Question about Earthquake Supernova Mkv 15
My suwoofer works great when I first turn it on, but after about 30 minutes, the subwoofer fades away and goes silent. I feed it a line level signal from the Subwoofer Out connector on the back of my Pioneer Elite VSX-82TXS into the Line Level In connector on the subwoofer using a Blue Jeans Cable subwoofer cable (the problem persists with any cables I use). Not sure if this is a fault with my subwoofer's digital amp going to sleep after not sensing a signal from the receiver. I'm wondering if there's a way to send a stronger signal from the receiver to the sub or whether the fault lies in the subwoofer's digital amp. Thanks.
    Top Expert:
  • Earthquake Master
  • 22,801 Answers
You could switch the auto sense function off.
Posted on Apr 08, 2017
I have an RCA Tablet RCT6773W22 Android Version 4.4.2 The tablet is in Silent Mode.
I'm betting the volume switch is actually stuck and that the sound is just going down to "silent" the moment you release the "up" button. Does the sound get loud and just fade away? If so then that's probably it.
Feb 20, 2017 | RCA CA 7" Tablet with 4GB eory 28458515
What is wrong with Sharp Aquos LC-40C32U Picture
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site with the keyword "Line fault"
Jul 01, 2015 | Sharp Televison & Video
How to fix a Sharp Aquos LC-40C32U Picture
Replaced rusted brake lines but did not replace valve in rear lines will this cause brake fade in 1995 bonneville
BY brake fade away I take it that you mean the pedal goes to the floor after you taken your foot off the brakes. . The valve you left out is a compensator valve that proportions the pressure between front and back to stop rear brake lock up and side skidding. I think the problem is in the master cyl in that the nonreturn valve under the second piston is not working and hold residiual pressure in the rear lines (Assuming they are drum brakes). If not you will need to bleed the m/cyl by cracking the lines at it one ata time and emptying the cylinder of trapped air allowing a full charge of fluid every time you pump the brakes.
Mar 10, 2013 | Cars & Trucks
Basslink works for a few seconds after i turn on the stereo, then it fades away. The servo light is always on even when i disconnect the input line and turn the knobs to the min level. What could be wrong?
Hello, check the +15v and -15v on the Switching Power Supply Control board. If one or both are missing, it is probably Q117 for +15v and Q118 for -15v. If one is missing the limit comparator will rail to one side and cause the auto variable volume control to trip the servo protection.
Oct 02, 2010 | Infinity BASSLINK Car Subwoofer
Bought newer Denon reciever does not have speaker wire hookups only subwoofer outlet. will my PV 350 still work
What model Denon? The BA Sub is self-powered so it would accept a Line level Subwoofer feed as well as a speaker level feed (choose one only). Look for a Sub Out RCA jack.
You could look in the manual, which is at retrevo.com for free after you register.
Feb 22, 2010 | Boston Acoustics PV350 Subwoofer
Power Light, Pulsating Level Control, Blows Fuses
you may of caused a short in the connections or it got moisture why in storge if so the hole subwoofer is screwed
Jun 07, 2009 | Infinity BASSLINK Car Subwoofer
How to connect a mordaunt short ms907 subwoofer?
I guess you don't have the owner's manual for this?
You can get it here:
MS907 Subwoofer manual
The manual contains connection info.
Apr 27, 2009 | Mordaunt Short MS-308 Subwoofer
Car Audio Fade
sounds like you got a bad stereo. it happens. i've i had the same thing happen, but the volume went up instead of down. check all the wires and make SURE they are all hooked up right.
Jan 10, 2009 | 2000 Jaguar Vanden Plas
A/C and Heat fade after 30 minutes
I have the same problem in my Dodge. It most likely is the flapper valve that seperates the heater and the a/c. Very expensive to fix as they basically have to remove the dashboard to get to the part.
Nov 24, 2008 | 1996 Mercury Grand Marquis
Earthquake Supernova Mkv 15 Logo
29 people viewed this question
Top Earthquake Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Earthquake Audio Player and Recorder Expert? Answer questions, earn points and help others
