I have a rheem quite 80 and heater blower fan just buzzes but doesn't come on. My question is are there any safety switches that would keep this from coming on are is the fan just bad.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
Check fan start winding or capacitor >>replace fan
Posted on Oct 18, 2013
5 Suggested Answers
  • 14 Answers
SOURCE: Williams Model 435FXR Serial GO222436 Forced air pilot keeps going out
BY THERMISTOR, ARE YOU MEANING THERMOCOUPLE, I.E. WHAT YOUR PILOT LIGHT IS HEATING? IF SO, COULD BE WEAK AND NOT GENERATING ENOUGH VOLTAGE TO STAY OPEN, SHOULD BE BETWEEN 10-25 MILLIVOLTS DC, WHICH CAN BE TESTED AT THE INTERRUPTER LEADS. YOU CAN ALSO BYPASS THE LIMIT DISC TEMPORARILY TO SEE IF THE UNIT STAYS LIT, REPLACE IT IF THE UNIT RUNS.
Posted on Jan 29, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Posted on Nov 03, 2009
heatman101
  • 43501 Answers
SOURCE: york diamond 80 heater does not fire up
Mostly likely the problem is in the pressure switch that tells the board that the blower started and it is okay to fire the burner. The pressure switch is usually a 2" or so round thing about 1" thick, it will have one or two tubes coming out of it that go to the blower or heat exchanger. Make sure that the tube is not cracked or that it has not come off at either end.
The pressure switch can be jumped out to check out if that is the problem, but you need to jump it out after the cycle has started and the switch needs to open after a cycle for the heater to refire again, so that fix would be very temporary. But it may tell you for sure what the problem is.
Posted on Nov 14, 2009
  • 1033 Answers
SOURCE: rheem super quite 80, two blinks, no water in
Hello, this code indicates a open pressure switch. Most common causes are weak inducer motor not creating enough pressure to close switch, blocked flue pipe, or the switch itself is defective.
Posted on Sep 26, 2011
Fan heater blower on dimplex cadogan CGN 20 not working properly0 optimyst electric stove
Take it out and see if the fan wil turn by hand. It may have somethng obstructing it. The clicking is the motor overload. It wil burn out if it continues to keep clicking.
www.dimplex.co.uk/assets/.../Cadogan_Stove_Instructions_Issue_2.pdf
Jun 29, 2014 | Heating & Cooling
Furnace tries to start. Blower fan moves momentarily but doesn't.
May have a start capacitor on fan to get it started. If fan only jerks, it is probably bad. Replace if needed. Be sure to short it out with a rubber handled screwdriver or something to make it spark before removing.
Feb 18, 2013 | Rheem Water Heaters
Does the vent motor come on when you turn on a powervent hot water heater
`1) Copy following link to troubleshoot by type of gas control valve, blower motor links, pressure switch testing, and other professional resources:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
2) Power-vent blower motor can go bad.
Plug motor directly into outlet, or turn on-off switch on, and see if motor works.
Check outlet for correct polarity, and for at least 80% of rated voltage.
Check vacuum switch. Blower creates vacuum, and the vacuum switch detect vacuum, and signals gas control valve that burner sequence can continue.
Gas control valve can also go bad. Wiring etc can go bad.
Feb 04, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a york diamond 80 heater. The part that blows the heat out won't come on.. igniter lites and flames come on but blower doesn't..help we are freezing
Sounds like your fan switch is defectiveor posibble installed in the wrong place. This switch is heat controlled and delays the fan coming on until there is warm air to blow.
Dec 31, 2012 | Heating & Cooling
Rheen PVW50 Hot Water Heater Making Buzzing Noise and Doesn't Light
Why is it always Rheem problems?
Every water heater problem is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Copy following link for troubleshoot by gas control valve.
Scroll up and find pressure switch heading among links.
You can install gas control valve yourself.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Sep 06, 2012 | Rheem Water Heaters
Fuirnace blower motor doesn't blow very hard and sound rough
Maybe if you put a drop of liquid soap on the shaft for the fan. Since it is a heater, I wouldn't use a lubricant like wd-40. GOOD LUCK. Soap is cheap. Hope it works.
Jul 02, 2012 | Rheem Gas Furnaces 125K BTU 80 AFUE Single...
I have a Rheem Power Vent hot water heater. Model 21VP50E-1 A. The hot water heater makes hot water and keeps up with demand. Problem or no problem: main burner cycles on and off in about 5 second...
I see your question posted under JJ, and will also watch for the answer.
The Tank has amazing amount of water heater information. But the industry is also changing very fast.
Feb 18, 2011 | Water Heaters
Rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Jul 04, 2010 | Solar Rheem Gas Fired Pool & Spa Heater...
Rheem RBHC-17J14SFA elec furnace fan won't stop
sonds like u have a bad safety switch they r round and have 2 wires on them usually and u can check them by taking the wires off of them and checking continuity thru them there might be one on the blower housing also either that or ur blower relay may be bad and stuck closed
Feb 18, 2010 | Heating & Cooling
Blower comes on and heater don't
Blower comes on then I am assuming no ignition attempt afterwards? If the blower ( Induced Draft Fan) is not being sensed by the safety pressure switch, ignition attempts are aborted until the fan is sensed. If there is a blockage in the vent system, ID blower or sense tubing itself, those would be the obvious starting points to check. If the pressure switch "makes" (closes) then your investigation should lead you to the ignition process. Is there a spark at the pilot burner (if there is one), Is the Hot Surface Ignitor glowing? Is the gas turned on? All can be checked visually.
Nov 12, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
