Question about Microwave Ovens
Kitchenaid oven reset
How do i reset my oven ? it wont heat above 260.
  • Microwave Ovens Master
  • 9,098 Answers
<font face="Arial">A hard reset is to unplug the unit for a minute or so. Then
plug it back in, set the clock and try again.<br>
.<br>
If that doesn't work, leave it unplugged for about 5 minutes.<br>
.<br>
If you still have trouble, I would suspect a failed thermostat or thermistor.<br>
.<br>
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">
You can find links to helpful exploded view diagrams and order parts
<a target="_blank" rel="nofollow" rel='nofollow' href="http://tinyurl.com/gv383">here</a>.</span><br>
.<br>
I'd recommend that your bookmark this link to your favorites.</span></font><BODY>
Posted on Oct 17, 2013
My daughter had a builtin oven installed and they removed her microwave that was above but separate from oven. They replaced it and now it doesn’t heat. Turns on but I heat. The guyscameba k today and said...
have it inspectied my a real company . if it was wired wrong, such as the oven was 220 volts and the microwave was 110 volt they tried to split the 220 down to 110 and wired it wrong. my question is was there a oven there before, if not did they run new wires for that oven . 220 volt needs 4 wires to run it , to be right. It sounds like 220 was put to the microwave.
Mar 01, 2018 | KitchenAid Microwave Ovens
I made popcorn last night and my microwave worked perfectly. This morning it will not heat a cup of coffee. What's up with that? What can I do to fix it. It is part of a matching set. Kitchenaid micro over...
When unplugging it for half a minute or so (this should reset all settings) won't help, it must be defect. When you are convinced you did press the right buttons and you are in the correct program you don't need to unplug. But for that you have to be sure it is not switched to oven. In 30 seconds it won't be warm enough to heat your coffee
Mar 10, 2015 | KitchenAid Microwave Ovens
Convection wont work
We could probably help you if you would repost this with the full model number from the tag in the cooking cavity or elsewhere on the oven.
Excellent job on detailing the symptoms though!
Just be sure to include them in your repost, too.
Jun 05, 2013 | KitchenAid Microwave Ovens
My KitchenAid Oven will not light. Any solution?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 14, 2011 | KitchenAid Microwave Ovens
Kitchenaid Superba range oven will not ignite
heatman101
Apr 26, 2011 | KitchenAid Microwave Ovens
KitchenAid Architect II KHHC2090S Stainless Steel 1200 Watts Convection / Microwave Oven. Microwave quit heating. Inverter and magnetron replaced by the repairman. Still no heat but the magnetron gets...
Perhaps the "repairman" should take another look at it. A lot of microwave ovens have an aerial that directs the energy out to the load or food to be heated.
Maybe...maybe not but worth a look behind the waveguide cover I would say.
Mar 24, 2011 | KitchenAid Architect II KHHC2090S ...
My Kitchenaid Superba kaw38avm726 microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhjjd
Nov 20, 2009 | KitchenAid KEMC377K Convection / Microwave...
Microwave wont heat food. Everything else works.
Micorwave doesn't work when the megatron tube is out. That's probably why it won't heat up. Either replace microwave or the tube. You can get the number from Sears for the megatron tube by calling customer support.
Nov 09, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid Microwave went blank
Is there a reset button or something I am not aware of?
May 20, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave Ovens Logo
24 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
