Question about Maytag Performa PAV3200
Rips and tears in clothes
The washer is ripping my clothes and making stress circles on them. The repair man took the machine apart and could not find anything. We have felt all the holes in plastic tub. No sharp edges were found. We felt along the top rim of the tub, no sharp edges either. We filled the tub with water and felt all the holes to see if a sharp object was stuck in one of the holes, none found. We are at a loss as what to do, the repair man says we need to take pictures of the clothes before they go in, then again when they come out. We need help, if we can not solve this issue, we will have to buy another machine. The machine is just under two years old. Buying a new machine is a lot cheaper than buying new clothes. I can take pictures of the rips and stress marks if needed. Please help.
    New Friend:
When the service representative from Sears came to examine the same problem - tears and perforated holes in my clothing - he diagnosed the problem was not caused by the washer but rather by the dryer. The rubber ring, as best as I can recall, had become unglued and left a metal part exposed which in turn was the cause of the tears. He replaced the rubber ring and carefully sealed it. This was about a year ago, and I have had no problems since then. So you may want to have your dryer examined. I was surprised because I too thought it was the washer was the source of the problem.
Posted on Mar 31, 2015
    New Friend:
I have same washer and same problem. just contacted bosch and will see what the repair person has to say
Posted on Mar 28, 2015
  • 114 Answers
The washer could be developing a transmission problem. As the washer agitates, the plastic tub is suppose to remain still. If the transmission is starting to slip, it will also try to spin during the agitate cycle, thus making the clothes become tangled under the agitator.
Posted on Sep 27, 2007
SOURCE:
He5t tearing clothes
Are you sure that the clothes are not getting caught on exposed zips.
Why not load some things like towels sheets (without zips/buttons etc) in the washer and see if the issue repeats itself. You should also be able to see if there are any sharp edges or loose sharp items in the drum (mind your fingers)
Dec 14, 2013 | Kenmore Elite 45986 Front Load Washer
Washer ripping clothes
Check the drum baffles (the paddles inside the tub) to see if one is loose and also check the front tub seal for any tears.
Nov 05, 2012 | Washing Machines
My GE Adora dryer is ripping clothes
look inside the drum with a flashlight and look for broken or loose tumbler rib, can be fixed with epoxy, sand smooth surfaces first, let cure and use appliance paint to paint it
Jun 09, 2012 | GE Adora Super Capacity Dryer
Boot rips
The door bellow on front loaders do wear out and require replacement. However, overloading the washer can contribute to premature wear or rips and tears due to items getting caught in the seal. If the bellow is ripped, it will require replacing or the washer will leak. The following link explains step-by-step how to install a door bellow on a Kenmore Elite front loader:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
Nov 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Tearing clothing
Either use a more gentle cycle or the agitator may be off centered or could have bad coupler or bearings. Otherwise check the seal on top of tub to make sure it is not ripped and catching clothes
Sep 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer is ripping my clothes
yep, I have that problem too. My son's winter coat got wripped to shreds.
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Metal Drum Ripped
$1000 est????? parts are guarrennteed i would def call the manufacture.althoug ive neverheard of hte inner basket "ripping apart" im sure you should have some recouse with the manufacture, the machine new costs that now.did ithe tech give you that est with a straight face???? definatlly call someone else!!!!!!!
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Front Load Rips Clothes
clothing tearing is usally from foreign objects in or on clothing such as zippers fastners belts etc try making sure all those things are fastened should help
May 29, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE top load Washer ripping clothes
Solution!
GE has replaced the "boot" (the large rubber gasket at the opening of the washer) on my washer. This has fixed the problem!
Although the majority of people I spoke with at GE did not know about this, eventually I got a repair technician out here who spoke with one of the engineers. The engineer said that there was a problem with the boot causing clothing to rip. The new boot we have on our washer covers a ring of plastic just on the outside of the metal drum (the plastic rim remains stationary while the metal drum spins - this is the cause of the ripped clothing) - the old boot left this plastic ring exposed. Our washer was only 8 months old - so even if your washer is new, if your clothing is being ripped, insist that the boot be replaced for an updated version.
May 03, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
946 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
