Question about Bose V35 Theater System
Connecting computer to bose v35
I have my laptop connected to bose v35 via HDMI. The screen is cut off on the TV (samsung 55 inch) in the top and bottom. Tried changing the resolution to different values. They either make the screen to small or too big to fit in the screen, or flicker in some resolutions. None of the resolutions fit the screen correctly to the size of the tv screen. However, if I connect the laptop to the tv directly (via HDMI) it is perfectly fine. The resolution when connected to the tv directly is 1280 * 800 @60HZ. The same resolution does not work when connected via bose v35. Any help in solving the problem would be greatly appreciated.
SOURCE: Bose Lifestyle V20 - no video out, no response to remote control
check the voltage setting on the power supply that connects the power cord to the media center. Mine was set to 230V. Changed it to 115V and the video starting working.
Posted on Dec 07, 2008
SOURCE: System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Posted on Feb 05, 2009
SOURCE: Apple TV and Bose Home Theater
I had the same problem.
I could not get HDMI to HDMI to work.
i fixed it (work around), by connecting ATV HDMI to DVD HDMI port on V30, i then connect L&R to AUX.  I set the Bose remote for controlling ATV to AUX.
so to use ATV with Bose remote i know press DVD, this gives me the correct display but not audio, i then press AUX and this gives me ATV control and audio.
interesting, when i first set this up (trial and error), it didn't work.  I was doing some cable management clean up, when i got a fright and the thing started working...but i have a ghost in my house so that is probably a more plausible reason why its working now.
it feels like this product is only 90% finished
Posted on May 26, 2009
SOURCE: Connect lifestyle 48 to plasma and dvr
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
Posted on Sep 29, 2009
SOURCE: Bose 3-2-1 - trouble connecting to Samsung 26" LCD monitor
Sounds like you might be out of luck with the older 3-2-1 system. I am in the same boat, and am thinking I will only be able to utilize the "audio out" on the back of my Samsung LCD, and run that to the "aux in" on the Bose 3-2-1. This of course will not allow me to utilize the 3-2-1's DVD player, but by using a seperate DVD player, such as a Blu-Ray hooked to the LDC TV, the video will make it to the screen, and then the audio should make it through the Bose 3-2-1 speakers. Probably not the "best" solution, but one that I am going to attempt.
Posted on Oct 14, 2009
We have purchased a Samsung 55" Smart TV. We have it set up and working with Foxtel connected via the supplied fittings. How do we connect the DVD player?
The usual way is to connect it via a HDMI cable, for which the TV should have 2 or 3 input ports. You then select this HDMI as input on the TV to see a DVD playing.
Get a "high speed" HDMI cable. Some will say there is no difference between any HDMI cables, but they did see fit to increase the bandwidth in these cables for Blu-Ray DVDs.
Dec 27, 2016 | Samsung Televison & Video
My bose lifestyle V35 console is playing through Av but HDMI source are not coming up at all.why?
Could be a bad cable connection, or more likely the HDMI socket is switched off on either TV or Console. Check your instructions or just look around the menus of both devices.
Aug 17, 2015 | Bose Audio Players & Recorders
I have a new TCL 55 inch smart wiffi ROKU TV what do I have to do to connect laptop so tv will be monitor wirelessly
You cannot have the TV as a wireless monitor for a XP machine.
Your ROKU TV will have HDMI input, but XP dos not have the ability to produce HDMI.
Using the composite input via a converter from the VGA output is possible.
see such a device here.
C2G VGA to Composite PC TV Video Adapter
Feb 19, 2015 | Computers & Internet
How do I stop the aspect ratio from auto changing on my flat screen set up as the monitor for my computer?
When you set it to just scan the source will determine the scan. I would remove the bose from the unit and connect the cable or sat box directly to the hdmi in of the tv. if the problem persists check Samsung web site for software upgrade. If upgrade does not fix replace the main circuit board.
May 07, 2014 | Samsung Televison & Video
Have lg 55ls5700 tv trying to connect samsung hw-f450
I suspect that the TV you have does not support the ARC function that the sound bar has. What you may have to do is use the Optical In from the sound bar to the TV and you should be good to go. You may have to change the TV's settings to use the Optical In though. So you should end up with the BluRay Player connected to the TV via an HDMI cable, the sound bar connected to the TV via the Optical In using a fiber optic cable. Hope this helps.
Mar 19, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
Hi I have connected my new Sony Laptop to my Hitachi TV (model PW2) via HDMI to input AV6 on the TV. Picture is perfect however I have no sound coming from my Bose Lifestyle 48 system. The sound on my Sony...
I don't think you can run AV6 and external sound could come from the TV as Audio Out through Cinch/Phono connectors. As you rightly say, the HDMI signal has audio on it, so the logical way should be to come from the TV through Audio Output connectors and to the Bose system as you cannot come from the Bose system to an already used AV6.
Hope that helps.
Nov 27, 2010 | Computers & Internet
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
Feb 11, 2010 | Apple MacBook Pro Laptop Computer with...
NO CLOSED CAPTION VIA BOSE LIFESTYLE 20 SYSTEM
CC is a function of your cable box in this case. TV's have the feature as well, but Bose is right about not all HDMI devices supporting CC through HDMI, especially converting from component to HDMI before hitting your TV. The solution: call your cable provider for this. Start at the source. The cables you use or the TV won't 'take away' closed caption if it's already there.
Feb 19, 2009 | Toshiba MW20FM1 20 in. Combo
I am trying to connect my Samsung DVD Recorder to my Samsung PS-42D7HD tv via the HDMI cable but it just comes up "no signal" on the tv - nothing at all. Also have an Olin HD Set top box with...
Hello
by befault your dvd recorder is transmiting signals via component video, so what you need to do is this connect both cable HDMI and Component or just a video cable then go into setup and then select video out via HDMI your video will go off on the screen and then with TV remote slect input source HDMI on TV and it should work fine.
Thankyou
May 09, 2008 | Televison & Video
Bose V35 Theater System Logo
95 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
