Sony nicam 32 '' tv, about 15 years old, lost sound and picture, indicator light flashing
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
These flashes are fault indication and are called blinking codes. From the number of flashes occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV, and will make repair easy. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 17, 2013
silly girl
  • 513 Answers
SOURCE: 32" Sylvania SRT2232X
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Generically speaking anything in the horiz deflection, hv development area will cause a no pix symptom, also a problem in the signal processor section, video river and output section as the crt/socket assembly. I would also check the lopt transistor and probably the fuseable resistors around the lopt.
Posted on Mar 23, 2006
  • 1694 Answers
SOURCE: Sony KV-32S36 32" suddenly stopped working, no picture or sound
Check soldered in fuse R607 in power supply circuit =
If open, replace it and bad converter xistors ( 2SC4834)
Next, replace shorted horizontal output transistor w/ first Quality.
Solder any / all bad connects,esp.horiz drive to base of horiz.
o / p xistor. Soldering is critical or it will blow up again......
Posted on Nov 05, 2007
rey jr
  • 149 Answers
SOURCE: Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Posted on Jan 01, 2008
sharptech1
  • 29 Answers
SOURCE: tv lost picture and sound
TRY UNPLUGING SET FROM THE WALL FOR 1 MINUTE. PLUG SET BACK IN AND CHECK. IF PROBLEM PERSISTS TAKE IT TO A QUALFIED SERVICER. UNIT PROBABLY HAS A DEFECTIVE MAIN TOTAL ASSY.
Posted on Jan 12, 2009
  • 5 Answers
SOURCE: Standby/stereo light blinking no picture or sound
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!! My TV is 9 years old.
Posted on Apr 13, 2009
We have an 11 yer old sony wega KV-32FV15 We lost picture and sound. Power on swirtch activates the standby red light which just continues to blink (no Sound no Picture0 We know we have the power plug...
the tv is defected needs to be repaired..have a tech repair your tv.the problem is in the power supply or horizontal circuit.could be any thing in one on those circuit.good luck.
Aug 28, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sound but no picture; little red light showing instead of green led power indicator. less than two years old. original owner
Tv LED light indication"LAMP" is flashing or staying on?Yes 2 years old projection lamp and watches tv daily 4 or 5 hours a day?Yes,it is time to replaced the tv projection lamp.
Feb 18, 2011 | Mitsubishi WD 65837 65 in. HDTV
My sony grand wega 55 constantly will turn off picture and sound, green lamp light stays green and then after about 30 seconds the picture and sound return, it has the original bulb in the tv and is around...
The LED light "LAMP" indication stay on or flashes in this problems?Yes,the projection lamp is the causes and problems.Change the projection lamp,should solved the problems.
Jan 30, 2011 | Sony KDF-E55A20 55 in. LCD Television
Sony Trinitron TV now taking around 5 minutes for picture to appear (sound comes on instantly) Is it worth repair or should I cut losses and replace set?
How old is the TV?
Sony Trinitron sounds like it may be from the 1980's?
Some TV engineers can use a piece of equipment to do a "tube boost" but this is sometimes risky and can completely ruin the tube, but it's a risk you would have to take.
If the TV is over 15 years old, and has been used regularly, (like 4 hours every day or more) it seems likely that the tube has reached the end of life.
TV cathode ray tubes are like light bulbs...they do not last forever!
Nov 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
32" Sony Trinton Wega
Count the flashes and verify that the model is KV-32FS100. The flash count will indicate the circuit in which the problem was detected.
Thanks,
Dan
Oct 28, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 27 inch tv
this could be indicator of a bad bulb
May 20, 2008 | Televison & Video
No picture
need to know the model number of the tv and your sources. IE cable or antannae
Jan 13, 2008 | Sony KV-36FS100 36" TV
Tv wont turn on
How many times does the light flash, as there is a code that can give an indication as to what circuit is bad.
Jul 15, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony KV-32S40 32" TV problem
intermittent problems can usuall be liked to bad solder connections. And sony typically has some that will develop after a few years in the power supply. so check for bad sodler connections throught the main board & give a close look to the power supply & check you work after to make sure you have no shorted pins. good luck.
Dec 27, 2006 | Sony KV-32S40 32" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
