Question about Asko T731 Electric Dryer
The display on our T781 Electric dryer is "dead"
Do I use the USB socket to charge my battery in the S529. it switches on then goes to MSDC mode.
Posted on Oct 16, 2013
2 Suggested Answers
Rotu
  • 175 Answers
SOURCE: Asko T781 Electric Dryer Doesn't Turn On
Have you reset the cut out on the back? its a little black button that you push in until it clicks. If it does not click, then it probably wasnt the problem. The next most likely cause is a melted fuse holder inside the box on the rear where the power cord goes in. There is a bypass kit available to repair this problem from ASKO, as the fuses are not needed. If you are able to do some simple wiring, you can do this. Otherwise find an AUTHORIZED asko servicer and they will know what I'm talking about. Good luck!
Posted on Jun 18, 2007
The display doesn't work
Asko are not very common in many areas and so not many people can mentally remember what this model looks like.
However, if the display doesn't not work: Try unplugging it for five minutes or just removing the power for that time. See if it resets.
Not sure what 'does not work' means...no light, no response to touch..respond but does not start..???
Give more info if you seriously nee people who are not at the machine to help you.
Oct 16, 2013 | Asko T781 Electric Dryer
My dryer is starting to sound noisy
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 23, 2011 | Asko T781 Electric Dryer
Asko dryers
Akso makes "condensing" dryers (Models T721 and T781) that condense the moisture wich then is directed to a drain. The T701 is a vented style dryer so I'm a little confused.
Dec 15, 2009 | Asko T701 Electric Dryer
I have an ASKO T781 Dryer that suddenly will not power up. Any ideas? Someone told me to pull the fuse panel? I do not have the manual available. Any ideas or what tool to use to pull the fuse panel. Also,...
I just had this same problem, The fuses were not attached to anything. I stumbled upon a black button, that looks sort of like a gromet. Push that, it's a reset button. If it clicks, there you go. It could mean something else is wrong, but that should be a starting place.
Sep 01, 2009 | Asko T781 Electric Dryer
My dryer is making an increasingly noisy rolling sound when in use. It is an Asko T701 model
sounds like your drum guides or felt thats wore
out or something stuck inside there rubbing
Jun 17, 2009 | Asko T781 Electric Dryer
Disabled neighbor was given an ASKO T780 dryer, but it doesn't heat up. What could the problem be so I might be able to fix it for him?
most likely if the dryer does everything except heat up the heating element is bad if you take it apart it will be directly behind the holes inside the dryer
Jan 15, 2009 | Asko T781 Electric Dryer
ASKO T761
press the black reset button on the back.wash door filter and condensor,then try again hope this helps.
Mar 16, 2008 | Asko T781 Electric Dryer
Asko T781 dryer trips on over temperature
The problem is probably that it is much lint in the fan, and/or in the back of the drum, so the air is unable to cirkulate fast enough. OR it can be that you are overfilling it with laundry.
Nov 25, 2007 | Asko T781 Electric Dryer
May 30, 2007 | Asko T781 Electric Dryer
Asko T731 Electric Dryer Logo
87 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you an Asko Dryer Expert? Answer questions, earn points and help others
