Question about GE Profile PDS22MHR Bottom Freezer Refrigerator
The turbo freeze and turbo cool buttons on the display are stuck at 88 and I cannot get any of the other display settings to work. If I hold each for 3-5 seconds, nothing happens. I'm still getting water and it's making ice, but I cannot use any other functions on the display panel.
  • donnatroendle
    donnatroendle Oct 16, 2013
    I also had the ice maker replaced twice and a new motherboard put in about 6 months ago!!
    Worst refrigerator I've ever had in 50 years.
  • donnatroendle
    I've also replaced the ice maker twice and the motherboard once about 6 months ago. This is by far, the worst refrigerator I've ever owned.
4 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Hi Urban Woman,
Unfortunately, your dispenser interface board has gone to appliance parts heaven and needs to be replaced. Fortunately it's relatively cheap. If I recall correctly, all you have to do to access the dispenser board is use a small flat screwdriver. There are 2 locking "tabs"/slots on either side and underneath the board (you will barely be able to see it, they're just that small). 6fb5654.jpg
Of course you already know that you need to unplug the fridge before doing any repairs so I can skip that part.
Insert your screwdriver into those slots and pry the bottom of the board out. Then grasp it with your hands and remove it completely. There are three wire bundles on it, remove them and re-install them on the new board. Then simply snap the new board into place.
This should take maybe 15 minutes to do... super easy job.
SG
p.s. Here's a link to the service manual, but the removal of the dispenser board is not in it (everything else is, though, so it may come in handy later)
p.s.s. Since you're going to be unplugging the fridge for the repair, you ought to go to Home Depot and pick up one of these to plug it back into. Transient voltage spikes are most likely the cause of all your woes... including the main board that was replaced.
Posted on Apr 01, 2009
aasc
  • 1606 Answers
SOURCE: ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Posted on Aug 30, 2009
Had the same problem. Pressed button heard a click, saw zeroes flash, then nothing. After some online search I found and solved the problem. Corrosion and condensation on the connector plug attached to the wire at the bottom of the freezer door. Remove plastic grill, pull out wire from under box. You'll find a plastic connector and possibly wet or corroded wiring. CUT POWER TO FRIDGE OFF FIRST. I cut away the white plastic connector then stripped and tied the wires together with wire caps. Taped them up too. Note which wire goes to which first. Mine was blue to blue, black to black, and red to white. Problem solved.
Posted on Sep 04, 2012
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
RT50 control panel not responding
It still sounds like the child lock is on since that prevents accidental setting changes on the refrigerator's control panel.The following will NOT work if the child lock function is activated: Freezer Temp Button Fridge Temp Button Power Freeze Button Power Cool Button Ice Type Button Water Button Ice maker Water OR it may be in Cooling Off/Demo Mode. Cooling Off/Demo Mode is a feature used by retailers to display the refrigerator without running the compressor. If your unit is not cooling, and the bars are constantly scrolling up and down the temperature, check your manual for reset advice
Mar 31, 2014 | Samsung Refrigerators
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and
the refrigerator and freezer do not get cold.
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
operation.
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Source: http://downloadcenter.samsung.com/content/EM/201104/20110414114919054/110323-QS_Guide-POLARIS-EN.pdf
Dec 30, 2013 | Samsung Real Stainless Steel 30 Cu Ft Side...
RF267 ABPN displays 88 88
it may just be the damaged lcd display or a diode controlling the display from the lcd.
Jun 05, 2013 | Samsung RF267ABPN (25.5 cu. ft.) Bottom...
Flash 88
Stuart:
I own a Samsung Model RF267 ABPN and am experiencing the exact same problem. If you go through the fixya Web site you will find this is a fairly common problem with the Samsung Refrig. There are 4 schools of thought:
1. Press and hold power freeze and power cool buttons at same time for 10 seconds to reset.
2. Press and hold the Energy Saver and Lighting buttons at he same time for 8-10 seconds.
3. Unplug the unit for 10 minutes and plug it back in.
4. Replace electronic circuit boards (for example the main board found in the backof the unit or a board that controls the dislay found in the door.
I would be interested in how your unit responds to #1 or #2.
Good Luck
R Joslin
May 23, 2013 | Samsung RF265AA Bottom Freezer French Door...
Error code 88 88
The 88 88 code indicates a modem communication error in the refrigerator. This error is not applicable in the U.S. It should be ignored. The control will conduct a self diagnostic check when it is powered up. When this code is encountered it will just need to be cleared and the refrigerator will resume normal operation. To clear the code, press and hold the POWER FREEZE and POWER COOL buttons simultaneously. NOTE: Be sure to press these two buttons at EXACTLY the same time -- no sound will be heard when the buttons are both pressed properly). HOLD the buttons down for about 8 to 12 deliberate seconds until the control beeps and goes blank. Leave the control in this diagnostic test mode and allow it to exit after it times out in that mode. This will take several minutes. When the test mode clears the fault code 88 88 and returns to normal operation, you should be able to set the controls on the unit and it will work normally.
Frank V.
Jul 22, 2012 | Samsung RF265ABBP (25.8 cu. ft.) Bottom...
Control panal is not working.
Hold Energy Saving & Lighting buttons simultaneously for 10 seconds! Panel dispaly resets.
Mar 31, 2010 | Samsung RF265AA Bottom Freezer French Door...
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
New GE profile refrigerator bottom freezer model pfss6pkwass. Will not run, stuck in display mode. Lights are on but when setting temp on panel it goes back to off after a few seconds. After spending...
Ok, I had the same problem with this fridge. It is in "demo" mode. You have to push in and hold the Energy Save and Adjust Freezer buttons at the same time. Hold these in until the display starts flashing. You should hear the compressor kick on. I did this, and it was fixed and started cooling in a matter of seconds.
Aug 13, 2008 | Refrigerators
GE Profile PDS22MHR Bottom Freezer Refrigerator Logo
55 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
