Elfunk 37781 fhd
On My elfunk 37781fhd the screen sometimes goes partly black. I can see the picture behind the black fields. Of i tap the back wall
5 Suggested Answers
  • 7 Answers
SOURCE: 42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Posted on Jun 07, 2008
  • 308 Answers
SOURCE: Picture goes black on bottom half of the screen
You have a bad connection to the panel or bad caps on the boards. Not something for the DIY'er. High voltages in plasma sets.
Posted on Mar 31, 2010
gopakumarg43
  • 74383 Answers
SOURCE: Sanyo 24 in flat screen
Hello
Your flat panel TVs picture tube base board has soldering loose contact with it. Just unplug your TV from AC mains socket, and open it. Pull out the picture tube base card from the picture tube neck. Pull it out straight, no shake must be there, as it will damage its connecting pins.
Normally, loose sodering are very difficult to loacate, as they will be quite micrscopic in size. Just resolder all the suspected loose sodering point on that board, by applying a little more solder. This will solve your TVs problem. OK.
Posted on May 26, 2011
Testimonial: "Going to try resoldering all the connection,as you stated only seam logical if hard to find, do them all. thank you. PS. I was not thinking..."
  • 517 Answers
SOURCE: I have a Sony CTV
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Sep 02, 2011
Haft of the screen is black.
Most likely, it is some capacitors in the inverter or power circuit that is dying. Check out http://www.fixya.com/support/r7406380-tv_training_manuals
Dec 16, 2012 | Sceptre 46" 1080p Lcd Hdtv X460bv-fhd
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
Turn the TV on and a minute after the picture comes on the picture scrunches up to the top of the screen and colors are distorted. It the goes black. I turn the TV off and on and the picture is sometimes...
try to tap your tv slightly at the side if it go back to normal operation you have a weak solder commonly in the main board try to resolder parts that is slightly hung.
Oct 15, 2010 | Sony Televison & Video
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
Screen goes black
here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
Sep 08, 2017 | Televison & Video
No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Aug 25, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Jun 03, 2008 | Philips 42FD9954 42 in. Plasma HDTV
LCD screen goes blank and computer stops functioning
This must be a loose connection on the lcd behind the lid or in the hinge, I would not atempt a repair, laptops are a nightmare, take to a specialist repairer.
Nov 27, 2006 | IBM ThinkPad T42 Notebook
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
