Question about Hisense 0375625 Television
How do I mount my 50 " his sense TV model no.55k610gw
I have a Nexxtech tv mount, model 8008654 that i used for a 40 inch flat tv. I purchased a 47 inch tv and i want to install it, but i lost the booklet and i'm wondering how to fit the panel
Don't fit the 40" panel for a 47" TV. It's not designed for it.
Buy a mount for a 47" or even a 50" TV instead. It will come with better fixings so that your 47" TV doesn't end up on the floor.
Jan 06, 2015 | Televison & Video
I am missing the wall mount screw for my TV.
The mount will come with several different sizes of screws so you can choose the correct ones.
Mar 18, 2014 | LG 50PQ30C 50 in. Plasma TV
Hdmi 1 not working panasonic 50 plazma
need the model number to assist but it sounds like a main board issue if you have one of the panasonic plasma models that have the inputs all on the main board. You can get main boards for most models at www.tvrepairworld.com
Mar 22, 2013 | Panasonic 50 in. Plasma TV
Aprilaire model 50 current sensing relay won't close
If the relay is not closing then it must be replaced. It works by sensing the current through the common wire of the blower motor.
Dec 08, 2012 | Aprilaire 50 Current Sensing Relay...
I own a Samsung DLP 56" TV for which I purchased a swivel wall mounting bracket that holds up to 160 Lbs of weight. However when looking at the back of the tv set and the such smal size screws that...
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
Jun 30, 2011 | Samsung HL-T5676S Television
I have a 50" Phillips
Check ur owner manual or call Philip support Tech. ask it this tv model have a colors wheel design into it tv.Not sure for a Philip model tv 50" DLP tv,but the Samsung model 50" DLP tv this problems alway causes by a dying colors wheel that design into it tv.Which the colors wheel it is warp worn out and spinning off of it motor mount axis to cause grinding noises and tv colors to mess up and flashes or have flashes Black & White within it picture.
Jun 07, 2011 | Philips 50PL9126D/37B 50" DLP TV
Remotes does not function at all. Tried two different remotes, only manual switches work.
Remote sensor/ receiver mounted at tv front sounds defective and unable to sense/ receive remote signals.
Replace infrared remote sensor in tv to fix the issue.
Jul 18, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Can I use any universal wall mount for my LG
Just check the weight and size restriction on the wall mount. As long as the weight and size specs of the TV fall within those allotted by the wall mount, you should be fine.
Nov 13, 2009 | LG 50PC5DC 50 in. Plasma HDTV
Can't find inserts/holes needed to wall mount the television.
i went thru this with my tv.. you can pop off those caps, if there's no obvious way to remove them
then when you shop for a mounting system, get a bigger/ higher capacity mounting system with generic connector system.
Dont go for the cheapeast price.
Nov 30, 2008 | Televison & Video
Televison & Video Logo
63 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
