ZDE2NDcwNDItYjdlMi00NDdmLTkwOTAtYzJiOWI5YWEyZDVj/view?hl=en_US
http://www.partsfish.com/page/oem-parts-for-honda
Honda NSR 150 SP Owner Manual
Feb 20, 2014 | Honda NSR 125 R Motorcycles
Bike wont start from the button
try pulling the choke when you start with a little gas, if i remember right the NSR has a carb & choke right?
Oct 25, 2012 | 2001 Honda NSR 125 R
Hi we have a 1976 Honda xl 125 can anyone help with the wiring? Trying to get spark, changed spark plug etc but wiring was all undone and we need to put it back together right for spark.
my 1976 honda125 cc xl wont start ive checked everything all the wires and spark plug and iget spark but no start what could it be?
Aug 19, 2011 | 1983 Honda XL 125 R
My honda nsr125 has got a weak spark and doesnt start
try a new spark plug, if the sparks plugs really black its probably fowled so wont work. That should fix your problem, if not pm me
Jul 11, 2010 | 2001 Honda NSR 125 R
I got weak spark so wont start got new plug
sounds like oxidization on your timing plate take it out and clean it with a peice of sand paper
Mar 18, 2010 | 2001 Honda NSR 125 R
1974 honda cb550 will not run?
• The first thing to do with ANY engine that has sat for any longer than a couple of months is to dump ALL the fuel in the tank and carb(s). ALL OF IT !! You'll want to refill with some high priced fuel that has fuel system cleaners (Like Chevron with Techron) not becasue you need high-test fuel, but because you need the cleaners. It's ether that or disassemble the carbs and clean out jets you can't find much less see. Your choice. The carb kits alone will cost you about $50 so a tank of high-test is looking pretty good, huh?
• Now the fact that you tried to crank the engine with old fuel has fouled the sparkplugs. All of them. Go buy all new sparkplugs.
Mar 21, 2009 | Honda CB 750 Motorcycles
Electric start dont work
You probably have a bad switch
First look to se if there are any fuses
also see if horn works
FIX for determining if starter works
to find out take jumper cables and put the red cable on the plus side of the battery and the black on the minus side of battery(ground)
Put the black lead(ground ) on the frame of the bike near starter and touch the red to the starter lead( you may have to peel back rubber boot over starter nut
when you touch the starter nut it will spark and should spin over
if it does then you need to remove the screw assembly that holds the starter button and remove and clean it out with electronic cleaner (you may have to replace it if so go to honda shop and order new one
Good luck
Jan 07, 2009 | 2008 Honda XR 125 L
Honda 4xled Cateye Black Mbx125f,xl 1251,nsr 250,vt 250 F2,cb1300 Turn Signal Logo
216 people viewed this question
Top Honda Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Honda Audio Player and Recorder Expert? Answer questions, earn points and help others
