Question about Ash-Rain-Oak Clothing
Trying to find fleecy wool-and-polyester zip-up as seen in Real Simple magazine.
We purchased a Real Simple Solution 6-cube storage unit and the instructions are missing.
Hello, Nancy -
If you purchased the storage unit at a store, I suggest you contact the store Customer Service department and ask about how you can obtain the assembly instructions.
Right now, contact information I have been able to find for Real Simple relates to subscriptions to the magazine. I will keep on looking and relevant information if / when I find it.
Added:
I still have not found information on what company / companies manufacture storage units for Real Simple. Therefore, contacting the store where you purchased the 6-cube storage unit seems to be the best route to follow.
Jan 10, 2018 | Furniture
Tip
Remove bloodstains before washing
I take a medication to reduce clotting which means a scratch can bleed for a while. If not noticed and washed straight away it is very difficult to remove. Sodium Hydroxide solution aka caustic soda will remove dried blood from white cotton sheets before washing. It is the main constituent of oven cleaner/ drain/plug hole cleaner. Test before use but note it will remove printed patterns so only use on plain fabric and only on cotton/polyester-cotton/nylon/polyester especially not wool or silk. Use rubber gloves and avoid splashing, wash off skin/eyes immediately if affected. It also dissolves rusty stains and others of a "biological" nature.
on Feb 01, 2015 | Washing Machines
Hi I need to sew a fleecy backing to a crochet item which settings do I need for the wool not to strech? Thanks
I would put the fleece on the bottom. pin the wool item to top with pins fairly close together so it says where you want it. sew with the wool side up and use a normal stitch setting but go very slowly and tuck the wool bits under the sewing machine foot so it does not get caught on a loop of wool. remove the pin just before you are going to sew over it and it should keep your wool centered on your fleece. hope this helps good luck.
Jun 14, 2017 | Sewing Machines
When i do a white wash some items come out with dark stains on them
Fabric softener will stain man-made fibres such as 100% polyester, and should only be used on natural fibres, ie, wool, cotton, linen.
Aug 08, 2014 | Daewoo Washing Machines
Winzip activation code
You dont need to steal Winzip,
Try a free program instead.
Look at this PC World Magazine article on free zip programs. Theres links to get them there too.
http://www.pcworld.com/article/2049053/5-free-compression-tools-zip-your-files-just-dandy.html
Jul 09, 2014 | WinZip 12.0 - Windows for PC
Is the whaley haunting true
There is of course a Whaley House (but not the one seen in the movie), and Life Magazine called it "the most haunted house in America".
Whether it is real from that point, well, do you believe in ghosts?
Feb 21, 2014 | Sanyo 7200W Solar Grid Tie System - 32...
Blue screen no image
simple things first---unplug set and a box from power if use one for a while, replug and see what happens, a power disconnect and reconnect will have a chance to reboot.
I have seen several times where a glitch with a box will confuse the set itself, know it sounds silly but I have seen it and not real hard to try.
Dec 04, 2012 | Televison & Video
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
How to use the dryer?
This should be simple and will not need a user manual. For silk, polyester, nylon, wool and delicate fabrics that dryer setting knob should be set to "Less Dry" or similar settings and then press on the start knob. For cotton, use the "More Dry" Setting. Now, these settings may vary between models. I am more familiar with the Whirlpool ones. Gook luck.
Aug 30, 2007 | Hoover Nextra HNWF 3135 Front Load...
Clothing Logo
77 people viewed this question
Top Ash-Rain-Oak Clothing Experts
ray gallant
Da Doc
Bill Boyd
Are you an Ash-Rain-Oak Clothing Expert? Answer questions, earn points and help others
