Tried to take client from high lift blond to level 7 , filled midends andends with gold , root was quite warm . applied 7/0 colour touch 1.9% all over , colour was green , ends very very dark , 5 ash , have stripped with blondor shampoo and warm water , now have gold root , gold with slight ash hugh through ends , washed some red through to koll ash , have gold level 8 roots ends red/brown but between level 7/8. no shine , 0n mid lengths and ends . any suggestions client doesnt want to be darker than a level 7
  • 26 Answers
SOURCE: Red colour prints brown
Just replace the non genuine inks with proper Canon ones and then do about 4 full cleans, that should fix it. If not you will have to replace the printhead, which is usually caused by using non genuine ink. Good luck
Posted on May 28, 2007
Mix-it-up
  • 832 Answers
SOURCE: My mfc215c doesnt appear to recognise magenta
So let me give you some clues reading the recorded errors:
A1 : (even a brand new model has this error which simply means COVER OPEN/Close Cover (e.g. when installing carts)
38: puuuhhh error starting with a 3 has always to do with the traveling of the printhead.
Or there might be a defective part within the gear wheels.
84: something to do with the paper roller feeder (you might have run out of paper or paper wasnt feed in right position: some paperjam afterwards. This error can be related to error 38.
Anyway,
if you had done the maintenance cleaning procedures and didnt have any luck with good printing, there is only left to say:
print head clogged and needs replacement!
(The main reason for this is either having used generic ink which will definitely destroy the ph within some time period or you have paused the machine for too long time so that the ph has dried out.)
Posted on Dec 07, 2007
  • 111 Answers
SOURCE: 99% of printed page has light grey water mark-as if water-washed
Are you saying it is this problem?
Gray Background Print Quality Defect
Here's another error that might fit the bill:
Vertical Lines Print Quality Defect
If these documents don't quite describe the issue, please post back with more details. Thanks.
Posted on Oct 15, 2008
Inky
  • 691 Answers
SOURCE: Colours are wrong
Most likely a toner spill down the back side of the carousel. Remove all the toner and dev unit and vac out any spillage from within the printer. DO NOT VAC THE DEV OR TONER UNITS.
Replace all the units and print about 200 full colour pictures (preferably a test chart - Gretag McBeth or similar) at full size (A4). See if the colour then begins to return to normal. If not, you will probably have to replace the dev units too.
Posted on Nov 09, 2008
  • 191 Answers
SOURCE: My ML 1610 Laser printer was working just fine a
please your problem is printer in rem and sarket in ice is fail. and you go to the near autho. dealer and changing the serket board
and checked the rem. and printer's services is fine.
Posted on Oct 03, 2009
Hi...I recently used Goldwell topchic 9N and mixed it equal parts with topchic 30 vol. cream developer. My roots came out a reddish tone which I do not like. My virgin color is between a 2 and a 3 (Dark...
it's only possible to lift 3 shades (like 3to 6, or 4 to 7) without taking undertones into consideration. To go from a dark brown (level 3) to a 9n you would have to pre-lighten your hair with an on the scalp bleach first. Then color with 9n and 20 volume
Jan 27, 2015 | Goldwell Health & Beauty
Bleached hair roots turned white the rest is orange
You cannot lighten "color" with "color". If you had to, and only had one color, you could possibly put color on the ends first, wait 10 mins and then apply to roots (which is difficult to do on your own hair) Virgin (uncolored hair) lightens MUCH faster than colored hair. alot of times the colored parts of the hair will never get as light as the roots, without using a differant product. This is why people go to salons :) Anyway, first try Matrix shampoo called "So Silver" (this will tone the hair. Its purple color neutralizes the orange. Most likely though, the color you used was a darker level of color than what your ends were and since you cannot lighten color with color, you get brassy orange. Go to sally's beauty supply, pick up some hair bleach, 20 vol. developer. mix together equal parts. wet your hair, lather with shampoo/conditioner mixture, and smush bleach mixture ONLY to your orange ends (NOT YOUR ROOTS)watch your strands fade from orange to light pale blonde and rinse as soon as it hits desired level (only takes a few minutes) Hope this helps.
Sep 02, 2014 | Clairol Nice n Easy Born Blonde Hair...
My dishes are not clean in my whirlpool gold quite partner III. my model #gu2275xtvy0
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 05, 2011 | Whirlpool Dishwashers
Can I put Loreal Feria 93 on bleached hair which was done over a month ago and achieve the color on the box?
Golden blonde is safe for high lift blonde hair, if the bleached hair is lighter than the color on the box it should match normally.If the bleached hair is not as light as the box it can lighten it some and help at tones to your hair.
Jun 02, 2011 | L`Oreal Feria 93 Candle Glow Light Golden...
2 door 2001 cavalier how to check for transmission fluid
The check plug is located just under the axle on the passenger side of transmission. The plug has a 7/16(11 mm) head on it.The engine must be idling in park and the transmission must be warm to touch(about 100 degrees).The car must be level.needless to say this is a real trick without a lift.You fill the transmission via a red threaded plastic cap on the top and drivers side.Good Luck!
Apr 13, 2011 | 2001 Chevrolet Cavalier
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
k24674
jasbo
jasbo
