Question about Refrigerators
How to load or retrieve from flash drive connected.
How can I retrieve the data in my portable hard drive. It says I have to format the drive.
You didn't give much detail as to what happened, but I will suggest what I can. It sounds like you have a corrupted partition which may give you a chance to pull that data off the drive. After your data is saved delete the partition and reformat.
>First, if you have a USB cable connection, exchange the USB cable for another; I have seen bad cables do this.
>The second thing to try is to access your drive from outside Windows; use the link HERE to download Reatogo. Reatogo is a program that loads from your DVD drive and by-passes Windows and loads into memory. You can then "see" your hard drive and attempt to access your data. It has a Windows XP screen so it is easy to navigate around in. So, do this:
>Download from the above link
>Double-click the file and burn to a CD
>Make sure your BIOS is set to CD=1st Boot Device (the BIOS checks the cd for bootable files before loading Windows).
>Reboot with the CD in the DVD drive; this takes a long time to load so be patient. You may think the load has stalled, but it hasn't. When finished loading, you will see a duplicate of the Windows XP desktop, and your hard drive will be listed. Click on it, and if the hard drive is still working you will see your C:\ directory. Plug in a flash drive, locate your data, and drag & drop it onto the flash drive..
If that doesn't work, post back for additional things to try.
Wish you the best!
Oct 13, 2013 | Western Digital My Passport Essential...
Shot with Lexar Professional 233x 16 GB compact flash but can't retrieve images.
Connect compact flash to a Windows box. Check Disk with Repair and Fix.
Go to Start > Run (Search). Type cmd ENTER. From the Command Prompt type chkdsk x: /r/f ENTER. X being the drive letter.
Oct 24, 2012 | Lexar Electronics - Others
My cruzer 1.o gb flash drive when pluged into the computer doesnt load and the light doesn't even *** on
Looks like the flash drive is dead. Try plugging into a different USB port and also a different computer. IF all these didn't work, the drive is dead. Thanks.
Nov 04, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Can i retrieve lost/recently deleted data from my sd card in my cell? I hit the format option on accident and now im freaking out!! Please help! (If possible).
mcdevito75 here, Best Bet call your cell phone carrier, hopefully you had your info saved on both the phone and memory card.
Jul 07, 2010 | PNY 2GB microSD Memory Card
I have a 3.5" hard drives use for back up purposes. This is a very old HDD bought more than 5 yrs ago. What happen was I have not use it for almost a year and when I tried to retrieve some old data, the...
You maybe able to retrieve data from this hard drive by connecting it to an USB hard drive adapter. Then plug this adapter into a working computer's USB port. If the hard drive is OK then this computer will see the adapter as an external hard drive and you can open the folders and files and copy them to the computer's hard drive or to a USB flash drive.
Jan 22, 2010 | Maxtor Hard Drive
Dont want to format my flash drive
Sounds like all the connections are not . . connecting.
If the computer recognized the device but can't get the directory structure, it will ASSUME it's not formatted and suggest a format.
Check the connections to be shure the drive is fully inserted in the USB port, and that the connector is fully extended, and free of any obstacles.
Hope this helps.
Dec 11, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Flash drive problem
first check virus on ur flash drive then use recovery tool for retrieve ur data
Oct 20, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Flash Drive Crushed - Data Recovery
http://www.ontrackdatarecovery.com/
There is no way to retrieve data if your flash drive is broken but you can surely try it on other system and check.
But if it does not work then the only way to retrieve data ( if it is very important ) is to contact the website mentioned above and they will do it for you
Jun 08, 2008 | Computers & Internet
Retrieving information on a reformatted USB drive
Unfortunately when its been formatted all the data stored gets wiped off.
You could try searching on the net for data retrieval programs and see if any of them can help you. Something like this
Good Luck
Mar 23, 2008 | Electronics - Others
Flash drive problem
sorry to say.. you cant retrieve it...
it happens to flash media .. i dont know what causes this though
Oct 13, 2007 | Electronics - Others
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
