HI MY ALPINE CVA-1003 HEAD UNIT IS UNABLE TO EVEN AKNOWLEDGE THAT MY CHA-1214 AI-NET CD CHANGER IS EVEN THERE. IT WORKED AND ALL OF A SUDDEN ONE DAY WHEN I TRIED TO USE IT IT JUST DIDNT WORK, I TRIED CHECKING THE CONNECTIONS AND EVERYTHING SEEMS FINE, AND NOW IM LOST. THANK YOU FOR ANY HELP OR SUGGESTIONS YOU MAY GIVE!!!
Hi Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine. However Error1 means Battery inside CD Changer needs to be replaced. And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer. take off the top plastic slide cover, with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position. Pop out the CD holder. Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again. grease the moving parts with light lubricant.
you have the amp remote wire hooked to the power antenna lead instead of the amp wire on the deck otherwise just hook it to a switched +12 volt source. You sure you got a DVD changer instead of just a cd changer
After you remove the outer cover, you can see a small, spring-loaded black arm under the middle of the magazine. Just lightly push it to the side, and the magazine will eject.
