Question about Coleman Roadtrip Grill LXE 9949-750
My new roadside coleman grill doesn't produce a flame. It heats but not enough to have a visible flame. I am using a 1lb. propane cilynder.
  • 95 Answers
Flames are merely particulates that are heated enough to glow. If a fuel is burning cleanly there will be no visible flames.
Posted on Oct 16, 2013
SOURCE: Propane tank
yes, you need to buy an accessory cord that connects your tank to the regulator
Posted on Jul 17, 2008
SOURCE: propane will not come thru burners
Most propane problems are due to a new valve on the top of the tank. It is designed to only allow a minimal flow until the line is pressured. This prevents fire flair up from broken or leaking hoses. Always turn the bottle on and wait before trying to light a burner. If the burner is on first, the propane will never come out at full flow or if you have a leak in the system, it won't pressurize sufficiently to allow full flow out of the bottle. There is never "air" in the tank.
Posted on Jan 13, 2009
  • 4736 Answers
SOURCE: New propane tank. Burner
jcw - It sounds like the regulator is locked up from turning on the gas tank valve. Happens a lot with the new OPD Valves on the grill tanks.
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Turn the burner(s) ON for 1 Minute, Then turn them OFF.
3. After 5 minutes reconnect the hose to the tank and open the valve VERY, VERY, SLOWLY (Slow
motion, slow).
4. Once the tank valve is fully open light one burner and turn it to HIGH. Did the burner light and
does the flame height look correct? Id so, light the remaining burner the way. Did it light and the
flame height look correct? If so, you solved the problem (with a little help).
If the above didn't solve the problem, the Hose/regulator Assembly needs to be replaced. What happened was this, when you turned the tank upside to "burp" the tank. The OPD Valve shot a hot load of gas to the regulator, when you opened it as you normally would and permanently locked up the grill's regulator. That "burping" trick used to work with the old style tanks. Won't work with the new ones. You can get a new hose/regulator assembly at any home center or hardware store, that sells grills and accessories. They run about $30.00. Take your old one with you for comparison purposes. Once you install the new one and connect it to the tank. Open the Valve Very, Very Slowly, until it is fully open. Or you may have the same problem again.
Hope this helped to solve the problem. Happy Grilling!!
Posted on Jun 19, 2011
  • 4736 Answers
SOURCE: I have a coleman roadtrip
There is no repair. The canister holder/control valve will have to be replaced. You can contact Weber directly at 800-446-1071. If they don't have it try Appliance Factory Parts http://www.appliancefactoryparts.com/ They have a large selection of replacement parts for all makes & model grills.
Good luck and Happy Grilling!!
Posted on Jul 15, 2011
upajos
  • 24 Answers
SOURCE: Coleman propane stove problem
The connector for attaching the regulator to a disposable propane cylinder has a sintered bronze filter in the tip of the brass probe tube that is prone to clogging, or the bronze pellets get mashed down over time, restricting gas flow, and this will cause a portable grill or camp stove to perform poorly. The filter is so fine that it takes very good eyesight and bright light to see that it isn't solid metal, or use of a strong magnifying lens. The best solution is to buy a new Coleman regulator assembly. If you are unable to get a new regulator assembly and have the skills and the tools, you can try drilling a very small hole on the side of the probe tube with a #60 drill bit, just below the bronze filter, but near enough the end of the tube so that the hole will be past the plastic seal when the disposable cylinder is fully screwed into place. You should avoid drilling directly into the end of the probe tube, as the end of it is used to depress the Schrader valve in the disposable cylinder to allow gas to flow. A #60 wire gauge drill bit is only 0.040 inch (1.016 mm) in diameter, but makes a hole large enough to supply sufficient gas to a portable grill or a dual-burner camp stove. If you choose to perform this work, the probe should be unscrewed from the regulator body and the Schrader valve core in the probe tube should be removed before drilling. Be sure to clean all brass and bronze particles out of the probe tube before re-installing the Schrader valve core and the screwing the probe into the regulator. Use a removable-grade thread locking compound to secure the probe in the regulator body and don't over-tighten it, so as not to crush the rubber gasket. Allow the thread locking compound to cure for several hours before attempting to use the regulator. Keep in mind that this modification increases the likelihood of dirt getting into the needle valves and jets of your stove or grill, which can cause maintenance problems in the future.1_28_2013_4_49_27_pm.jpg
Posted on Jan 28, 2013
Coleman 9921 low flame stove
Tony B. s answer gave me the idea to try and spray carburetor cleaner to try and unclog the filter. Worked like a charm. I now have a full flame coming out of both burners.
Apr 10, 2014 | Coleman Propane Grill Stove 9921-700
I have a coleman roadtrip grill. I use a propane screw in canister. When I lite up the grill there is a flame that comes out by the propane cylinder were is screws on the back of the grill. How do I fix...
Jul 15, 2011 | Coleman Roadtrip Grill LXE 9949-750
I'm aving a low flame issue. I replaced the burneres and heat shields a couple of months ago, worked great for a while, but now the flame on all 4 burners is low. When the heat is turned down to half...
If you're turning off your propane tank after each use (which is fine), you will need to turn it back on very, very slowly. The new OPD valves that are now required on all portable propane tanks, will lock up the regulator if it's turned on to fast. Also, check all the pilot orifices for clogs. And finally, be sure you have enough gas in the tank.
Jan 19, 2011 | Barbeques Galore Turbo STS 4-Burner with...
I have a Coleman two burner propane campstove and
Try cleaning the carbon out of the burners.
Jun 22, 2010 | Coleman Gas Grill Stove
I can not get any gas pressure in main burners or side burner, i have a new propane tank, just a trickle of gas not even enough to keep side burner going when only using side burner, will only produce a...
Look for spider webs in the venturi tubes, check the orfices or it could be faulty controls. Verify the tank working properly by trying on another grill.
Eric
Jan 24, 2010 | Brinkmann Charmglow 810-7400-S Propane...
Heating problem
inside its a sensor or limit thats shutting it off
Jan 24, 2010 | Coleman BlackCat 5038-850 Utility Heater
Aug 19, 2008 | Coleman Gas Grill Stove
No gas going to grill.
It would appear that your regulator is not working.
Hope this helps ya
Jun 17, 2008 | Coleman Propane Grill Stove 9921-700
Coleman Roadtrip Grill LXE 9949-750 Logo
121 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
