Oki cx3641 Fuser life does not reset when I change the fuser. Any suggestions?
    Champion:
  • 219 Answers
You might have to go into the service screen and reset it yourself
Posted on Oct 17, 2013
Soulvisitor
  • 1113 Answers
SOURCE: HP clj 2550n error 50.2 fuser
Replace fuser assembly is the fix
Normal consumable, the lamp electrics (lamp, thermistor) will have blown.
9337832.jpg Part info
Posted on Jan 13, 2008
jtuminaro
  • 56 Answers
SOURCE: Brother 8460n Fuser Unit
Hit in sequence Menu,*,2,8,6,4
This will put it in maint. mode.
Press 88
That is parts counter reset, scroll down and hit ok on the part you want to reset the counter. :)
Posted on Jan 14, 2009
  • 5 Answers
SOURCE: RESETTING FUSER LIFE ON BROTHER HL5140 PRINTER
How to reset the pf-kit message on a brother hl-5140.
Posted on Aug 12, 2009
  • 255 Answers
SOURCE: Sharp AL-1631 Fuser Unit
The fuser codes are only H2,H3 and H4. To reset , press C, Exposure, C, Exposure.Display goes off enter 14 press print.
Posted on Nov 18, 2009
markzbylut
  • 64 Answers
SOURCE: I have a Oki b6500. Replaced the fuser. How to
The following procedure was provided by Oki Tech support when a web search did not provide an answer. Resetting the Fuser After Replacement - When Counter is NOT Reset First print out a MenuMap and note the fuser count, to later verify that the maintenance reset has taken affect. To reset the fuser counter, enter the diagnostics mode and go to Maintenance Mode Step-1 How to enter the maintenance mode. Hold the Menu & Right arrow button while powering on the printer. Hold the buttons down until the op panel displays “Initializing”. The op panel will display “Output Test” Step-2 Press the down arrow three times. The op panel will display “Maintenance Info” Step-3 Press the right arrow. The op panel will display “Reset Maint Reqd Execute” Step-4 Press the select button. A quick flash will come up on the op panel “Resetting Maintenance Reqd”. The op panel will then display “Reset Maint. Reqd. Execute” Step-5 Press the Cancel button to exit the Maintenance Mode and go back to “Online”. This completes the process, please print out the Menu and inspect the Fuser Count it should read ‘0.’
Posted on May 20, 2010
Ho do I reset my MFC8480DN after replacing the fuser unit?
This is the fuser reset procedure from page 563 of the service manual:
5.1 Resetting the Periodical Maintenance Parts Life
? Resetting the Life Counter of the Fuser Unit
<Function>
This function allows you to reset the page counter of the fuser unit and increase the number
of replacement times by one.
<Operating Procedure>
(1) Press the [3] and [9] keys at the same time in the ready state.
The "Reset Menu" will appear on the LCD.
(2) Press the [ ] button a few times to select "Fuser".
(3) Press the [OK] button.
The "1. Reset / 2. Exit" will appear on the LCD.
(4) Press the [1] key when resetting the life counter of the fuser unit. Press the [2] key if not
resetting.
(5) The "Accepted" will appear on the LCD if pressing the [1] key. The page counter of the
fuser unit is reset, and the number of replacement times is increased by one. Then, the
machine returns to the ready state. If pressing the [2] key, the machine do not reset the
page counter and the "Fuser" will appear on the LCD.
Feb 10, 2015 | Office Equipment & Supplies
How to reset he 980 fatal error on a oki 610 laser printer
The OKI 980 Fatal error is a Fuser that needs to be replaced. Replace the fuser
that being said you can replace the fuse on the fuser unit or you can do the option below that I DO NOT RECOMMEND
separate the fuser unit in half
Unravel and loosen the wires at the connector at the bottom of the fuser close to the edge so you can pull that connector out a few inches so you can get a couple of wires in there.
Insert a wire into each of the two holes on the back of that connector. 2 and 3 have wires going in, 4 and 5 don't which is the fuse. After you get the wires in the 2 holes. Make sure the wires are long enough to hang out the case. put the case back together and put the fuser in. connect the two wires together and power up the machine. As soon as you here the first motor, which is about 5 seconds into the startup, pull the wires apart. This will make the machine think that the fuser has been broken and reset the fuser life.
You can also purchase new fuse units from ebay etc and replace the fuse unit.
Sep 01, 2014 | OKI Office Equipment & Supplies
How do you reset maintenance count on a dell 3130?
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Aug 27, 2014 | Dell 3130cn Color Laser Printer
Reset xerox phaser 5550
To reset the maintenance counter (assuming it is the maintenance kit you need to reset)
1. From the Main menu, select Information, then press the OK button.
2. Select Supplies Info, then press the OK button.
3. Select Reset Fuser Life, then press the OK button.
4. Select Reset Fuser Life NOW, then press the OK button to reset the fuser life.
Aug 01, 2014 | Xerox Phaser Office Equipment & Supplies
How to reset fuser life error
the best soloution is to replace the unit with a brand new one as reset fuses are difficult to work with on fuser units but if you search the internet you might be able to find a reset kit from alibaba or amazon
Jul 23, 2014 | OKI C Office Equipment & Supplies
Oki c710 error 980 reset
Per the technical manual - Media wrapped around the fuser error. Turn off the power. Replace the fuser....
It is possible to unravel the paper from the fuser.
Feb 15, 2014 | Oki Electric Industry OKI C710dn - - color...
Wide yellow line and blotches in blue background
he poor quality in OKI LED color printing might be fallen on one of the following problems:
- Toner is almost running out
- Drum is scratched or its life almost terminated
- Belt is scratched or its life is almost terminated
- Fuser is scratched
- LED Print head is dirty.
Depend on the knowledge and experiences of each person, the solution is solved easily or takes much time or much labor as well as money This is my suggestion that I have learned from my experiences on OKI C3200, C5300, C6100, C330 that I own:
- First, you should have extra printer accessories suchj as toner and drum cartridges (Y,B, C, M) and fuser, belt for reservation. I think you should have them since someday your printer must need them after they reach to their life limitation.
- Test one after one with the good ones. First testwith tonner cartridges. If the test is OK then continue to test drum cartridges. If it is OK then test fuser and so on. Finally if it is OK, then you must look at the LED Printer heads.
Below is the bad print-out:
:hbc-error.jpg?w=183&h=296After following the steps that we suggest, we found the LED head above the red drum is dirty. Below is the picture after it is clean:
hbc-ok2.jpg?w=181&h=300
Oct 25, 2013 | OKI C3400N Single Pass Color Printer
HL-5250 report shows fuser and laser life at 0% and PF kit 1 at 12%
The fuser is a separate component to the drum and toner in this printer. It has a much longer life than them but will run out eventually. Sadly a fuser unit is not a commercially available consumable for this printer either. I would recommend contatcing a printer technicain or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother HL 5250DN Laser Printer
Service call 984: fatal error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Mar 20, 2013 | Oki Brand Oki C610n Laser Printer...
Oki c5800 belt life reset
It may require a complete service kit, you should check with Okidata to see if there is a kit available or what steps you should take to reset the life counter.
Jan 29, 2013 | Oki Electric Industry Okidata C5500, C5800...
78 people viewed this question
jasbo
jasbo
