Question about Mtd Garden
Blades wont engadge belts on - Mtd Garden
    Sergeant:
  • 224 Answers
This would be either the clutch relay, pto switch or pto clutch, check the relay first, then the pto switch, and lastly, check the clutch, if the clutch tries to engage with switch, then the switch and relay are good, and the clutch will need adjusted or replaced
Posted on Oct 17, 2013
Cant get blades to full RPM replaced all idlers all belts greased spindles new elec. clutch new blades when cutting grass it leave rows of uncut grass
if the blades wont get up to speed or not cutting grass you have a belt that is slipping. could be the pulley is damaged or just a worn out belt. if it is leaving a strip of uncut grass you have a blade that is wore down on the ends not cutting the full path
Aug 05, 2017 | Garden
Mower blades won't engage
Did the smoking stop when you disengaged the blades? If so it is most likely your belt that is smoking. Make sure all the blades turn freely by hand to ensure you have not hit anything that may have bent a shaft on one of the blades. If one of the shafts is bent and wont turn FREELY, the belt driving the blades would slip and start smoking as it tried to turn them.
Apr 19, 2015 | Garden
Scag turf tiger 61"
Check switch with ohm meter.
May 21, 2014 | Garden
Were does the cable hook on the deck that engages the blades
you have to give more info
If its a manual engage the lever tightens up the belt by sliding a pully against the belt
If its an electric pto it has an engadge button and that powers up the eltric pto wich inturn runs the belt
Jul 26, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Runs but when u engadge the blades it dies
I would try bypassing the safety switch on the mower at the bottom of the blade control stick. It's meant to prevent starting the motor with the blades engaged but it or another safety switch can be bad. You may have one for reverse, the seat and brake.
Jul 28, 2010 | Yard Machines MTD Gold 20 HP Lawn Tractor...
My 1992 saturn sl2 wont go into gear when i let up on the cluch its like it doesnt in engadge and wont move? what could the problem be?
Most Likey It's a clutch problem or I have seen a axle shaft broken in between the rubber damper on the axle shaft.More than likely a clutch concern.
Sep 22, 2009 | 1995 Saturn Sl
My blades wont engage and just hear click sound?
No permanent solution, but you probably can get by once by "riding" the clutch engagement lever - pushing it only part way forward and holding onto it.
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
122 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
