Question about Sanyo ECD-T1580DV Car Video Player
Installation this is a car cd player need too find out about the color code wireing
Cd player color code wiring panasonic cq
FYI if you remove the factory unit it will disable the cars starter and or fuel pump. The radio is tied into the security system. You shoud be able to get the wiring color codes here:
Jan 17, 2014 | Oldsmobile Cars & Trucks
Need info on wire color coding for jvc car cd player: JVC KD-G140
Try going to the crutchfield website and look for help installing stereo. they can get you vehicle specific wiring codes for free. Also, almost everey stereo has common color codes for wiring. red- switched batt. +, yellow-constant batt. +, black= ground, blue- power anrenna, etc.
If you need further help, reach me via phone at https://www.6ya.com/expert/david_f2436a37cbb50365
Apr 12, 2010 | JVC KD-G140 Car CD Player
Need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Nov 22, 2009 | JVC KD-G340 Car CD/ MP3 Player
I need the cd player wire diagram for a 1994 4runner
constant is blue/yellow or blue/black
switched is gray
ground is brown on my 4 runner thats all i i know!!
Jul 30, 2009 | Kenwood KDC-1011S
I need the color codes for a 93 bravadas stock stereo
Hello coydersavvan,
You can find the wiring color code for the '93 Bravada here.
To avoid cutting or tapping into the vehicle wiring and to make a more professional installation, you may want to consider an aftermarket wiring harness. The one located at this link appears to be the correct one for your vehicle. Scosche, Metra and other make harnesses for most all vehicles. They are usually stocked and sold by local car audio shops, places like Best Buy, and many online retailers such as www.crutchfield.com and www.sonicelectronix.com.
Hope this helps. If it does, please rate as "FixYa". Thanks!
Jul 10, 2009 | Pioneer DEH-2100 CD Player
Wiring diagram color codes for pioneer 6800mp cd player
what car is going into and in what country was the pioneer bought
May 15, 2009 | Pioneer DEH-P6800MP CD Player
Need color codes of speaker connections,power connections etc...
Hi and welcome to FixYa,
Offhand. almost all Pioneer units follow the ISO standards for color coding their wires. Pls reference below:
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 15, 2008 | Pioneer DEH-1800 CD Player
Sanyo ECD-T1580DV Car Video Player Logo
13 people viewed this question
Top Sanyo Car Audio & Video Experts
Colin Stickland
Colin Stickland
xxxxxx xxx
Are you a Sanyo Car Audio and Video Expert? Answer questions, earn points and help others
