Question about E-Machines eMachines Desktop PC
Computer idles high then shuts down - E-Machines eMachines Desktop PC
    New Friend:
  • 126 Answers
You probably need to clean the fans as this seems like a thermal shutdown if that fails then the power supply may be faulty
Posted on Oct 17, 2013
  • 30 Answers
Time for a new motherboard
If you need further help, I’m available over the phone at https://www.6ya.com/expert/ernie_b93ee48ba0eab50b
    Master:
  • 359 Answers
When you say "idles high" do you mean you hear fans spinning faster or louder? If so, a fan spinning at higher than normal speeds is indicative of components/chips being run aggressively causing them to run at much higher temperatures. You may want to look into getting temperature monitoring software like CPU-Z to monitor the temperatures of your CPU and GPU. These components are the most common ones to be running at high temperatures. If any fan has failed on them the secondary fans (if there is one) will run at much higher speeds to compensate. Your PC may have a safety precaution to automatically shut down if certain temperatures are reached to prevent permanent damage to the components. Are you getting any blue screens before it shuts down?
I have 2004 Toyota Corolla with a remote start when starting the car idle is very high then shuts down
most likely idle air control valve on throttle body remove rubber air duct that runs from air filter spray real good with carb spray wait 30 minutes for it to dry should improve condition
Feb 26, 2015 | 2004 Toyota Corolla
I have a 1990 S-15 with 4.3 motor idles high when you start, idles down , set and idle for a while it starts idling up and down.any idea's?
Could be a faulty idle air control valve.
The computer controls idle speed by regulating how much air enters the throttle body thru the valve.
You could unplug the valve when the idle speed is close to normal, then shut the engine off and restart to see if the idle speed is still in the same place. Unplugging the valve will also set a trouble code and turn the warning light on.
Mar 07, 2013 | Chevrolet Cars & Trucks
Did a tune up on a 2004 nissan quest-and now it is idling up and down
You have created a vacuum leak somehow in the process of messing with it. It has to be a manifold vacuum leak, which is why it is idling up too high and then the computer shuts it down and then this cycle keeps repeating.
Oct 17, 2012 | 2004 Nissan Quest
Vehicle idles high for a few minutes, then shuts
did u use fuel stabalizer? if not the gas can turn into a varsale like substance that can clog fuel filter and reck injector seal's, also check the disributor cap and rotor for condensation, this can happen over a period of sitting
Jun 07, 2010 | 1985 Toyota Pickup
Noise at shut down
The noise is caused by the engine running on after the ignition is shut off. It makes noise because the pistons are rattling in the cylinders from incorrect timing. This has nothing to do with the mechanical or electronic timing of the engine. The engine runs on either because of hot glowing carbon deposits in the cylinder head or because the engine was shut down when it was running too fast. Sometimes the carbon can be literally blown out by running the engine at high rpm for a short time. Put it in second gear and run it for a couple of miles on the highway. If this does not work the heads will have to be removed and the carbon cleaned out manually. The shut down when running too fast problem can be caused by the idle being set too high or by shutting the engine off before it has reached idle speed. If you can adjust the idle speed try reducing it. If not always hesitate before shutting the engine down to let it reach idle speed. Good Luck!
Mar 20, 2010 | 2001 Ford F150 Styleside SuperCrew
High idle and shut off.
Check either the throttle position sensor, or idle air control valve. One or the other is the most likely culprit. Could also have a vacuum leak which will cause a high idle.
May 12, 2009 | 1988 Dodge Aries
Idle is off??
hi leobowdy
disassembly the carb and carefully clean it.Check the air filter,the fuel line and fuel filter,check the needle,lever,small spring and the screen filter from the carb.Check the sparkplug.
high speed H=2 turns,low speed L=2 1/2 turns,adjust T
When chain saw starts adjust H,L and T accordingly.
cheers savumihai71.
Nov 22, 2008 | Ryobi Factory Reconditioned 18" 40cc...
My chevy 5.3 idles low sometimes stalls at stops
Clean the throttle valve and the air bypass idle speed control valve, they get full of sludge and restrict air flow, this causes a low idle at times and the engine will stall, clean them by spraying carb spray into the throttle valve while the eng is running, have someone hold the idle high or it will stall, after using at least 1/2 can shut down and disconnect the battery for 5 minutes, this clears the memory and allows the computer to relearn idle strategy, the computer willl take a few days to relearn the idle, maybe 30 miles of mixed driving.
Oct 14, 2008 | Chevrolet Avalanche Cars & Trucks
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
