Question about Samsung YP-T8 Digital Media Player
How to paste a sme firmware download file to "ROOT" of my yp-t8
How do I copy a downloaded SME Firware file to the "ROOT" of my YP-T8. Apparently this should fix my forever "system loading problem". Thank you
  • gt_shinoda Sep 09, 2008
    hi? I'm mongolian. pls yp-t8.img.fnt.rom send me
    Problem Solver:
  • 6 Answers
Ok you need to know exactly what model number player you are using as there are three versions of the YP-T8. * YP-T8A * YP-T8X * YP-T8Z Once you know that then you go to the samsung site and download the appropriate driver. Looks something like this: FM/200611/20061107201844343_YP_T8_ROM_20060609_138US.zip Once you do that you have to unzip or extract the file. Windows should do this automatically. According to the directions you then take the files that it unzips and put them on your mp3 player. So connect your mp3 player to the computer via that usb cable. It should show up as a Removable Device under My Computer. Find the files you just extracted. Should be YP_T8.fnt, YP-T8.rom and YP-T8.img You then simply copy those files into the mp3 player which is that new removable device drive. The root folder is the first area you see when you first explore the drive. i.e. any folder you see on that mp3 player when you double click on it is actually a sub-folder and not the root folder. So open it up and copy those files right there. After which you then do as the directions say. Unplug the mp3 player, power it off and then connect your charger. It says it will automatically upgrade the firmware and then automatically turn on so it should just be a waiting game at that point. Good luck!
Posted on Sep 26, 2007
SOURCE:
How do i put music on my yp-t8 and how do u delete it and how do you plug it in the computer
hi there,
you can use Download and Install Samsung Media Studio as the software to manage your media (music and picture files).
To download Samsung media studio, go to this site:
http://samsung-media-studio.software.informer.com/
See how to use and install it from the manual ( including how to connect it to a PC) here:
http://downloadcenter.samsung.com/content/UM/200509/20050905090213203_YPT8-SECA-ENG0.0.pdf
hope it help
regards
Apr 17, 2010 | Samsung YP-T8 Digital Media Player
I can not get my yp-t8 to download to my pc my pc is xp home and the driver that ihave is win 98
If the driver you mention is only for Win98, it is of no use in XP.
For the YP-T8 there are 3 model players, that might need different driver, software and firmware (under OS there's a listing for the supported Operating Systems).
Select your model on next page:
http://www.samsung.com/uk/support/search/supportSearchModelResult.do?menu=SP00&searchWord=ypt8&default_searchInputBox_value=Enter+model+number+or+keywords&searchInputBox=yp-t8
Next select the matching driver, software for your computer.
Download and install the driver and software.
Also look under firmware, to see if there are updates for the player.
Apr 09, 2010 | Samsung YP-T8 Digital Media Player
I just changed comnputers and i can't find the disk that came with my mp3 yp-t8. How can I transfer music to it??
Support for the YP-T8 can be reached here:
http://www.samsung.com/uk/support/search/supportSearchModelResult.do?menu=SP00&searchWord=YPT8&default_searchInputBox_value=Enter+model+number+or+keywords&searchInputBox=YP-T8&find_button=See+all+results
Select the exact model from the list, going to Downloads.
Next select the drivers and software under Downloads, matching the operating system on the computer.
Manual for the YP-T8 in pdf format:
http://downloadcenter.samsung.com/content/UM/200507/20050711085738421_T8__ENG_1[1].0-1.pdf
Jan 10, 2010 | Samsung YP-T8 Digital Media Player
I have lost my samsung yp-t8 player software cd
I have lost my samsung yp-t8 player software cd, how do I get it?
Dec 26, 2008 | Samsung YP-T8 Digital Media Player
I want to reset my samsung yp-t9
Complete Solution - includes fix for Bluetooth.
You will need to execute a number of steps to do this:
1 - obtain a copy of the latest firmware from http://www.samsung.com/uk/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=mp3others&subtype_cd=&model_nm=YP-T9&dType=D&vType=L&mType=&model_cd=&menu=download&prd_ia_cd=&disp_nm=YP-T9
or (even better) - go to the international site and download a copy of YP-T9 V1.80.zip
2 - Reset - Power off the yp-t9 using A-B and MENU pressed together - hold down A-B and press the POWER button to enter the low-level format mode - press LEFT LEFT RIGHT RIGHT UP CENTRE DOWN - the yp-t9 will now reformat - power off using A-B and MENU together
3 - reload firmware - Power on normally and connect to PC as a USB drive. Move the two files you just downloaded (MUON.ROM and SYSDATA.BIN) into the root of the USB drive - Safely remove the drive - Power on the yp-t9 and allow it to re-install the firmware
If you want to restore Bluetooth functionality you will also need to perform the following steps:
4 - pop the four rubber plugs out of the back of the unit - with a small phillips screwdriver remove the four screws - insert your fingernail into the seam of the unit on both sides and pop off the back - gently (slowly) remove the battery taking care not to place any strain on the connecting wires - copy dowm the 12-digit number on the label under the battery (starts 0016xxx...) - replace battery, back, screws and plugs.
5 - using text editor create a file with the 12 digits (use upper-case letters where appropriate) followed by <enter> key - save it as BT_MAC_ADDR.TXT
6 - connect the yp-t9 and open it using Right click on Start and Explore - find the yp-t9 and drag a copy of BT_MAC_ADDR.TXT into the SYSTEM folder - Safely remove - power on normally.
Hope this helps
Chris
Nov 19, 2008 | Samsung Yepp YP-T9 Digital Media Player
Samsung YP-T9 corrupt files
Go to the settings menu in your yp-t9.Then open the system menu.Then update the library.The files will go after this.Guess this helps.
Jan 18, 2008 | Samsung YP-T8 Digital Media Player
System loading...forever posted by mykel280 and responded by pcgeek on mar 21,2007
Sep 25, 2007 | Samsung YP-T8 Digital Media Player
How do you put videos on it
You either drag & drog the files to the removable disk or go to Samsung Multimedia Studio and select 'export' and select 'export videos to device' on the drop-down menu. If the files aren't in the correct format then it will do that and transfer the files.
May 19, 2007 | Samsung YP-T8 Digital Media Player
Samsung yp t9
Firstly, "re-set" the T9 (ie hold 'MENU' & "REC', for 3 secs to re-initialise the built-in firmware - refer to your manual, or download manual off Samsung website). This procedure will overide everything. If this gets it goin, then download the latest firmware update from Samsung website (download centre/mp3) and save newest firmware onto your T8 - your manual should explain how to do this. Always update your T9 with latest firmware when available (appropriate with your Windows OS), to eliminate any bugs in the firmware. Failing this, then a replacement battery is the next step. If still under warranty (ie less than 12mnths old), then have an approved Samsung service agent look at it Free of charge. Good luck.
May 13, 2007 | Samsung YP-T8 Digital Media Player
Samsung YP-T8 Digital Media Player Logo
244 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
