Question about NEC SL1100 1100061 Digital 12 Btn Black Phone IP4WW-12TXH-B-TEL
My phone has a fast blinking light and the display says MSG >>> CONFERENCE. How do I cancel this??
Banked call?
Message waiting can come from several sources. Usually they are stacked at the phone and you can keep pressing message until they are all displayed. Have the person down the hall pick up the phone when you ring it, or look for the message cancel code and get that message off your set. If it clears, that was the only one and you have no voice mail messages.
Carl
Dec 16, 2009 | Toshiba DKT2010H Phone
Charge light keeps blinking This light usually blinks when we have a recorded msg but there is no msg
I have a problem for my uniden phone. I did deleted msg on uniden phone but the light still blinkling . I don't know why ? . Can you help me,please ?
Nov 22, 2009 | Uniden Lands Phones
Called extension and now the light won't stop blinking.
There is a messaging side that is part of the phone system and not the vmail. You can send someone a message and it will appear on that persons phone as text. you should be able to call the person back and that will cancel the message, if not scroll thru the menu screen on that phone for msg cancel.
Dan
Jul 30, 2009 | Comdial Impact 8324S Corded Phone
Message Light
press #409 to cancel message receive
press #64 follow by et\xtn on display to cancel sent message
mayb st 21 been assigned, but no body know.to check, call from all extn to displayed phone.check 1 by 1.
if light keep blinking for mic, try to change other key phone
May 27, 2009 | Toshiba DKT-2010 Corded Phone
DKT2020-SD Msg Light Blinking for no reason
#409 to cancel receive message...may need to key in few time to cancel few message
#64+sent messane extn - to cancel sent message
Apr 17, 2009 | Toshiba DKT2020SD Phone
Message Light
Press " Intercom " # 4 0 9 to cancel msg lamp that was not left by voicemail or press the message lamp and when it rings to an internal phone have someone answer it and that will turn off the lamp also.
Jun 12, 2008 | Toshiba DKT-2010 Corded Phone
Message Light won't stop
If you have vmail and no msgs and the only light that is flashing is the light at the top right of the display, what that is flashing for is someone set a msg to your phone from another phone on your system. Try this :
without picking up the handset , dial 43 .
the display should show the ext # that set the msg and an option to reply or clear . press the btn under the display where it says clear and the msg will clear and the light will go out.
Mar 18, 2008 | Samsung Falcon 18 Corded Phone
Polycom ViewStation H.323 Red Blinking Light
Are you able to move the camera using the remote?
If not, then you may have a hardware issue.
If yes, then try to connect to the Viewstation (web interface) using its IP from a Computer.
Let me know what happens
Jan 18, 2008 | Polycom ViewStation ISDN (pcy220011323001)...
Display shows "Not Registered"
1. Remove battery from phone, and unplug from charging cable
2. Unplug Phone base
3. Hold Page button on base and plug it back in. While holding page button wait for in use light to go solid. Once solid unplug base.
4. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen.
5. Press 0
6. Unplug power from phone pod
7. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen.
8. Hold the page button on the base and plug it in, Hold page button until the in use light blinks. Let go of page button.
9. Press 9 on your phone. If it says Reg o it is finished. If it says Reg fail try again if it fails twice please call Tech support.
10. Replace Battery
11. Make a test call
Oct 05, 2007 | ClearOne Communications Max Wireless...
NEC SL1100 1100061 Digital 12 Btn Black Phone IP4WW-12TXH-B-TEL Logo
80 people viewed this question
Top NEC Radio Communications Experts
Mister Danger
David Payne
David Payne
Are you a NEC Radio Communication Expert? Answer questions, earn points and help others
