Question about Hayward 116k HeatPro Heat Pump HP3100
How much pressure my hayward heater need to work fine?
  • 3,103 Answers
Same as while vacuuming the pool..low speed circulation.
Posted on Jan 10, 2014
Error code HS on hayward heater H400FDN
check the fusible link if blown check gas pressure
Jan 28, 2012 | Hayward H400FDN Low NOx Natural Gas Pool...
My hayward h400ed2 heater starts for 2-3 seconds then shuts down showing error IF. I checked the gas orifices - they all clean. Heater was working fine fo the most of the summer then started showing IF...
Have you installed anything in your home that uses gas? Alot of times it due to low gas pressure.
When you checked the orfices did you actually remove them? or just stick a paperclip inside and clean them?
If the heater is firing ..even for 2-3 seconds the ignightor is fine. If it wasnt it wouldnt lite, period... bad call on hayward
Aug 22, 2010 | Hayward H Series Pool & Spa Heater...
Hayward H400FDN won't stay lit
It is probably not sensing flame. You either have a clogged orifice underneath the flame sensor and you probably need to have the gas pressure assessed, meter size and gas valve pressure adjustment. These heaters need 2" wc of gas pressure.
Apr 17, 2010 | Hayward H400FDN Low NOx Natural Gas Pool...
Haward H250 dual therm, heater lights then shuts off after 5 to 10 seconds,even with pressure switch bypassed
it sounds like a flame sensor.its located in lower end of burner box,remove it and clean with fine steel wool or emory cloth.
Sep 02, 2009 | Hayward Pool Products HAYWARD H-Series In...
HEATER WAS WORKING FINE TILL I HAD PROPANE TANK TOPPED OFF
The Pressure Regulator may be stuck, Try closing the propane valve releasing the pressure,, gently tap the regulator( on the propane inlet side) and Very Very slowly open the propane tank valve, and attempt to light
Jul 30, 2009 | Hayward H Series
Hayward 250 heater won't fire up
Check the control circuit, specifically the pressure switch, for continuity with an ohm meter....any reading over 2 ohms needs to be investigated
Jun 27, 2009 | Hayward H Series Millivolt 250,000 Btu...
Pool heater will not ignite
check pressure switch,if it is faulty or out of adjustment it wont allow it to go tomain burner
Jun 17, 2009 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Hayward 116k HeatPro Heat Pump  HP3100 Logo
89 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
