Question about Isuzu Electrical Supplies
Location cam sensor diesel - Isuzu Electrical Supplies
emissionwiz
  • 77202 Answers
SOURCE: Where is the cam sensor on a 7.3 diesel 1996 f-250 4wd pickup?
To fix it, your going to need a 10mm wrench (or socket with a short 3" extension, experiment at
home to find the exact tool you think you will need if stranded on the side of the road,
at night, in the cold and rain). A flathead screwdriver, and a replacement CPS. Ideally, you should use a 6-point tool, as the CPS bolt is known for rounding off. Locate the CPS. It is on the passenger side of the engine block. Accessible from under
the truck, and located about the 10 o'clock position behind the crankshaft front pulley.
Reach up and unplug the wiring harness, remove the 10mm bolt, and GENTLY pry the bad CPS
out with the flat screwdriver.
Posted on Apr 22, 2009
  • 412 Answers
SOURCE: i have a 2001 dodge 24 valve diesel and need to
it is located below the fuel injection pump in timing gear housing..not easy to get at..1 bolt and electrical connector..goes in from behind into housing..injector pump is unit with all the fuel lines coming out of it..have replaced these sensors before
Posted on May 21, 2009
  • 21 Answers
SOURCE: Where is the cam shaft
should be on the back of the timing case behind the cp3 pump above power steering pump
Posted on Sep 04, 2010
cansmo
  • 2431 Answers
SOURCE: where is the cam sensor
cansmo_123.gifIt is located below the fuel injection pump attached to the timing gear cover
Posted on Aug 28, 2011
jeremydogg
  • 14 Answers
SOURCE: Where is cam sensor located on 1994 Chevrolet 6.5 diesel?
Go to advance auto parts or a smimlar store and ask for the Hayes or Chiltons (not sure I spelled that correctly) for that make/model/year and look in the section on Engine/Timing. Or try and figure out what kind of engine it is, and google that (For example, instead of looking for "Firing sequence for a Chevy cobalt 2005" one might google "Firing sequence for Ecotec 2.2L L4) and you might get better results. I know this doesnt answer your question, but it gives you an idea of some new places to look.
Posted on Mar 13, 2014
Can anyone please tell me where the cam sensor and crankshaft sensor are located on a 2002 RAV4 2.0 D4D...116BHP Problem is wont start when engine is hot.
this a diesel. (our is 2.4Lgas(petrol)
cold starts fine,runs perfect cold RIGHT?
common rail system.
the PCM will tell you when those are bad, cranking for 5sec or running.
does your run,. ? if yes for get them. and scan engine PCM.
some sensor takes major work to reach.
get the FSM on that car. y
so get the FSM for your car, your engine and your country
The DI chapter covers this. read that yet? diagnosis?
did you use the scan tool an see what up's up or not ?
your engine really is.
1CD-FTV I4 (diesel)
that is the correct name, so study only that)
no start hot.
its too much fuel or tool little?
to little?
did you try test fuel to see if loss of fuel is the problem?
on diesel it's poor compression
or lost fuel , hot starts.
easy huh , no spark to check , there is no spark
some diesels have 1 sensor for injector timing.
if flooding , you get black smoke out the tail pipe, so id suspect
you'd have noticed that and did not see it.
test fuel, tests.
if this fails, a full hot compression test. its not the cam belt slippped
if runs ok cold,
i bet the injectors are shut down
the PCM tell you why, so let it.
SCAN it. after 5 seconds cranked.
almost all PCM report 1 bad pulse of 10 in all speed sensors.
(CKP or CMP )
Feb 24, 2014 | 2002 Toyota RAV4
Camshaft sensor location
look on the rear of the camshaft bearing area or near the cam drive sproket..
Dec 14, 2013 | Ford Cars & Trucks
What dose the crank sensor control in a 96 dodge diesel
The crank sensor on the truck works with the camsensor the crank sensor uses the cam to synchronize and identify where number one piston position is at. It is responsible to fire you injector and for how long is determined by the cam position sensor. On a 96 Dodge diesel the crank sensor is also responsible for you tach reading,your air condition ,and for the alternator.
Mar 06, 2012 | 2008 Dodge Ram Pickup 2500
Where is the cam sensor on a 1999 dodge ram 4x4 turbo diesel located
Aug 28, 2011 | 1999 Dodge Ram 2500 4WD
Truck stalls after running for a while....cam sensor changed already and oil pressure sensor changed also...fuel pump is workin fine....what else can i do?
you stated you changed the cam pos. sensor, meaning it must be a 7.3 or 6.0 turbo diesel. These engines are extremely sensitive to low fluid levels and failing sensors, first i will suggest for you to check and top off all fluids wich include antifreeze and oil above all. if those are within range, proceed to check the injector control pressure sensor located in the driver side of the engine towards the front.
Nov 18, 2009 | 2002 Ford F250 Super Duty SuperCab
Where is the cam sensor located on a dodge v10
It is located under the injection pump but you may have to pull the pump to get it it a tight fit.
Sep 21, 2009 | 2001 Dodge Ram 2500 Truck
2005 ford excursion cam sensor location I need to change the cam sensor and the crank sensors on my excursion and i do not know where they are located
On my 02 Excursion with the 7.3L Diesel, the Cam Position Sensor is located at the front bottom of the engine on the passengers side. There is one electrical pigtail plug that is attached and one bolt holds the sensor in position. It may be located in a similar location on your 05 Ex. I do not know where the crank sensor is located. I hope this helps.
Aug 27, 2009 | 2005 Ford Excursion
I have a 2001 dodge 24 valve diesel and need to replace the cam shaft sensor, i bought the sensor but cant find where it is on the motor. where is the cam shaft sensor located on the motor?
Apr 30, 2009 | 2001 Dodge Ram 3500 Truck
Where is the cam shaft sensor located
it is located`on the engine, under the power steering pump
Dec 11, 2008 | 2006 Ford F-250 Super Duty
Ford F450 6.0 Diesel
Under the ft driver side bumper locate power steer line and pump above line is sensor in block has two wire plug one bolt 8mm. long socket with short ext 1/4" drive should do it. has o-ring so may be a little tight after getting bolt out. about as long as pen, pull out ,put new in connect wire.
Jul 01, 2008 | 2005 Ford F 350 Super Duty
Electrical Supplies Logo
13 people viewed this question
Top Isuzu Electrical Supplies Experts
Steve
Gene Haynes
Are you an Isuzu Electrical Supply Expert? Answer questions, earn points and help others
