Question about Furniture
Where can I find a PCB6111K2 control board for my wine cooler ?
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
mrbobfixit
  • 259 Answers
SOURCE: Are red wines stored on the top or bottom of the
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Posted on Jun 14, 2010
  • 1891 Answers
SOURCE: kenmore wine cooler 13485 spill wine in the top not cooling
if suction line is warm and pressure line hot . sounds like comp is trying to do its job / ck the fans and they may be slow or not going . spilling of the wine did not cause problem . .. but now is the time to correct the problem .. mm / ps if unit is running like you state the you might look at the ref charge . as it may be low . mm . hope this hs helped . feed back pls .. mm
Posted on Jul 22, 2010
Sea Breeze
  • 4654 Answers
SOURCE: I need to know where
Number 19 in this photo is the control boards location=> HVTS18DABB Parts Breakdown
and if you need the user manual click here=> HVTS18DABB User Manual Please rate this if helpful and should you have more questions please ask, Thanks Sea Breeze
Posted on May 10, 2011
  • 12 Answers
SOURCE: looking for the mother board
go at sears go to this address http://www.searspartsdirect.com/partsdirect/index.action?pop=flush
and good luck with the repair
Posted on Jun 03, 2011
E1 error code LFWC38F6LS
Good Morning Chris,
I see that you are receiving an E1 error code on your wine cooler, model# LFWC38F6LS, even though your wine cooler is still working. This could possibly be a false error code, caused by a miscommunication between the different control boards inside your appliance. I suggest resetting it by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes. If when you bring power back to your wine cooler, you are still receiving the E1 error code, I suggest contacting either the manufacturer or your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Mar 18, 2014 | Frigidaire 38-Bottle Two-Temperature Zone...
Magic Chef Wine Cooler Model #MCWC50DBT will not hold correct temperature. Temps fluctuate between about 45 to often 70 degrees F. Also, often get an "EEF" error message.
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
Aug 10, 2013 | Haier BC112G Wine Cooler
How to replace thermostat on Haier BC-112G
First lets find out why you want to change the thermostat.
  • The 112G has a control board & temp sensor
If you are having problems try replacing the sensor first then the control board.
Link to the parts breakdown page:
http://service.haieramerica.com/Models.aspx?CID=226#
The sensor is $4.76 & the control board is $26.81.
good luck,
dan
Feb 01, 2012 | Haier BC112G Wine Cooler
I have a e4 code on my wine cooler
I am sorry to hear regarding the trouble. This is a common problem on this unit. E4 refers to a faulty control board failure. Unplug the unit for few minutes, say 15 minutes and then turn it on. If this would not reset the error code, the only solution is to replace the board.
I wish i could have a better solution.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 30, 2011 | Danby DWC283BLS Wine Cooler
I need to know where the board RF-5210-56 is located on the wine cooler model hvts18DABB
May 09, 2011 | Haier HVF042 Wine Cooler
Wine temp on Haier wine cooler BC112G went to LL, opened up and some champagnes frozen, other wines very cold, condensation all over door, how do you fix this error?
The error is likely caused by a bad temperature sensor. The control board may still be Okay.
Replacing both of them is recommended.
Check this link for parts: http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/BC112G.aspx
Dec 31, 2010 | Haier BC112G Wine Cooler
Can't change the cooler's temperature? the temperature reads LL and its very cold.
LL is an error code which means that it is too cold. Surprised that it didn't freeze something. Problem is likely the thermostat ($15 - RF-7350-55) or motor control board ($50 - RF-0668-04).
Nov 21, 2009 | Haier BC112G Wine Cooler
Danbysilhoutte
sounds like you need to replace the control board, i believe there may be two parts here - if there are, try replacing the power control board before trying the electronic control piece... this is the board that has the low and high voltage circuits and relays.
May 18, 2008 | Danby DWC283BLS Wine Cooler
Danby wine cooler repair
call Danby at 800 263 2629, you can order parts from them
May 10, 2008 | Danby DWC283BLS Wine Cooler
Furniture Logo
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
