Question about Sharp LC70LE735U: Aquos 70" Quattron 3D LED
Serial#108817962 looking for pcb board part# DKEYMF733FM26
Error code E000350-0001 in ir3300
Its the serial number board. Someone swapped the main controller out and didn't change the small serial number pcb with it. That board HAS to be returned to the machine or it will not function. Only way to get a new board is through Canon engineering.
Feb 11, 2015 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Vizio e421va picture going black
POSSIBLY T-con pcb, but check the cables between the T-con & the panel & the cables between the t-con & main pcb.
Try unplugging & reconnecting those same cable links. When disconnected look at the condition of the cables & boards. your looking for signs of arcing or corrosion.
Apr 16, 2014 | Televison & Video
Repeating flash
Serial signal (reverse) error, at operation start up. Usually a faulty outdoor controller board but this one has about six PCB'S in the outdoor unit so your going to need a tech to look at it.
Jan 23, 2014 | Fujitsu Heating & Cooling
CANON IR 1600 COPIER IT WENT OFF AFTER REPLACING POWER SUPPLY BOARD STIL COULD NOT WORK UNTIL I HAD TO REPLACE MAIN BOARD THEN IT CAME ON BUT WITH ERR CODE 354 I HAVE TRYED TO CLEAR IT ALL IN VAIN
the counter PCB or the serial no. PCB is not matching.Did u got the main board with the counter pcb attached.if not then u have to get the counter pcb of the same board or attach the serial no pcb and the counter pcb of the old board . u will get it if ur a rep .if not then u have to consult one
Jun 28, 2011 | Canon iR 2016i Black and White Copier
Error code 354-0002 ir7200 serial number pcb
when you changed the main controller for the copier did you use the counter board that was on the old main controller or did you put the counter board from the old one on the new one.... if you don't use the old counter board with the new main controller then that problem will occure
May 19, 2010 | Canon imageRUNNER 7200 Copier
Canon ir2020-seystm err e354 please tel me what ido tanvir gillani
E354
•When turning ON the power, inconsistency of the serial No. of
the serial number PCB and that of the controller PCB
(SRAM)/counter memory is detected.
•When turning ON the power, it is detected that no serial
numbers are assigned to the serial number PCB and the
controller PCB (SRAM)/ counter memory.are you trying to change the counter board this not possible bec the serial no of the machine is embedded on the counter board so no counter tampering allowed
Oct 01, 2009 | Canon imageCLASS D320 Digital Copier
Samsung HD 42inch TV Model No. PS42S5H Y Board
Your board numbers should start with LJ92. They will cross to both Samsung and LG. Oh, your model number goes nowhere, double check it.
Aug 25, 2009 | Televison & Video
Error 354
E354
controller PCB (SRAM)/ counter memory , if you are try to change the counter pcb to get rid of high meter reading this error is possible, this a security measure of canon to prevent meter tampering
Jul 15, 2009 | Canon Office Equipment & Supplies
Help me.....faster....
Errors commencing with E3---- means that something to do with the reader unit,,,, apart that error mentioned does not exist. If youhave plenty of parts that you can try out I will try to replace the reader board....
Dec 15, 2008 | Canon imageRUNNER 5000 Copier
Hp vs17e monitor
Hi...there,
That's mean you got a busted backlight inverter, Dude! Replaced a new one or repaired it. Good lucks!
Oct 06, 2008 | HP Pavilion F1703 17" LCD Monitor
Sharp LC70LE735U: Aquos 70" Quattron 3D LED Logo
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
