Question about GE Microwave Ovens
I have a GE Microwave Space Maker XL1400. Has 2 lights. Changing one bulb it broke off. Electrician removed the remains. Taking out the second light it blew out. Replaced with new bulbs and still no light. The rest of the unit timer, on-off and the heating unit work fine. Is there a switch or fuse that blew? If so where is it? and how do I replace it? Also type # of replacement bulbs. Thanks! Joe Fields
    Top Expert:
  • GE Master
  • 21,286 Answers
Probably the sockets need the lamps fitting properly if they are not damaged.
Posted on Aug 01, 2017
MicrowaveSvc
  • 9047 Answers
SOURCE: Under Hood Light, bulb is fine (brand new)
This is a problem with the control board, which we commonly repair for $32.50. This is caused by not disconnecting the microwave from the power line when removing or installing a bulb. Feel free to e-mail me at _ for more information or visit _ for full details.
Posted on Sep 15, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: Lights under the microwave won't turn off
The problem is in the control board of the microwave. We repair these circuit boards nationwide for this problem for only $32.50. For more information you can do a search on Yahoo.com (not Google) for: microwave circuit repair It's a good idea to also send a copy of the technical note sheet from inside the oven when you send the assembly in for repair. This problem is caused when the bulbs are disconnected (or blow apart from) the sockets while the power is on. Power should always be disconnected before replacing bulbs, but sometimes they just fail on their own and short, causing them to "blow" like yours did. Also, be sure to avoid cheap bulbs, as we feel they have less chance of shorting and may hold up better.
Posted on Dec 04, 2006
marked
  • 6487 Answers
SOURCE: panasonic genius microwave light bulb
Yes definitely that should be working fine again since it only stop working when the bulb blew,so go ahead and replace the bulb so you can use it again...
Hope that helps.......
Posted on Aug 27, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: JVM1460 surface light problem
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 02, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Ge Eterna Model Em0300 HBB01 under neath light
Please unplug the oven first!
This is pretty common and can be a pain. It's tacked in place with hot glue, and sometimes there may have been enough moisture to corrode and seize up.
You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
You may be able to put the tips of needle nose pliers inside the broken bulb's socket, gently but firmly force the pliers jaws apart and then rotate the pliers to loosen it.
Another cool trick is to put a big glob of hot glue on the end of a stick or dowel, then shove it into the broken base and let it cool about 5 minutes, then turn the stick.
I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
Once you get new bulbs in it, please let me know if you the lights are still not working. This is usually a problem on the control board that can be easily repaired.
Posted on Sep 16, 2008
The light and fan on my ge space maker microwave wont work but the microwave oven works fine
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
Aug 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How to change light bulbs in ge space maker 651b267p3
Unplug the unit and remove the outer cover. That should get you to the lamp. Be careful not to touch the high voltage area, it may still hold a charge.
Aug 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The vent fan and surface light do not work
1. Check your circuit breaker for this m/w. Reset it.
2. Microwaves usually have 20A fuse inside. It could be broken.
Dec 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker XL 1800 undercabnet microwave
Remove the light cover /filter opening.Its very easy to remove.The filter will be removed by hand and may give you the best reach.
Please rate this !!
Sep 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Hood lights
first remove mains cord from main power. and remove the microwave oven top cover and check the bulb and crefully remove the old bulb and put new bulb. at high voltagae section dont touch any thing ,that area very dangerous ,thats why very carefully work inside the microwave oven ..
Sep 09, 2007 | Goldstar MV-1320W/B Microwave Oven
Broken light bulb
First of all, always disconnect the oven from the line before you remove or install bulbs, otherwise, you can damage the control board. We repair them all the time because of this. You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 We have critical safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 21, 2007 | GE JVM1430 Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
