Question about Delphi Blower Motor Chevrolet Cavalier 2002 2001 2000 99 98 97 96 Bm10029
Why does the heater blower motor in my 1998 chevy cavalier not work in the lower two speeds. The switch has been changed but did not help
    Top Expert:
  • Delphi Master
  • 34,242 Answers
The speed resistor could be bad
Posted on Oct 16, 2013
My 1998 chevy cavalier heater and ac does not work at all also the blower and fan does not come on and it keeps blowing the fuses
I would think either your fan motor is bust. Or it could be a cabling issue.
If you can access the fan motor. Think yours is accessed behind the glove box. Test the fan.
You should be able to get a replacement from a breakers yard.
If not the fan motor is could be a failed switch/speed selector.
Apr 28, 2015 | AC Cars & Trucks
Trying to find the relay switch to my heater on my 1994 Chevy 2500 Silverado?
There might not be any relay, Mary - it might be wired directly from the switch to the blower motor, although the lower blower speeds may go through a speed-reducing resistor pack to get there. If that's true, the resistor pack will be somewhere in the heater plenum, probably near the passenger's foot area.
If the blower doesn't run at all, check for voltage at the blower motor with a meter or test light, switch in all positions, keyswitch ON. The blower motor may have failed.
Aug 06, 2014 | Cars & Trucks
Mazda bravo 2.5TD blower fan only works on speeds 3 and 4. Is it the resistor or the fan motor
ballast resistor for sure as this lowers out put to blower motor and increases power as your select a faster setting balast resistor shoud be located on motor or near by hope this helps phil
Aug 16, 2012 | 1998 Mazda B-Series
Blower will not work on high speed or on recirc but works on lower speeds.
Check connections on switch for loose or burnt wires.Sounds like it might a bad switch or blower motor resistor.Hopefuly its the blower motor resistor its cheap the heater control switch on the other hand is very exspensive. Make sure you check the wire connector for melted connection on the blower motor resistor this could be the culprit.www.rockauto.com has a new wire connector and resistor for alot cheaper than you can get it from anybody else.Hope this helps!!
Apr 19, 2011 | 1998 Buick LeSabre
At first the heater in my cavalier 2001 was working on everything but the first two speeds on the heater (low, and low-med), now only high works. The med-high does not work anymore. I can hear something...
With the lower 2 speeds not working, it was the blower motor resister pack that is bad. It is located in the blower motor housing which is way up in the front of the passenger side footwell. The part itself it fairly cheap (online ~$30, ~$50 locally [if I remember correctly]) and shouldn't take more than an hour to do yourself. The blower motor housing is held together by 3 or 4 screws, and 2 more that hold in the resistor pack itself. The worst part of doing this yourself is that it's in an awkward position for one of the screws. As for the rattling, it could just be something within the housing (you'll be able to check and clear it out of so).
Dec 20, 2010 | 2001 Chevrolet Cavalier
1998 Chevy Cavalier z24 heating/AC fan only runs on the lowest speed, how may I get it work on the other 2 speeds?
Replace the blower motor resistor. It is next to the blower motor.Should be on the passengers side under the dash panel.Good luck.
Nov 18, 2009 | 1998 Chevrolet Cavalier
'05 Freestyle Heater/AC blower only works on high(4). How do I get at the switch or blower motor. Everything is plastic! Does anyone have a solution? Thanks, Bob.
here is what my book says:
Blower Motor Speed Control To Remove:
  1. Remove the right lower instrument panel insulator.
  2. Disconnect the electrical connector from the blower motor speed control.
  3. Remove the blower motor speed control mounting screws.
  4. Remove the blower motor speed control.
Jul 06, 2009 | 2005 Ford Freestyle
Heater blower is not working have no power at the switch fuse is ok the motor is good
check the lower motor relay. there should be one in the power distribution. also check to see if this model has a blower motor resistor which controls speeds if this goes it can cause this problem not sure if the dodge has one. hope this helps
Apr 19, 2009 | 1998 Dodge Ram 1500 4WD
My 1998 astro van blower motor only works on high speed.
No the motor is not bad or going bad, the heater blower motor resister is bad, thats regulates the blower speeds, its located under dash by heater motor 2 screws hold in heater box with a electrical plug to it.
Feb 17, 2009 | 1998 Chevrolet Astro
Delphi Blower Motor Chevrolet Cavalier 2002 2001 2000 99 98 97 96 Bm10029 Logo
88 people viewed this question
Top Delphi Car Audio & Video Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
gmduvall
Are you a Delphi Car Audio and Video Expert? Answer questions, earn points and help others
