Question about Ford Vehicle Parts & Accessories
WHERE IS THE CRANKSHAFT SENSOR IN 98 FORD EXPLORER
On the front of engine on the top right(passenger side) of harmonic balancer pulley.
Posted on Oct 17, 2013
  • Mark Evans
    Mark Evans Oct 17, 2013
    This is a 4.0?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
On the rear of motor right about trans case
Posted on Oct 16, 2013
Edge. where is crankshaft position sensor located?
Hi Rusty, There's two links below showing the position of 2005 Ford Explorer Crankshaft Position Sensor and the 2008 ford edge camshaft sensor location. It seems like they're all in the same position, I hope this helps.....CHEERS
2005 Ford Explorer Crankshaft Position Sensor Location
Apr 02, 2016 | 2003 Ford Ranger
98 ford exploer 4.0 2whl dr died while driving tried to re start starter was turning but not engaging sounded like had starter tested was good now what
Check if engine is getting fuel. It usually has a port to plug a fuel pressure gauge to check pressure.other thing is use a generic scan tool if you can pick up trouble codes. It can be crankshaft position sensor or cam sensor.
Feb 20, 2013 | 1998 Ford Explorer
98 explorer 4.0 no start no fuel
if equipped with crankshaft position sensor, check that first. on my jeep it kills both spark and fuel pump.
Aug 27, 2012 | 1998 Ford Explorer
98 ford explorer cranks wont fire
Check your Cam,MAP,MAF sensors.
Mar 07, 2012 | 1998 Ford Explorer
How do check the CPS on a 2000 Ford Explorer?
you cannot check crankshaft postion sensor if your car has hard starts or does not start your crankshaft postion sensor is faulty it tells cars pc when to fire spark and to what cylinder to fire it to
if it helps please leave a 4 thumbs review if it helps
May 10, 2011 | 2000 Ford Explorer
Location of crank sensor on 2006 ford explorer
Here is the diagram, installation, and removal of the Crankshaft position sensor for the 2006 Ford Explorer 4.0L SOHC Engine: http://www.4shared.com/document/M_-IdBmP/2006_Ford_Explorer_40L_SOHC_Cr.html
Here is the diagram, installation, and removal of the Crankshaft position sensor for the 2006 Ford Explorer 4.6L Engine: http://www.4shared.com/document/xevDKaBb/2006_Ford_Explorer_46L_Cranksh.html
Mar 08, 2011 | 2006 Ford Explorer
My 98 explorer turns over but will not start. The fuel pump kicks on for half a second, then immediately shuts off. Does anyone know how to go about fixing this?
your truck has two sensors that are in control.There is a camshaft sensor that controls when the fuel injectors open according to camshaft position.If this one is bad the fuel injectors wont open and the engine wont get any fuel.It also has a crankshaft sensor that is in control of allowing spark to the propor spark plug at the right time.If this sensor is bad you will not have any spark to any of the spark plugs.The fuel pump will only run for 2 to 3 seconds unless the motor starts,it is designed that way and it primes the fuel system and brings it up to pressure.(aprox 40 psi )
Jan 09, 2010 | 1999 Ford Explorer
98 ford explorer oil pressure sensor location
2.9L and 4.0L engines-Left side front of the engine, below the cylinder head in the engine block
Nov 28, 2009 | 1998 Ford Explorer
I cant find the IAT sensor on my 98 ford explorer XLT v 6 SOHC
Try “autozone.com” or your local library for diagrams and step by step instructions.
Mar 12, 2009 | 1998 Ford Explorer
Vehicle Parts & Accessories Logo
37 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
