Question about Breville BKC600XL Coffee Maker
My machine has no power. It will not turn on and no lights are lit. I moved it to another outlet to ensure that was not the problem. It almost seems like it blew an internal fuse.
Machine want turn on T7Si.
1. Check outlet.
2. Check the connector on both ends.
3. Is the light bulb lit on the machine?
4. If bulb is lit and you can't get it moving then check all areas that is normally set for rewind of bobbin.
5 If you hear the motor moving but there is no movement of needle or the bobbin winder you may need to replace the motor band or adjust it.
Aug 08, 2016 | Sewing Machines
I just plugged in my sewing machine into a new apartments socket. This machine has always worked. I smelled a strange odor, and went to get scissors. When I returned the machine was completely dead. Did...
1. Have you tried it in another socket? Check the light bulb to ensure it isn't rubbing against something (smell).
2. After you try the machine in a new socket make sure the on/off switch is set to on. Is the bulb lit? Replace it if not. Also, check the outlet with something else electrical to make sure it is working.
3. Make sure the cord is attached securely to the machine.
4. If these checks hasn't worked your next move is to go to your repair shop.
Mar 20, 2015 | Sewing Machines
Washing machine drum not turning
Most likely it has a small gearbox with a nylon bushing that has stripped out. I'm not sure that you can get just a single part. Remove the gearbox and replace the assembly.
Mar 02, 2015 | Beko Washing Machines
HOW DO I FIX MY SAMSUNG FLAT LCD SCREEN ?? IT WONT TURN ON AND THER IS A LIL RED LIGHT FLASHING IN THE FRONT OF IT
How old is the set The older models suffered from problems with the electrolytic capacitors in the power supply . No point in trying another power outlet or cable if the standby light has been flashing red . Power is obviously getting to the set if the standby is lit .
Has the set been a little slow staring from cold lately
Jan 03, 2015 | Samsung Televison & Video
Krups wont turn on
Check circuit breakers more than likely one is tripped .check a gfci- outlets . A lot of times kitchen outlets are tied in to ground fault recepticles. Commonly called gfci 's. If it has a light on it that is lit up press reset button. If it clicks and stays lit it's bad and needs replaced.
May 26, 2014 | Krups Coffee Makers & Espresso Machines
Machine stop running
Make sure all power connections are in place, to outlet and to machine. Make sure power switch in ON.
Check outlet with working lamp to ensure power is coming to that outlet; check panel box to make sure power is coming to that outlet.
Aug 27, 2013 | Singer 2259 Sewing Machine
My LG LCD 32LD350 seemed to have been fried in a storm last night, stanby red light no longer lit and won't turn on, still see some green lighting inside televison, but it won't turn on, Is it
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | LG 32LD350 32 in. LCD TV
My ten year old Health Rider s300i has no power when it is turned on. How much would it cost to replace the power pack and would it be worth the time and trouble to try and fix it.
First be sure there is power at the outlet. Check that the power switch is on, and the circuit breaker is not tripped (beside the power cord).
Remove the hood and inspect the wiring. (unplug the machine first). Ensure that all connectors are tight and none are burnt. At this point if all appears to be OK, look for lighted LEDs on the power PCB. If all is dark, replace the power PCB ( approx $100). If the LEDs are lit, you may require a console, or the safety key switch might be defective. To check it, the console must be removed and the console base removed. Inspect and test the micro switch.
The console is no longer available.
Dec 18, 2010 | HEALTHRIDER S300i Treadmill Motor Control...
Dell e137fp monitor flashing green...
Below you will find my recommendations for troubleshooting this issue:
1. Reseat the power cord and verify a good power source.
To reseat the power cord, follow the steps below:
1.1 Power down the system.
1.2 Unplug the power cord.
1.3 Wait approximately one minute.
1.4 Reseat the power cord.
1.5 Verify that the power cord is plugged directly into a known good power outlet.
2. Verify that the monitor is receiving power from a known good outlet and bypass any power strips.
To test the power outlet, perform the following steps:
2.1 Unplug the monitor power cable from the power outlet.
2.2 Plug in a different device, and verify that the device is operational.
2.3 If there is no power try another outlet. Remove any power strips and try plugging directly into the main power outlet.
3. Verify the monitor is powered on and the power button is engaged.
Ensure that the monitor is powered on and that the power button is fully engaged. To do so, check the power LED on the front of the monitor; it should be lit.
NOTE: There are two types of power switches:
A mechanical switch characterized by a long travel. You have to push it further and you will hear an audible click.
An electrical switch that has a short travel and almost no click.
A lit monitor LED can be any of the following:
* Green
* Blinking green
* Yellow
* Blinking yellow
* A combination, such as alternating green and yellow
Any of these states indicate the monitor is receiving power and that you should proceed.
4. Swap power cables.
To try a known good power cable on the monitor, follow the instructions below:
4.1 Turn off a working monitor.
4.2 Unplug the cable from the back of the working monitor, and unplug the cable from the wall.
4.3 Unplug the cable from the monitor in question.
4.4 Plug in the cable that came from the working monitor.
5. Run the monitor self test.
To run the monitor self test, perform the following steps:
5.1 Power off both the computer and the monitor.
5.2 Unplug the video cable from the computer or video card.
5.3 Reseat the power cord to the monitor, ensuring it is plugged into a known-good outlet.
5.4 Power on the monitor.
NOTE: The monitor self test will move around on some monitor models. If the monitor self test moves, allow it to move to the affected areas of the monitor to check for the problem described.
If the Self test failed, it's possible that the monitor is faulty. Contact dell to check if it's still under warranty so they can replace it.
Jun 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Unfixable?
all lights are flashing
the printer may need to be restarted
1. Press the Power button to turn off the printer, then press the Power button to
restart the printer.
Proceed to step 2 if the lights continue to flash.
2. Press the Power button to turn off the printer.
3. Disconnect the printer's power cord from the electrical outlet.
4. Reconnect the printer's power cord to the electrical outlet.
5. Press the Power button to turn on the printer.
If these steps do not work. It will need service, as a bad board may be the problem.
Here is the manual.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=304431&cc=us&lc=en&dlc=en&product=304431&dlc=en&lang=en
Nov 09, 2007 | HP DeskJet 5150 InkJet Printer
Breville BKC600XL Coffee Maker Logo
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Delierious
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
