Question about Electrolux Dishwashers
Damper vents getting an error 4. How do I fix this?
    Problem Solver:
  • 14 Answers
Hello.
I own the Electrolux EWDW6505GS--0 {24'' Built-In Dishwasher with Wave-Touch® Controls}
On two occasions I have had the "Error 04
Drying Damper - Drying damper not operating"
In each case, I found the plastic 'ring nut' RETAINER in the upper right top of the machine had come loose. I simply unscrewed the retainer, wiped the area down, and re-screwed the ring on hand tight.
Sincerely,
Patrolcats
Here is a picture of the retainer;
A new retainer part (if it is broken) may be ordered here at the RepairClinic;
Electrolux Dishwasher Retainer 154622601
Use & Care Guide
http://manuals.electroluxusa.com/prodinfo_pdf/Kinston/154671101en.pdf
Service Data Sheet
http://manuals.electroluxusa.com/prodinfo_pdf/Kinston/154676601.pdf
[img alt="repairclinic.com" src="http://i.fixya.net/uploads/images/embeddedlinks/1590384-repairclinic.jpg?2.0" >
Electrolux Dishwasher Retainer 154622601repairclinic.com
Retainer 154622601 Order now for...
Posted on Jan 04, 2015
  • Official Brand Answer
  • 4,342 Answers
Hello Erica, thank you for allowing me to assist you!
Typically error code E04 indicates that there is a failure with the drying damper. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it would be advisable to have a professional check the wiring between the main control board and upper fan since either part could need replacing.
Posted on Nov 01, 2013
What caused heat to stop working?
same answer on all cars. nice photo, so rare here, shocking that.
in order,......
1: sure the blower must blow.
2: the engine must get to min. 180F , if not, thermostat bad in engine.
3: ok, engine is hot, so the heater core must get hot next. it has 2 hoses, we feel them with hands, are both hot?, yes, then the core is most-likely hot. (inside) (if not core is packed in gunk inside)
ever do 2year cooling flushes< (oops. zero service lands you here)
4: the controls must open the dampers, if not? bad controls
5: if the controls work and dampers fail, then the dampers are bad.
all answers assumes , cooling system full to top of RAD.
your car uses 3 damper motors. (electric)
that operate them by controls
the motor for temp is called temperature actuator motor.
the controller is called HVAC controller
did you scan the PLC to see if HVAC controller has errors.
the controller needs fuse 15 good. Cab fuse box ."hvac-rfa"
the controller use a network, data comm .
if you scan the PCM and it tells you the HVac comms are dead
what do you know? (means you cant fix it)
its not just a simple switch like in 1990 (gone)
its all computer controlled now.
check fuse first
scan 2nd.
like we do on all modern cars, or , its all just a guessing game.
Feb 14, 2016 | 2008 Suzuki XL7
How do I bypass my Honeywell D896 vent dampner?
The furnace was probably originally equiped with a damper bypass plug that was removed to install the vent damper. Of course some were hardwired in as an accessory. But look inside the furnace vestibule or in the homeowner instruction envelop and see if the original installed tossed the plug in there during installation. That would be GREAT !!!!
Without the wiring diagram of the furnace AND the vent damper, I cannot give you specific input on the wiring. But the damper has to have 24v to operate it and there has to be a switch circuit for making and breaking the gas valve control circuit.
You may have to call a service company to get your issue safely resolved.
Dec 29, 2014 | Honeywell Heating & Cooling
Ac vent selector wont swich
not sure why you want to bypass it , this gismo moves damper under dash to allow wether you get cold or hot air out of vents depending on what you select on dash control (hi /low vents) if theres a problem with it most times it comes from ac condensate collection pan drain clogging up and water spills over into duct work rusting the damper shafts making it impossible for damper movers to move them , producing a fault or hot or freezing cold air all the time , sorry no easy fix for this but removing underdash ductwork and cleaning / replacing them lots of hours upside down with your feet on seats and head under dash , just kidding ...... most times we just take front seats out that makes plenty of room
May 13, 2014 | 1994 Buick LeSabre
Cant get enough airflow to defrost windshield fans blowing max
Either the damper door is not redirecting air flow OR your air duct clogged with debris. If you get great air volume thru all the other vents I would believe the problem is with your damper not functioning properly.
Jan 25, 2012 | 2002 Kia Spectra
Car window defrost
CHECK VACUME HOSES UNDER DASH
Dec 18, 2009 | 2004 Chevrolet Cavalier
Hi My extractor hood in the kitchen has a hose that goes into the kitchen roof then out through the roof vents. The problem is that all the cold and wind comes back down the hose and makes the kitchen very...
You need to install a damper. It sounds like your vent now just vents into the attic and out the attic vents. If that is the case, or even if it vents directly to a roof vent, you can install a damper that only lets air flowe one direction.
rewilliams_2068_131005279
springload.gif Here is just one source of many that you can purchse dampers from.
http://www.rewci.com/416splobada.html
The damper would be installed in the exhaust duct. If your vent pipe is connected to a roofmounted vent, you can replace the vent with a dampered vent.
Aug 30, 2009 | Bosch 22 in. PCD685F / PCD685D / PCD682D...
No green light on vent damper
The damper is no longer funtioning and needs to be replaced
Dec 17, 2008 | Heating & Cooling
Damper need for Broan Range Hood
I called tech support at Broan and was told they recommend two dampers in cold climates ...one at in the wall cap and one on the unit. They make the damper,
(#BP87-7"), that attaches to the round duct plate that comes with the hood. Strangely the unit does not include a round damper and the seller LOWES did not have it, also checked Home Depot,.
The Tech said they can't get stores to stock it. I checked at a local supplier of all kinds of plumbing, heating, and cooling supplies and they only had basic 7" dampers which, I was told would probably be too heavy, and be manual. I ordered it through Amazon/True Value ($11.56 w/ shipping, shipping more than cost of damper). Tech indicated that the 2nd (unit damper) is optional and may not be needed if in a warm climate. I would suggest that Broan include the $5.00 item in their unit or at least sellers stock it.
Jun 27, 2008 | Broan-NuTone Broan Range Hood Accessory
Dishwashers Logo
364 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
