Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My Whirlpool Cabrio washer has it's lid lock light flashing while the door is actually locked and it does not spin out the clothes.
  • Jose
    Jose Oct 16, 2013
    In addition to my question above, the door will unlock when the lid lock light start to flash.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Check the door safety switch.
Posted on Oct 17, 2013
scottowa
  • 87 Answers
SOURCE: Whirlpool Duet makes spinning sound but drum is not spinning.
What is the model number? To get your clothes out and the door open on that model, try unplugging it for awhile and open the door (you probably have tried that already. Some models you can take off the bottom panel and reach up and there is a little ring you can pull to open the door. (most likely) you might be hearing the pump running since it always run when spinning. If you give me the model number I can let you have the test code. You could try Pressing any key (not power or stop) hold it in for 3 seconds let go 3 seconds, press 3 sec, let go 3 sec, hold 3 sec let go. It should come up all lights on. Don't worry you can't damage anything in the test mode. Watch what it says. then press that same key about every 30 seconds to advance it. It's kind of hard to explain but I'm trying my best. It should at least unlock it in the process. Good luck
Posted on Jan 24, 2009
  • 1314 Answers
SOURCE: whirlpool duet frontloading washer been
as far as i can find out there is no f35 hold pause cancel for three seconds and let me know if the code resets
Posted on Jan 30, 2009
  • 572 Answers
SOURCE: The lid will not lock on my Whirlpool Cabrio
id change the door switch
Posted on Feb 06, 2010
  • 867 Answers
SOURCE: Whirlpool Cabrio Lid
The lock cannot be disabled, The lid removes easily and is also simple to replace.
Depending on where in the world you are depends on where you will get a lid, If you do a google search in your area for whirlpool spares you will get some results.
Posted on Mar 11, 2012
SOURCE: I have a wtw5600xw0 Whirlpool washer. When I press the start button the sensing light and lid lock lights turn on. Then after a few seconds the lid lock light goes off and the sensing light stays fl
Swich off the machine, try some WD40 on the door mechanism (on machine lock, not on the door) and open & shut for a minute or two. Then try the machine, spin only just to try.
Rate pl, if solved, or dont!
Source
Posted on Nov 27, 2012
Lid locked light on, will not release
The lid lock light won't stop blinking. - Fixya
www.fixya.com/.../t14714916-lid_lock_light_won_39_t_stop_blinking
Oct 21, 2012 - The lid locked keeps blinking and I can not start a cycle. - WhirlpoolLSB6200KQ Top Load Washer question. ... Whirpool cabrio wtw5500xw top loadwasher will not start lid light flashes then goes out and into flashing pause ...
Whirlpool washing machine_ lock light flashing_ nothing ...
? 1:53
www.youtube.com/watch?v=zrV9w6Z5LAU
Mar 3, 2012 - Uploaded by briantaylor62 Whirlpool washer wont start a cycle, lid does lock and the locklight ... a cabrio as well that just has the lid lock flashing and nothing happens , I ...
Flashing Lid Lock Light: How to Troubleshoot Errors on Your ...
? 1:23
www.youtube.com/watch?v=nttHsAX2_OM
Mar 27, 2015 - Uploaded by searspartsdirect
The lid lock light on VMW washers, made by Whirlpool, Kenmore and Maytag, will flash whenever there is a ...
Oct 12, 2015 | Washing Machines
I have a Whirlpool Cbrio top load washer. it won't start it's cycle. Once it senses the load, the lock lid light flashes and it does nothing. can this be fixed?
I would say that the lock has failed. Either the lock itself or maybe the pin or latch that fits into it when you close the door may have cracked / broken. If the machine thinks the door / lid is still open, it wont let you start it.
Jan 03, 2015 | Whirlpool Washing Machines
Whirlpool cabrio washer no longer spins
Most likely control board. On a cabrio main power controls everything. If it agitate and drains and does not spin that's what it will be especially if there are no codes. Only other thing that could prevent spin, is a bad lid lock. But if there are no codes it a board.
Apr 05, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool washer cabrio stuck on spin cycle
solution- ID- is in the control program and the door lock. If, there is any warrenty on it, call Whirlpool and a Tech can help you with it.
Sep 10, 2012 | Whirlpool WTW6400SW Cabrio Washer
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Having trouble with my whirlpool cabrio . . . showing "DU" . . .
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa!
Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Lid won't lock when going to wash.
Door Lock Failure
dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from
extending.
Machine/motor control detects open door lid switch when
attempting to lock.
lid is in a locked state.
Door Unlock Failure F-83
retracting.
unlocked state.
Sep 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
362 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
