Question about RCA DSB772WE Wi-Fi Streaming Media Receiver
My RCA Wi-Fi Media Streamer stopped connecting to the Comcast wireless router when Comcast encrypted their signal. I have entered the password several times, each time it says error. In the setting it says the link is down. I called Comcast and they said it's my streaming device, to call RCA. I can't get connected again. Any suggestions?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
Get on phone live support, call 1800 252 6123 theese guys are cool if they cant fix it over the phone they also repair/repalce them for like 20 bucks and give you a 1 year warranty
Posted on Nov 29, 2013
3 Suggested Answers
  • 101 Answers
SOURCE: rca streamer not logging on to netflix nor hulu.
I suggest that you try and use a wired connection to test your wireless setup. You could be having interference problems or signal loss issues. If the wired connection works then that is your problem. A 4" wall is equivalent to 16 feet of open air, so the more walls you have between your wireless source and the destination the greater the signal loss. Also if you are in an apartment you could be getting interference from our neighbor's wireless equipment. If possible temporary move the wireless source into the same room with the receiver and see if that helps. Again if that does fix your problems, then you need to find a different Ethernet connection method. Try a Ethernet Over Power (example only) system. If none of these provide any better results then you need a faster internet access. Ask your ISP to provide you with a faster access for one day so that you can test your system. They should be willing to do that for you for free.
Posted on Aug 02, 2012
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
My streamer worked fine until we moved and put it in storage now it connects to internet then when you try to do something with the remote it says prohibited
Try running the basic set-up procedures. If it's connected to a wireless network, you may have to enter a password (if one was set up and network security is turned on) in order to connect to your router / wi-fi network.
BTW, are you using the remote to access netflix? I don't think that the problem is with the remote, you're probably trying to access sites that require subscriptions and log in info to access the streaming media.
Mar 01, 2015 | RCA DSB772WE Wi-Fi Streaming Media...
I have a RVA tablet my wifi signal is always dropping or disconnecting on its own. Right now the wifi signal is remaining grey and not turning blue. I'm very close to my wireless router. What is wrong with...
you have not mentioned encryption - does the wireless router use WPA or Wep encryption if it does you have to connect the tablet to the actual Wi-Fi if the router broadcasts its id it then your tablet will ask for a password which is the encryption code. This may be the cause of your problem.
Dec 23, 2014 | Computers & Internet
Can't connect to a wifi router that uses WEP encryption
Within Android settings of the S8 select Wi-Fi (to turn it on)... you may need to toggle or slide between off and on to enable The tablet looking for a Wi-Fi signal.. Then select Wi-Fi again to see the networks that are broadcasting and select your particular WI-Fi router. Enter the password for your network.
Dec 31, 2013 | Computers & Internet
Wi-fi pasword connot conect to wi-fi
Network security key
Some later model wireless routers have the Password (ie.Encryption key) and the SSID already configured in the wireless router and this information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adapters in your computer/laptop.
If these settings do not suit you, then it can be changed to suit your requirements.
The encryption key secures your data and wireless connection from unauthorized access.To configure the wireless settings in the router, connect a LAN cable from your computer to the wireless router, then open a Browser on your computer and enter the router's configuration IP address, then enter the admin login and password and then go to the wireless settings and configure the SSID and Encryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2 key.If you use the Passphrase method select either WEP or WPA or WPA2 to generate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to 63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born in January 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop, configure the wireless card in your computer/laptop with the router's wireless settings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptops can communicate with your wireless router. http://www.fixya.com/support/r10267861-network_security_key
Dec 18, 2012 | Samsung Corby 2 GT S3850
I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
  • Move closer to the Wi-Fi router or hotspot.
  • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
  • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
    • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
  • Check for any sources of potential interference.
  • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
If you are unable to access the Internet while connected
  • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
  • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
  • Verify that the Wi-Fi network settings are correct:
    • Tap Settings > Wi-Fi.
  • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
  • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
  • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
  • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
  • Restart the device
    • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
  • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
  • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
  • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
  • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
  • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
  • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
  • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
Mar 22, 2010 | Linksys Wireless-G WRT54G Router
How do i protect my unsecured home wi-fi network? I have a Belkin router IP address 192.168.2.1.
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 19, 2009 | Belkin (F5D7230-4) Router (587009)
My laptop asking for sercurity key passphrase
First connect your router to computer with ethernet cable.
Then you can access it with following link
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then go to wi fi security check your WEP code it is your security key connect wi fi network.
Let me know if you need more assistanse.
Thanks
Oct 02, 2009 | Linksys Wireless-N WRT150N Router
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
How to protect my DNA-A211-I router
First connect your router to computer with ethernet cable if it is not in network.
Then access your router with following link.
http://192.168.1.1
or http://192.168.0.1
type user name as "admin" and password as "admin' or blank or "password"
then go to wi fi security then cinfigure it as WEP then enter encryption code it is your connection password .
So who want to connect your wi fi need that password .So your wi fi is secure now.
Aug 12, 2009 | D-Link 802.11g Wireless Router WBR-1310...
RCA DSB772WE Wi-Fi Streaming Media Receiver Logo
205 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
