Question about Fossil Clothing Accessories
One of the snaps broke on my boot and I need to get 4 (3 on each boot) to make them all look the same when I get it repaired.
    Master:
  • 969 Answers
Take them to a shoe repair shop to get this taken
Posted on May 06, 2014
How to replace hatchback handle assembly
You need to get into the boot space remove trim card on boot lid then you will see lock assembly find the link rod to the catch flick it with a screwdriver and the boot will open to change the locl assembly is quite easy you will need TORX bits to remove fixing screws good luck.
Jun 22, 2014 | 2000 Ford Focus
1997crank pulley fell off bolt snapped need to repair
So, go ahead and repair it. You don't need our permission.
May 28, 2014 | Cars & Trucks
Ink release lever in brother MFC-6490cw broke
Did you ever resolve issue with broken tab. I have same problem on my black cartridge release tab, and am wondering if I can need tab or can salvage. Thanks!
Nov 17, 2012 | Brother MFC 6490CW InkJet Printer
Repair driver side door
tHE DOOR PAIEL IS SURRONDED WITH 6 TO 8 PLATIC RETAINERS THAT SNAP INTO THE DOOR FRME.WHEN YOU TRY TO POP THEM OUT FROM THE DOOR FRAME BE CAREFUL NOT TO SNAP OF THE RETAINERS. yOU CAN DO THIS WITH A SCREWDRIVER. " may be a screw in the door handle or the pull handle. Sorry about the caps lock was on. hope this helps.
Tommy
Jan 07, 2012 | 2000 Dodge Intrepid
I have a 1997 Silverado 2500 4x4. I went to take it out of 4 wheel this morning and the shift lever now slides freely leaving it in 4 wheel high. How can I fix this and can it still be driven on the...
Sounds like you broke the linkage. I'd get down there, and manually put it in 2WD by you activating the linkage from where it's snapped, it's a bad idea to drive anywhere but on the mud if 4wd, if the axles turn at different speeds, it could snap a driveshaft, or worse, the differential.
Dec 19, 2010 | 1999 Chevrolet Silverado 1500
The prong on the plug snapped off in the outlet
Hello. You can replace the plug your self with a good quality 120 volt, 60 Hz plug, or you can take the toaster to most hardware stores or electrical supply stores where they will repair it for you. Joe
Apr 27, 2010 | Dualit CTS4E 4-Slice Toaster
I have a Porter Cable 352VS Type 4 sander needs bearings.
You need special pullers for these, you will have to take it to a power tool repair shop.
Jan 26, 2010 | Porter Cable 3" x 21" Electronic Variable...
How to remove velocity joint?
Hello, If the axle shafts have not been replaced before, you have the old style c/v joints. The tools to do this job are very expensive abd are usually only purchased by dealers etc. They consist of a large cutter, looks like a huge pipe cutter, and a crimper, to crush the cans together.
You would be better served to buy an updated axle shaft assembly that is made so anyone can replace the boots.
I case you were not sure how to remove the axles, here it is.
To do this, you need to elevate the car securely, remove the wheels, remove the long 13mm bolt from inside the hub then place jack under the differential and unbolt the mount from the frame, let the diff down remove cover, remove "C" clip from the end of the axle, jack the diff up as high as you can get it, take axle down from the wheel side, and then slide the axle out of the diff. Then you slide the boot down and at the end of the axle you will find a snap ring. remove snap ring and then tap the c/v joint out.
If you find this information to be correct would you please enter a "fixya" rating.
Thanks, Gator241
Feb 13, 2009 | 1984 Mercedes-Benz 190
Headlamp pull out nob broke so can't turn on head lights wondering how to repair
If just the silver bezel broke you can buy a new one and it snaps on like the other one did. So that way you don't have to replace the whole thing, but if the switch itself broke, then you'll have to buy a new one. Hope it helped!
Jan 04, 2009 | 1966 Ford Mustang
Clothing Accessories Logo
Top Fossil Clothing Accessories Experts
Da Doc
ray gallant
Are you a Fossil Clothing Accessory Expert? Answer questions, earn points and help others
