Question about Sony KP-FX532M91 TV
Sony 10 blinks - Sony KP-FX532M91 TV
Sony kp-57xbr10w. Red light blinks 10 times . When you turn power on sound comes on . No picture . Then no sound and red light blinks 10 times . Help
Sounds like a highvoltage failure. might be the flyback or focus circuit too. oddly I cant find any useful info about 10 blinks.
Sep 30, 2015 | Sony Televison & Video
Trying to update my sony kdl55ex621 firmware and now I only get 10 red led light blinks
Congratz. You bricked it. Messing with fimware is mortal for electronic equipment. Maybe an authorized Sony repair service can help you, most probably not.
May 27, 2015 | Sony KDL55EX621 55 Class LED Backlit HDTV...
10 blinks Sony rear projection
If your model is a KP57WS520 and the light blinks 10 times thats a fairly common issue and there is a repair kit for that error at the following link it bottom of the page http://tvrepairworld.com/rear_projection_tv_circuit_boards/rca_circuit_boards
Apr 03, 2013 | Panasonic PT-53WX53 53" Rear Projection...
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Aug 28, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
My KP-51WS520 blinks 10 times
Type in Sony Blinking codes on Google you will find all blinking codes and what they mean.
Aug 06, 2009 | Sony KP-51WS520 51" Rear Projection...
Led 10 blinks then turns off
According to sony,
Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Thanks.
Jun 16, 2009 | Sony KP-FX532M91 TV
10 BlINKING LIGHTS ON SONY TELEVISION
in these sets you have to check the power supply board. check all capacitors maybe blown on top.
Jun 07, 2009 | Sony KP-51WS520 51" Rear Projection...
Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Apr 15, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony KP-FX432M91 TV 10 blinks
my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
my email address is drbonnyb@yahoo.com
Oct 31, 2007 | Sony KP-FX532M91 TV
Sony KP-FX532M91 TV Logo
21 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
