Need device code for Hitachi 19LD550U - Televison & Video
Need code for hitachi 19LD4550U
0291,0226,0206. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Oct 30, 2015 | Hitachi Televison & Video
NEED THE CODE AND HOW TO SET UP THE REMOTE
Codes to check with Hitachi brand TVs are:
0102 0104 0107 0110 0119 0126 0127 0150 0152 0161
Aug 10, 2015 | Hitachi Televison & Video
Need code to program to hitachi tv remote.
Codes are stored in your Hitachi remote. What you really want to know is how to use your remote to control some unidentified device.
Jun 07, 2015 | Hitachi Televison & Video
Code for hitachi tv remote model no. l32hpo3ua
0173,0118,0190,0101. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
Mar 06, 2015 | Hitachi Televison & Video
I need a code for my Hitachi 50HYT62U tv for virgin tivo remote
2610,2663,2681. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Dec 28, 2014 | Hitachi Televison & Video
Need a codes forone for all universal remote control
0268.0266,0269.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
Jul 30, 2014 | Hitachi Televison & Video
I NEED THE REMOTE CODE TO OPERATE A HITACHI TV FROM A PHILIPS UNIVERSAL REMOTE
Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
HITACHI ........... 0088/ 0059/ 0142/ 0060/ 0072/ 0004/ 0009/ 0091/ 0001/ 0012/ 0061/ 0137/ 0139/ 0141 /0179 /0227
May 09, 2011 | Hitachi 53UDX10B 53" Rear Projection...
I need the cod
Hello
I don't know what code do you need. Your post is not clear. Anyway assumeing that you needs universal remote contol codes for your Hitachi, and posts this solution.
Three digit universal remote code for Hitachi are:
001/ 004/ 009/ 013/ 059/ 061/ 079/ 088/ 091/ 137/ 139/ 140/ 141/ 142/ 143/ 144/ 145/ 146/ 179/ 210
Four digit universal remote codes for Hitachi are:
0088 0059 0142 0060 0072 0004 0009 0091 0001 0012 0061 0137 0139 0141 0179 0227
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Apr 26, 2011 | Hitachi 51F510 51" Rear Projection...
Need code for hitachi tv
Hitachi: 1145, 0145, 0151, 1904, 0032, 0409,
or you can use the general method:
SEARCHING FOR YOUR CODE
If your device does not respond to the remote after
trying all codes listed for your brand, or if your
brand is not listed, try searching for your code. For
example, to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks
twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power.
The remote sends IR codes from its library to
the selected device, starting with the most
popular code first.
5. If the TV responds, go to step 6. If the TV
does not respond, press CH+. The remote will
try the next code. Continue until the TV
responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps
1 to 6, substituting the appropriate device
key.
Apr 04, 2009 | Radio Shack 15-2142 Remote Control
Hitachi-lg cd-rw gce-8487b device driver corrupted or missing error code 39
You may find your driver here: http://us.lgservice.com/ or here: http://www.kauaikeepsakes.com/computerguy/
Good luck
Mar 22, 2008 | Computers & Internet
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
