Question about GE Refrigerators
LW18jZARW-2 No freezer shelf but has plastic plugs on sides about halfway up which I assume are a place to install a shelf? Has anyone installed a shelf on one of these? If so, where can I buy the shelf? Thanks!
SOURCE: Hotpoint FFA70
Remove the plastic venting box which feeds cold air over the top of the freezer drawers,There are 4 hexagon headed self tapping screws,two at top.and two bottom.Now defrost all ice off rear of freezer and back of vent box.Now replace and door will shut with draws in.Make sure no ice left round fan housing.
Posted on Apr 11, 2008
kachbibi1
  • 979 Answers
SOURCE: Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Posted on Jan 14, 2009
Sea Breeze
  • 4654 Answers
SOURCE: BROKEN SHELF CLIP IN FREEZER
Try to find as many numbers or letters after the ED25PW for example model ED25PWXAN01 There are about 30 versions of that refrigerator so start by entering the basic ED25PW into the model and search feature. And go to a link of your choice and click on the photo refrigeration shelves. There you can choose the parts from the display of the parts and components of shelves.
You can visit my link below. Let me know if I can help you further, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Jun 18, 2009
Partstore
  • 34 Answers
SOURCE: we have a bottom freezer frigerator and in the
For your Amana model ABB2227DE, the shelf you refer to comes in several parts. I have attached a diagram.23d98a7.gif
Posted on Jul 29, 2009
  • 64 Answers
SOURCE: Re Liebherr KTe 1744 fridge: need replacement
have one made at a glass shop and have them temper it
Posted on Aug 26, 2009
My GE Refrigerator doesn't work properly.
The two main causes for your problem is the control set wrong and the second one isthe defrost element has burned out... Sometime the defrost clock will go out as well.... always try to set your controls to midrange and if the bottom of the freezer compartment is cold and frosty but the refrigerator is cold ... Remove all the food and store in a backup refrigerator you can rent from an appliance rental center... Unplug your refrigerator and let it defrost for 48 hours.... In the mean time open up the doors and clean it from top to bottom. place a fresh opened box of arm and hammer baking soda in the frige side and one in the freezer side. Plug back in after completely deftosted and place a small plastic cup half filled with water on each shelf of the freezer. Close the doors and wait 8 hours... Open the freezer and check the plastic cups.... if they are all frozen great..now wait for 3 days do the test again if the bottom cup is frozen and the top shelf is not ... its time for a new defrost element or a defrost timer.
25 years service
stocktongoodrepair@gmail.com
Sep 21, 2014 | GE Refrigerators
Frigidaire upright freezer door will not seal
Hi Chris, this is AP! Thank you for your post.
I understand you are having trouble with the door sealing on your upright freezer. Many times this can be caused by the freezer not being leveled. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems. To level your upright freezer use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, 1/2 bubble higher, so that the door closes easily when left halfway open. I hope this information has been helpful.
Mar 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
How to thaw a 20 lb turkery in refigeratores
Would need to know a bit more information.
1 Type of refrigerator (top freezer or side by side or bottom freezer)
2 How soon do you need turkey thawed
On 1
Top freezer type = place turkey on lowest shelve in a pan to catch water.
On Side by Side type = this will take the longest to thaw as it has a consistent temp through out.
On bottom freezer type - place turkey on highest shelf of refrigerator.
Nov 21, 2013 | Refrigerators
I have a 1998 buick park ave ultra and the driver side air blows heat and the pass side blows cold
assuming you have an electronic controlled (digital) dual zone system, it is most likely your heater blend door motor has failed, check and see which side is operating and buy the one you need and replace, it has 2 or 3 screws on the side, i think size is 4.5 mm or 5.5 mm and you have to take off lower plastic cover under dash and remove screws which go on horizontally... install heater door with temp swithched to the middle, move door to middle, if not you need to place new motor into plug before installing and turn temp to cold, then turn by hand the white blend door tube to match motor then install... make sure you turn off ignition when working,,,
Jun 22, 2010 | 1998 Buick Park Avenue
Freezer shelf issue, roller adjustment, Icemaker problems
There is not a recall per say on this issue but there is what's called a training bulletin.. The cabinet tends to spread out causing the shelves to fall out typically in the middle.Some models have wider shelves that will not fall out but also can not be pulled out due to the recess in the sides of the inside of the cabinet. The other fix is installing a little c clip on the sides of the trouble shelf in hopes that it will stop it from falling out. part # is WB4X174 and I have not had good results with them but it is a cheap fix. 2 per side are needed. Ge would have to be contacted to see if wider shelves are available but they are very expensive!
Mar 21, 2017 | GE Profile PSC25MSWSS Stainless Steel...
I mant to reverse the opening swing of my refrigerator doors
You have to remove the doors, swap the hinges to the other side. Start by taking the top hinge off the freezer door (pop the plastic cover off the hinge to reveal the screws). If it has handles (some don't) you will need to swap them over as well. The screws are under plastic covers on the ends. There will be plastic plugs in the holes that will need to be removed and placed into the holes you took the screws out of. This is assuming your model has reversible doors. Most do, but some don't.
Jan 11, 2010 | Kenmore 70832 / 70834 Top Freezer...
Wire shelf in freezer of Frigidaire refrgerator - how do I move?
since on differnet models it goes right or left,
but you should be able to push the shelf one way, enough so that the other side pops out of the wall
then slide in the long side first, you will see what i mean when you have the shelf out
push the long side in with a lil pressure and raise the shelf the leve you want it installed on
Oct 14, 2009 | Frigidaire 18.3 cu. ft. Professional...
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Cannot install water line
I too had to scratch my head to locate where to connect the water line for the ice maker. Looking at the rear of the frig on the bottom right you will see a white plastic cover that the black plastic line goes into. There is a screw on the right side. Undo the screw and then pry off the white plastic cover. You will see a black plastic cap over the threaded water line connector. This is where you connect you line as approprite. I hooked up the line and turned the water supply back on and then you have to turn on the ice maker. I works great. Problem is the manual is not clear at all. Guess they assumed that the installler would be hooking it up. Once you know what to do is is a piece of cake. Good Luck. Doug S. in Poland, OH
Aug 11, 2008 | Refrigerators
Hotpoint FFA70
Jan 21, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
236 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
