Question about QPS Q see QSZ515D Surveillance/Network Camera
Can I save an action that was recorded on my surveillance camera?
    New Friend:
    Problem Solver:
  • 5 Answers
Yes, you can.
With Surveillance Camera you can save all its recording by using an external storage. You can also set it to save all those recordings automatically.
Posted on Jun 09, 2017
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
    New Friend:
  • 14 Answers
Through dvr / nvr
Posted on Oct 21, 2013
How do I save recording to use stick
try to find backup and choose the time you need and backup the record on the stick but it must be FAT32 Format
Dec 17, 2015 | Home Security
How can I record audio onto the SD card?
what is the model of the cam?
some cams only do video
depends what its saving the file as
may be your software that wont play the audio but plays the video ok
check the codec used to save the audio
Apr 26, 2015 | SWANN Home Security
How can I delete unneeded data from the hard drive of a 'first alert' camera/DVR system?
bring up unwanted program then edit should let you save or delete there .
Jul 18, 2014 | First Alert Home Security
How can I delete data from the hard drive of 'first alert' camera surveillance DVR?
Surveillance DVRs write over the oldest data when the hard drive needs more space.
You do not need to manage that manually. It is all handled automatically by the operating system of the DVR.
HOW DO I GET MOTION DETECTION TO WORK?
Are you sure the cameras are capable of motion sensing and make sure that you do not need an additional control cable to the camera to make that work.
Jul 17, 2014 | First Alert Home Security
How do I get my Swann ADW-400 camera/recorder of of PAL mode and Back to NTSC
Connect the DVR to a monitor, go to system or camera settings, select NTSC as signal type, save and reboot the DVR.
Jan 12, 2014 | SWANN Adw-400 Video Surveillance System...
How do I use my compro ip540 surveillance camera to record a video without using my pc?
Hi~
You can use SD card to record, but SD card recording just provide motion detection recording.
If you need nonstop recording, there is only PC or NAS could apply on.
Jul 04, 2011 | Compro Technology Ip540 Ptz Megapixel...
I have a 4 gig card in my camera. the camera only records in 2 gig segments. When it switches to the second segment the video goes white and you can't see the video anymore. what could be causing this?
sounds like it is not finished processing the first video. processing power in cameras is usually pretty low, so it is probably just being overwhelmed and needs more time to finish the previous action.
Mar 06, 2011 | Midland Xtc Extreme Action Video Camera...
PhotoShop CS3 Droplet automation
Try the following steps
  1. Choose File => Automate => Create Droplet.
  2. Specify where to save the droplet. Click Choose in the Save Droplet In section of the dialog box and navigate to the location.
  3. Select the Action Set, and then designate which action you intend to use within the Set and Action menus. (Select the action in the Actions palette before you open the dialog box to preselect these menus.
  4. Set Play options for the droplet:
    a. Override Action “Open” Commands Open commands in the action refer to the batched files, rather than to the file names specified in the action. Deselect Override Action “Open” Commands if the action was recorded to operate on open files or if the action contains Open commands for specific files that are required by the action.
    b. Include All Subfolders Processes files in subdirectories.
    c. Suppress Color Profile Warnings Turns off display of color profile messages.
    d. Suppress File Open Options Dialogs Hides File Open Options dialog boxes. This is useful when batching actions on camera raw image files. The default or previously specified settings will be used.
  5. Choose a destination for the processed files from the Destination menu:
    a. None Leaves the files open without saving changes (unless the action includes a Save command).
    b. Save And Close Saves the files in their current location, overwriting the original files.
    c. Folder Saves the processed files to another location. Click Choose to specify the destination folder.
    Note: You can record an action that saves using a specified file name and folder. If you do this and deselect Override Action “Save As” Commands, the same file is overwritten each time. If you record your Save As step in the action without specifying a file name, the droplet saves it to the same folder each time but uses the file name of the document being saved.
  6. If the action includes a Save As command, choose Override Action “Save As” Commands to make sure files are saved to the folder you specified (or to their original folder if you chose Save And Close.) To use this option, the action must contain a Save As command, whether or not it specifies a save location or file name; otherwise, no files are saved.
    Some save options are not available in the Batch command (such as JPEG compression or TIFF options). To use these options, record them in the action, then use the Override Action “Save As” Commands option to make sure that your files are saved where you specify in the Batch command.
  7. If you chose Folder as the destination, specify a file-naming convention and select file compatibility options for the processed files:
    a. For File Naming, select elements from the pop‑up menus or enter text into the fields to be combined into the default names for all files. Elements include document name, serial number or letter, file creation date, and file extension. Starting Serial Number specifies the starting number for any serial number fields. Serial letter fields always start with the letter “A” for the first file.
    b. For Compatibility, choose Windows, Mac OS, and UNIX to make file names compatible with Windows, Mac OS, and UNIX operating systems.
  8. Select an option for error processing from the Errors pop‑up menu:
    a. Stop For Errors Suspends the process until you confirm the error message.
    b. Log Errors To File Records each error in a file without stopping the process. If errors are logged to a file, a message appears after processing. To review the error file, open it in a text editor after the Batch command runs.
Give it a try.........
Jul 30, 2009 | Computers & Internet
QPS Q see QSZ515D Surveillance/Network Camera Logo
177 people viewed this question
Top QPS Home Security Experts
Lawrence Oravetz
Are you a QPS Home Security Expert? Answer questions, earn points and help others
