Question about HSM SECURIO B32 Shredder
How can I clear a paper jam on a hsm securio b32 shredder when the reverse function does not clear it
  • 221 Answers
On most shredders ideal unjamming would be by trying the reverse, if that fails there's 2 options: 1 - opening the unit by removing screws (usually 5) and using small narrow flat screwdriver carefully clearing out all the stuck paper/cardboard from in between two rollers, but be carefull and make sure the power cord is NOT plugged into wall socket. 2 - without dissassembling the unit spray some WD-40 into the shredders feed opening and let that cardboard soak for a while. WD-40 will soak into cardboard and any stuck paper and will loosen it, you might need to spray couple of times allowing to soak in between sprays, but this definitely does the trick. Once sprayed 2-3 times allowing to soak for at least 10 minutes between sprays simply swich the shredder on and use reverse and all stuck paper should come out. Be advised after unit was cleared you must use some spray oil to protect the blades. Once oiled allow unit to run in reverse for at least 2 minutes, the swich it off. 15-20 minutes later your shredder will be good as new!! Hope this helps ;)
Posted on Nov 03, 2013
4 Suggested Answers
  • 35 Answers
SOURCE: HSM 125.2hs Begins feeding then stops
There are three things that cause this problem.
1. a gear is broken which will cause only one cylinder to rotate.
2. on the non-driven side (opposite side of the gears) there is a electromagnetic sensor that rotates with the shaft. It detects rotation and overload. If this is out of place or damaged it will cause this symptom.
Posted on Feb 24, 2009
  • 45 Answers
SOURCE: hsm 225.2 jerks in & out 2-3cm and wont eat paper!
try oiling the cutters...this helps out with the shredding of paper...also make sure properly mounted on bin, try resetting the shreddar, unplugging it and then plugging back in...check to make sure no paper or anything stuck in shreddar and make sure no broken gears..if this doesn't work and your shreddar is under warranty it would be a good time to call the warranty company
Posted on Apr 16, 2009
  • 41 Answers
SOURCE: Where can I buy gear wheels for a HSM 125.2 paper
cooksmobileshred@bellsouth.net 901-565-8188
Posted on May 10, 2010
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Shredder is jammed and I've removed as much paper as I can. It won't go forward, or in reverse.
check and mak sure the eye is not blocked this will happen more if you use a paper that has a sticky back
Oct 24, 2013 | HSM ShredStar X5 Shredder
How can I clear a paper jam when the reverse function does not work
Oct 16, 2013 | HSM SECURIO B32 39mm shredder
The shredder is totally inoperable
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Sep 17, 2013 | HSM Office Equipment & Supplies
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
Hsm 225.2 jerks in & out 2-3cm and wont eat paper!
Apr 13, 2009 | HSM 225.2hs Shredder
Sep 16, 2008 | HSM 125.2hs Shredder
HSM SECURIO B32 Shredder Logo
176 people viewed this question
Top HSM Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
ray gallant
ka4iup
ka4iup
Are you a HSM Office Equipment and Supply Expert? Answer questions, earn points and help others
